Hints and tricks thread
#176
headtube.
You've levered a stubborn tire on the rim and are about to inflate it when you notice the tube is misaligned so the valve stem is canted over at an angle -- and grabbing and pulling on the tire doesn't seem to help.
Put the wheel back on the bike completely deflated, spin it up by hand as fast as you can in the direction the valve is pointed, then grab the brakes so the wheel stops suddenly. Repeat a few times and the valve will be aligned.
#177
Old fart
Quoted: 3571 Post(s)
Liked 3,367 Times
#178
thanks Karl Von Draise
dont throw anthing away before you know you can get are placement
#179
Bikes: lowracer, highracer, moving bottom bracket, 2 tall bikesl
i dont tell the wife this, but as most of what i use is from the scrapyard, i chuck all bits i can fit, in the dishwasher!
#180
To cut brake and der. cables:
Use a Hammer and a sharp chisel. Lay the cable on another hammer/piece of hard metal. etc. Hold chisel where you want it cut and ...wackkkk with the hammer. This actually cuts the cable very well!
#181
I do most of my cable cutting with the cable in the housing on the bike. Can I use the frame as a back stop for the chisel?
#182
Bikes: GT, Rockhopper & Orbit Silver Medal (brit)
Regarding using the frame as a back stop when cable cutting with a hammer and chisel, I once drilled an extra hole in a mudguard (fender?) with everything in situ and put the bloody drill straight through the tyre. Such stupidity isn't within the grasp of everybody.
#184
double duty
That splined BB remover can be held in place with the threaded driver from your chain tool.
Check thread compatibility first, wont work with short chaindriver / axle combos.
It doesnt grab deep but a couple of turns is all you need to hold it on and allow purchase on those stubborn (particularly drive side) fixed cups.
#185
#187
Pleasurable Pain
Bikes: Voodoo Rada, KHS Alite 4000, Smith & Wesson Tactical, Diamondback Response
Use your fingers to get nuts and bolts started, then use the wrench to tighten. Works every time.
#188
Bikes: Bianchis, Litespeed
Try Lemon (or any of the other flavors) Pledge sprayed on a cleanish rag for a quik bike cleanup. It will clean as it protects.
I also use it on my fishing rods several times a year.
#189
Bikes: 1995 Cannondale R500 2010 Specialized Tarmac Comp
My trunk rack (for three bikes) doubles as a repair stand
#190
#191
A little trick that I found handy when fix'n friends' bikes that required tools that I didn't need for my family's bikes was to buy them- not from my LBS - but from one of those faceless corporate uber stores w/ a no-questions-asked return policy. That way, when I'm done with the tool, I just return it for my $ back or trade it for an other tool that I need for an other freind's bike.
#192
Large Member
Seems awfully wasteful when you could just purchase the tool once and add to your collection and not have to run around scamming retail stores to save a few bucks.
#194
Scamming retail stores to save a few bucks. Quite sad, really, although I imagine the morality issue is of no concern to someone mean enough to "peel a fart", as my grandfather used to say.
#195
Bikes: Iron Monkey: a junkyard steel 26" slick-tired city bike. Grey Fox: A Trek 7x00 frame, painted, with everything built, from spokes up. Jet Jaguar: A 92 Cannondale R900 frame, powder coated matte black with red and aluminum highlights.
I have a strong suspicion that such tools are not reinspected, given the quality of the products in the first place.
#196
Bikes: Pinarello Road, Surly LHT, Dolan Track, Fuji Supreme, Guru Ti Tri, Bamboo
Quoted: 7 Post(s)
When trying to pinpoint noise when the bike is on a repair stand, I'll use the empty spool from a roll of paper towels. I'll hold it up to my ear and point the other end to the part on the bike where I think the noise is coming from. It really does help, though it seems pretty stupid after typing it up here.
#197
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
I wonder could it be adapted somehow for those only-when-riding noises? Maybe tape it to the end of a bearing stethoscope? Hmm. Now that I think about it, my bearing stethoscope has a diaphragm above the probe that is just about the same size as a paper towel tube.
Dibs on the patent!
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
#198
Dibs on the paAWWW.
#199
I have concerted several vertical drop out bikes very successfully to ss---be a tiny bit flexible with your ratio AND buy the magical half link !!
#200
ONE OF THE MOST IMPORTANT TECHNIQUES
Youtube has "how to" videos on almost every aspect of bicycle mechanics. Great resource!
Respectfully
Jack
Respectfully
Jack
