How common is 300w for an hour?
#176
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
OMG yes, this. This is the part that seems to completely allude a ton of people. I always find when I delve down into their thinking by asking "why" until they get mad that I find out that it's because power to them is a measuring stick and they use an FTP metric as a score for their life. I have always argued that outside of a few applications power solely exists as a tool for personal training. It becomes troublesome when it's used as a genital measuring device.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Likes For Psimet2001:
#177
Quoted: 8271 Post(s)
Liked 9,021 Times
Likes For big john:
#178
Quoted: 842 Post(s)
Liked 469 Times
Last 2-3 years I've fudged my FTP based on what I can do mainly in z3 and z4. 45 minutes is the longest I've had to hold a break neck pace; going an hour all out is hard. Unless its a TT, going all out for an hour probably means you're going to lose (or your competition sucks). I also know my zone settings are different compared to others; my lower zones (z1-z4) are better and my higher zones (z5-z7) are terrible; I both don't have much power over FTP and can't hold it as long. The Zone thing is not linear like it shows in the software like WKO, etc. My Zone 6 is probably 20% worse than other racers but I can hold threshold longer. A solid TT'er profile (I'd rather not have).
I've tried about 4 times outdoors to do a legit hour TT, each time something has went wrong. Sometimes its as simple as a car cutting you off, having to hit the brakes, and that lapse just kills it. On top of that, its just really hard mentally to go all out that long when nothing is on the line. Occasionally I'll do an all out 20 minute test because I want to break 300w (I've gotten close) and I'm really curious to see how I'll do after doing a year solid of base and tempo work only.
#179
Quoted: 590 Post(s)
Liked 445 Times
My 25mi TT I did on my own I recorded 252 AP (3.5w/kg). Good for 25.5mph. I've done a 10mi at 285w in TT aero (right at 4.0w/kg) for 22ish min.
Indoors I've done 305 up Epic KOM in Zwift at 4.3w/kg for 22min. Hour indoors I've done right at 265 on road bike at 3.6w/kg.
I'm nothing to write home about. Even as a 4/5. But the road race where I crashed, I was in a 3 person sprint for the win and we had 100 yards on the field with 200m to go. I'm not that bright of a racer either. So, if I can be in that position, you probably could also.
IMO, I just think in general if folks aren't a Cat 3 or faster or about to be a Cat 3 due to their points and power..........you don't have the aerobic engine or need for it to make nearly 300w for a whole hour.
I would love to since I do TT and regional TT's is a 25mi event. That's between 50 and 65min for most folks. So, I've tried to focus on that more (and my 1min thru 3min power has stagnated due to neglect).
Though never a racer, I still have a racer's chase-the-rabbit and close-the-gap mentality, so I continue to lurk in this forum just to feel that spark again from others.
Likes For Riveting:
#181
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times
I'm hoping to get a shot at a proper hour long effort on a 60ish minute climb in the mountains next month. I'm really looking forward (er...well, besides the suffering) to seeing what I could actually do for an hour a bloc.
Likes For rubiksoval:
#182
Bikes: 1979 Raleigh Team 753
Quoted: 3374 Post(s)
Liked 371 Times
No, it doesn't. Age and fitness really have nothing to do with it.
The whole 20 minute test was NEVER about 20 minutes anyway; it was about a 5 minute blow out effort and THEN 20 minutes max and THEN using the .95 multiplier which provided an estimate that may or may not be particularly relevant to any particular person.
The 20 minute test needs to go far, far away. It really has little to do with anything other than what you can do for 20 minutes.
The poster known as Fuggly did 373W in a 21 min Kings Via Huddart V.2 | Strava Ride Segment in Woodside, CA and 367W (pos 31) for an hour in segment Palomar Mt South Grade (Taco shop to Summit Stop Sign) | Strava Ride Segment in Pauma Valley, California. I expect he had the same PM and bike as these were near the same date. To me, that is not far off. I expect he was going as hard as he budgeted at the time.
My kid typically does not use a PM when he want's to go real hard. Junior in pos 5 the segment above with the three guys ahead of him with PMs all held 400W+ for shy of an hour. Cookie guy is the same reported weight. Junior has a calculated FTP of 260W. So I don't really give all that much credit to calculations.
#183
Liked 371 Times
Opinion:
"While a top amateur rider might be able to hold 400W for the same length of time, they wouldn’t be doing so in the first 11km of a 250km race. If they did, they wouldn’t make it to the end, as they’d be past their limit."
"Troia averaged 302W (4.19 W/kg) for the first hour of racing"
Just how good are male pro road cyclists? - CyclingTips
#184
Quoted: 1851 Post(s)
Liked 678 Times
I've done a 90-min climb. I don't recall what my power was on that day. Regardless, I've never found climbing to be a great test for power though, largely because I rarely have the proper gearing so I'm grinding along at 50-60 rpm. Also, I do not like climbing. I'm quite bad at it.
Likes For topflightpro:
#185
Quoted: 4230 Post(s)
Liked 2,947 Times
I can push harder on flats than I can for the same length of time on a climb. Something about how speed is a positive feedback loop for me. I see myself going fast and feel like the hurt is doing something and that motivates me to go faster. On a long climb, I go slowly, feel like I'm not going anywhere and don't get that same push to keep putting out more power.
#186
Quoted: 942 Post(s)
Liked 526 Times
I don't know what all the apprehension is about going all out for an hour. (not talking about you guys), but I always hear people saying "not very many people can hold their FTP for an hour". It's like they are afraid of reality....then quote Coggins about how FTP can be anywhere between 35 min to 90 min. Naturally they justify their 20 min power and make themselves feel better by thinking they are in the 35 min category. None of them have been tested in lab conditions....then the discussions shift into how you can make accurate FTP assessments by looking at certain points in your power curve.
