#5826
Total Scrounge
Bikes: 71 International 72 Super Course 83 Gap
Quoted: 327 Post(s)
Liked 924 Times
I scored two bicycles this year with custom touring racks that were, thankfully, still attached! One, a Bruce Gordon Hikari came with the standard issue, blue BG racks, and the second, a tandem made by John Cutter in San Luis Obispo, came with even cooler bespoke racks. Both have fender eyelets on the rack that allow you to run shorter struts, and the Cutter racks even have threaded inserts for mounting through the fenders. Both bikes have been getting used in wet weather, so I finally scraped together some fender bits and every ounce of patience I had and got to mounting! I'm glad I didn't spend a bunch of money on the perfect fenders for these, because there were lessons learned, and these were perfect as rough drafts!
The BG got the chromoplastics that came with the bike. I quickly realized that the downside of this design is that the struts have to enter the brackets on the fender in a perpendicular fashion. I imagined myself executing perfect compound bends, but I ended up just grabbing and yanking until it looked decent. I'm no metal artist.
Meh. The Cutter was a second draft. I had some aluminum Planet Bikes that I had previously installed on a 700c cross bike. The mounts on these racks follow the radius of the tire really nicely, so I was able to make them hug the 26" wheels pretty nicely. I also had some short, individual struts which I learned from the BG were crucial.
If anybody has any advice for second drafts of these, I'm all ears!
Likes For JacobLee:
#5827
Quoted: 1607 Post(s)
Liked 2,216 Times
The aforementioned TS-2 stand facilitated the next day's trueing of the Bianchi Wheels along with the gliuing of the rims. Tires were also glued.
Last step is to put another layer on the rims and then mount the tires, hopefully today.
Then it will be ready to ride for the first time.
I have Spin Doctor truing stand I have used for a couple of years, maybe 10. The TS-2 is a huge improvement due to its stability and overall design. With the SD, I always used the QR to ensure the hub stayed in place. The TS-2 Simply has V notches the axle slips into and then you clamp it with 1 knob. Much faster to check dish with a dishing tool. However, I found I did not need to as the stand is very well aligned. I don't know how the alignment happened with taking it apart but only fraction of an inch correction was needed of the collars on the tie rod.
Since this is an older version, all chrome, it has the calipers without the plastic covers. Upgrade calipers were ordered to get them. I did not find how to order just the covers.
Likes For SJX426:
Likes For Mr. 66:
#5829
Quoted: 938 Post(s)
Liked 2,939 Times
With the two builds I had on my plate mostly done I’m trying to catch up on various tweaks and general maintenance and cleaning on my fleet. I started with the Shogun, which got a 700c wheel set (VO rims and high-flange early Dura-Ace hubs) that had been on Mrs. ascherer’s Motobecane. I swapped in a longer axle and dished it to accommodate a 7-speed freewheel. After that the VGT Luxe that was on it didn’t want to clear the big cog so rather than fuss with it I put on a long cage Arabesque rear derailleur. I did a little bending on the front rack to clear the cantis better, and applied some fresh bar wrap.
I really should screw the adjuster down and re-tighten the cable.
Next up is the Falcon which gets a Record headset to replace the Shimano that’s on it - nice, but out of place - and a vintage coiled cable housing for the rear derailleur.
Likes For ascherer:
#5830
Quoted: 253 Post(s)
Liked 223 Times
#5831
Quoted: 938 Post(s)
Liked 2,939 Times
Even nicer when I get it in focus.
Likes For ascherer:
#5832
The Motobécane I bought a few weeks back came apart without violence. It appears all it needs is a good cleaning; the bearing surfaces look good.
As a bonus, the drive side BB threads were deep enough to "read" from the outside past the fixed cup, making it possible to determine it is a left handed thread. Came right out, too.
Now I have to figure out how to set it up... 27? 700?... I'm probably going to start as-was with 1 1/4 Paselas to get a feel for the bike, then decide. High of 17 F today. No real hurry...
Likes For steine13:
#5833
Bikes: Motobecane C41, Matsu$hita Nashonaru
Quoted: 215 Post(s)
Liked 430 Times
#5834
@VintageSteelEU
It's a 1981 Grand Touring. Sorry, I should have given a bit more information.
Temptation is everywhere, and this particular instance was on the Enabler™ thread; I posted my acquisition here: https://www.bikeforums.net/22770983-post70.html
This is becoming like a part-time job; I need to harvest the serial numbers -- all twenty of them, this thing is full of stamped digits -- and post them on the appropriate thread, and I should also make a build thread for it, it's a nice example of a bygone aesthetic.
Not perfect, of course, the paint is scraped in places, and some genius put a kickstand on the chain stays.. for some reason, the tops are hardly affected but the bottom is somewhat flattened. The while thing begs to be turned into a 650b, and with the stays pre-dented, why not?
The size is 23" -- 58 cm and change center-to-top on the seat tube, and 57-58 cm top tube, I generally like more height, but that's as much length as I want to deal with. The frame with nothing but the headset cups and the dropout adjusters weighs 2370 g; the fork is 880 g, making the whole thing about 350 g heavier than the 1997 Cannondale R200 I moved on to make room. At that differential, I'll take the steel and hope for a lively ride. So far I've only done a ten-miler locally to check it out.
And the bike came with strong wheels; Normandy hubs and Weinmann concave rims that run pretty true.
Here, I'm not kidding about the serial numbers:
cheers -mathias
cheers -mathias
Likes For steine13:
#5835
Fast Old Guy
Quoted: 145 Post(s)
Liked 672 Times
The older I get, the more I realize that I need to make adjustments if I want to keep riding racing bikes. After many years and several thousand miles with Cinelli 65 Criterium bars and a brief experiment with ergo bend bars, I installed Soma Hwy One bars, with Tektro RL340 levers replacing Shimano 600 EX non-aero levers. A 20 mile shakedown ride felt good on the hoods and in the drops, only needing a minor lever position adjustment before I do a final cable trim and bar wrap.
Likes For Straightblock:
#5836
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
Bet you have better braking power as well!
#5837
ambulatory senior
Quoted: 1955 Post(s)
Liked 3,661 Times
@VintageSteelEU
cheers -mathias
cheers -mathias
#5838
Quoted: 215 Post(s)
Liked 430 Times
Still have the big project going on. Not sure when I'm going to finish it, probably will take a few months before I start building it up. The frame is Motobecane C5 with Columbus SL tubing. Most likely from 1980. It needs repairs to the seat tube (which would require paint removal). It was also extremely rusty, so I decided to strip the paint anyway (nearly crying when doing that, because the few good remaining bits were beautiful Motobecane metallic / candy red) to see if restoring the frame is even viable. All the dark spots you see in the photos are essentially pitting from rust. I still have the difficult to get to bits to remove the paint from, but getting there.