Re: People who's indoor power is higher than outdoor power.....I think being on a stationary trainer has a lot to do with this. Specifically the artificial leverage you get when hammering.
#187
Newbie racer
Bikes: Propel, red is faster
Quoted: 1575 Post(s)
Liked 1,569 Times
If you're wanting a good performance, you'll need to both do preparatory workouts in the weeks leading up to an hour effort, take time off to accumulate some form, do the effort, then take a day/days to recover from said effort.
For more time crunched folks that's a big time expenditure. I'd argue the person is better off doing whatever they can to build fitness constantly, instead of preparing for constant tests and doing tests. Just adjust workouts as needed based on looking at said workout results (or mid workout).
Just IMO. If you've got 20 hrs a week, by all means go for it.
But if I'm going for an hour it better be worth it.
#188
out walking the earth
re: leverage - I don't find that to be the case. It's the ability to hold steady without concern for cars, lights, turns, downhills etc.
Likes For gsteinb:
#189
Liked 2,947 Times
And the fact that there's no coasting. Even in what I thought were long, consistent efforts outside, I only realized how many microbreaks I took (even unintentionally) until I went inside and all those disappeared (rollers so power output needs to always be there).
Likes For himespau:
#191
Liked 678 Times
My old Garmin just recorded time until I stopped it. So, if I got on the trainer for 90 min, it recorded 90 min. My PC8 auto starts/stops and only records time when it is receiving data - power, cadence, distance... I was pretty shocked at first at how much time I would spend coasting or resting when on the trainer. It was not uncommon for the PC8 to only record 65-70 min of a 90-min trainer session. Even yesterday, Strava shows I was on the bike for about 80 min. My PC8 shows 67 min of effort. To be fair though, I did take two work calls during my workout, and I generally stop pedaling when on the phone.
#192
Liked 9,021 Times
#193
I eat carbide.
Liked 1,306 Times
Old coaches would constantly be like, "you aren't pedaling most of the time - look at your (can't remember the metric...like vi or some such) . Your power profile histogram for the ride is like a half pipe...it should be like a bell curve."
So yeah... I get it. I coast a crap ton. I never can on a trainer though so I think that's part of why it is so mind numbing to me. I thought games like zwift would increase the momentary coasting effect like in the real world but they don't. I feel ya.
#194
no cat contains
Quoted: 57 Post(s)
Liked 142 Times
I'm sure I've heard people say that back in the good old days, a mark of a solid racer was the ability to do 40km in 60 minutes of less on a road bike. Has anyone else heard that? Might be a fun 2021 challenge...
#195
Yes.
I know it isn't a popular opinion amongst the TT geeks, but I think it would be a better sport if they did away with TT bikes. A hell of a lot more folks would do TTs I'd think.
#196
Version 7.0
Bikes: Too Many
Quoted: 1340 Post(s)
Liked 2,482 Times
Most riders interested in racing know that several time trials offer a Merckx division to ride ones road bike. At the Fiesta time trials, they have a Merckx division and then a conforming Merckx division where one rides a road bike similar to Merckx. Not many sign up for riding their road bike. We may get a couple out of a hundred entries.
Generally, racers, who ride the aero bikes, often ride a second time trial on their road bikes. In the Beat the Clock time trials in NorCal, they had a Merckx division and teams. I would do a 20K ITT aero and then a 20K TTT.
We had an evening time trial on the same course as Beat the Clock and racers showed up and raced whatever they had but mostly aero bikes.
Upshot...not much uptake for riding the road bike in a TT unless one is a trained time trialist. Hell, we could offer ebike time trials and once the ebike’s power was tapped out and the racer had to put in full human power for 20 Km, no one would show up.
Timed events are just too hard and demanding for most racers or they just do not want to put in the training necessary. So be it.
#197
Showing up for an under registered second thought division isn't the same. I do mercx TTs. Northeast stage racing basically died, in no small part due to needing a TT bike. They started doing sway with TT bikes at some of those stage races.
#198
Version 7.0
Bikes: Too Many
Liked 2,482 Times
When I moved to San Diego in 1979, I did a 10 mile time trial promoted by the San Diego Wheelmen. It was a flat time trial with a turnaround and all we had were road bike . I missed DFL by beating a junior. I coughed for a couple of days afterward. Who is going to take that deal? We had a guy that did 21 minutes on his road bike. We had 13 entries and that was a good turnout.
#199
Newbie racer
Liked 1,569 Times
But at the level of not even wanting to attempt it due to not having a TT bike, you're a $25 set of clip ons from being over 85% the way to the aero gains of a TT bike. So every time I hear somebody local to me say that stuff I tell them they can borrow my old clip ons for FREE for however long they need.
I could argue that people owning $400 Scotty Cameron putters and $500 bazooka golf drivers keep me from playing golf too.
Each sport chooses the tech limits they see fit. With road bikes and TT we've already seen in road racing mass start at least the ban on the IAB. That came out of trying to make the road bike faster with what you've got. Same thing Merckx riders would do in a TT. My argument there is the clip ons and TT bike are safer than some stuff folks may try on a road bike to go faster.
If you make it so everybody has to as a rule ride the road bike on the darn hoods the same exact way............why even have a contest? Just have a trainer contest on gross power output at that point. You've gotta allow some ways for competitors to differentiate themselves in a contest that is a solo race against a clock.
#200
Cool. I disagree. Like I said, TT geeks will always argue it. But the idea that you're the only hard men who want to go hard alone is silly and self important. I can roll out (and have) and podium the non aero bike class (often win) but the strongest guys are riding 10K TTs bikes in another class. Like I said, it all but killed northeast stage racing, and they started disallowing TT bikes in the the time trials.