I have a nearly full Ultegra 6400 group which I was planning to use on this frame (with Miche gunmetal grey seatpost to match other components, Cinelli 1A stem, Cinelli Campione Del Mondo handlebars and 600EX non-aero brake levers), but my plans have changed when I managed to get NOS Suntour Superbe RD (first version from the late 70's). It was going to become Motobecane C5 Superbe until I realised I can forget about getting the first version of Suntour Superbe crankset. They are simply too expensive and all I've seen are additionally pretty well used. Can't justify the price. There is also basically no chance of me finding Suntour Superbe stem (made by Kusuki) or seatpost. So, after long deliberations, it's going to become Motobecane C5 Superbe Royal. I've managed to get SR Royal RY5-ESL crankset and will be hunting for some other SR parts over the next few months. Just got Superbe FD in a very decent condition, so making some progress. Still will be getting Superbe 4700 brakes and levers and Superbe hubs. So it should build up as a fairly light and nice late 70's / early 80's bike. I might have to sell a kidney to get there though
And a small project today was the bad boy below. Suntour Vx-S, as far as I can say it was never used in its 44 years since leaving Maeda factory. Just cleaned it up and put some fresh oil in a few places. It's also a proof that I should consider some therapy to treat addicition. I have Vx-S on my Grand Sprint and after tuning up it works like a charm. It's also in a decent condition. No play anywhere, shifts well and it's nice and clean. No reason to replace it whatsoever. But when I saw another one, I decided I can't possibly let it go and justified the purchase by thinking I will replace the one on the GS. Then I thought some more (very bad habit, I'm afraid) and decided I don't need to fix something that's not broken. I just need another frame. And build it up as a bit less flashy, Suntour based 70's Randoneur bike. Not sure what for, because I have a Motobecane built up as 80's Randonneur with mostly 600EX SIS components. Rides great. But have to say that since I've put Suntour components on my Grand Sprint and got used to friction shifting again, I found riding it more and enjoying it more. This one will have to go in a few months, so I guess since I have quite a few parts for another build, I might as well. I should probably do a clearance sale of components to avoid more temptations in the future.
#5840
Quoted: 215 Post(s)
Liked 430 Times
If I had more space for storing bicycles safely, I could just keep building them, but realistically, there's room for 3. The other option is to move somewhere with a lot of storage space and fully commit to restoring C&V bicycles for the rest of my days.
That C5 is going to hurt my wallet for sure. It will be beautiful if I manage to complete that build, but I can see it blow a substantial hole in my wallet.
Likes For VintageSteelEU:
#5841
Quoted: 938 Post(s)
Liked 2,939 Times
Tinkered with the San Remo last night and today. Installed a Campy Record headset, wider Cinelli bars, a more retro-style Zefal bottle cage, and a few general tweaks.
Likes For ascherer:
#5842
Quoted: 253 Post(s)
Liked 223 Times
Is it common to run the brake cable behind the handlebars? I usually route them in front. Or like the bar-tape personal preference? Either way, looks gorgeous! How's the brakeing perfomance with those centerpulls? I am contemplating switching from side to centerpull.
#5843
Bikes: a couple
Quoted: 563 Post(s)
Liked 862 Times
[QUOTE=Positron400;22791077 How's the brakeing perfomance with those centerpulls? I am contemplating switching from side to centerpull.[/QUOTE]
I call them u-brakes on a plate, they work phenomenally. The reason they went away wasn't performance, it was weight.
1990 Rockhopper - brakes are incredible
1983 Fuji The brakes will launch you if you really dig in.
#5846
Edumacator
Quoted: 2436 Post(s)
Liked 3,119 Times
And worth their weight in gold!
Likes For jdawginsc:
#5847
Bikes: A bunch of old bikes.
Quoted: 278 Post(s)
Liked 869 Times
I think that might be difficult on that bike. Normally on mixte's with rear centerpull calipers, they are mounted to a bridge on the middle stays. I don't think your bike has that bridge.
Likes For daverup:
#5849
Bikes: a couple
Quoted: 563 Post(s)
Liked 862 Times
These are not unattractive
https://allstarperformance.com/body-...10pk-all18840/
#5850
Quoted: 938 Post(s)
Liked 2,939 Times
I’m not preferential about it, but look around and you’ll see many examples of cabling behind the bars on bikes of the era. The cable housing needs to come straight down just a few cm from the head tube to meet the cable hanger for center pulls. Some stems were drilled for the housing to pass through. This frame requires long reach brakes and these work just fine. I have 3 other bikes with MAFAC center pulls and so far I always stop! That said I believe modern dual pivot side pulls have much greater stopping power. My wife’s Motobecane Grant Jubilé mixte had the same Weinmann long reach brakes and they required a lot of effort, even with new cables. I replaced them with Tektro dual pivots and braking is easier.
Likes For ascherer:
