Wooden rims?
#101
Grupetto Bob
Bikes: Bikey McBike Face
Liked 6,633 Times
Likes For rsbob:
#102
I don't know, you've stirred the pot. I doubt you seriously believed people would accept your discovery of a superior new wheel material w/o some push back. I still think you could build an eye catching coffee shop ride.
#103
Liked 8,313 Times
#104
Klaatu..Verata..Necktie?
Liked 13,226 Times
Trying them tells you nothing. Confirmation bias is a real thing. People used to believe that aluminum bike frames rode more harshly than steel and titanium frames. But tests showed that, e.g., a 1997 Cannondale aluminum racing frame differed from a Litespeed titanium racing frame in vertical compliance under a representative load by 0.018" - a difference that would obviously be imperceptible through the suspension provided by any bike tire.
Instead of "trying them," measure them. See the first of my links in the post you quoted for a simple test rig that would demonstrate the difference in vertical compliance between a built wheel with a wood rim and a similar wheel built with any other rim material. Once you've purchased the wood rims and built the wheels, please measure the vertical compliance and report back.
#105
Just as I'm leery of claims of magical metals that ride like a cloud, I'm leery of claims like this, owning both a mid-90s Cannondale and a mid 90s Litespeed. "Humans can't tell the difference" assumes facts not in evidence. Not being able to disprove the null hypothesis doesn't make the null hypothesis true.
#106
Liked 13,226 Times
If the geometries (and the wheelbases in particular), tires, bars, stems, and seat posts of your two bikes are identical (or at least have the same dimensions), I'm at a loss to guess where the differences could be. (I mean with respect to vertical compliance; I'd expect the bikes to differ markedly in torsional stiffness, which would, of course, affect the way they feel to ride.)
Another interesting, but thoroughly irrelevant difference - a sharp strike to the tubes of the Cannondale makes a *thunk", but the Litespeed rings like a bell! It's why I call it "Pinball Wizard", or "Wizard" for short. The Cannondale is "Jackhammer".
#107
#108
Well, you're off the hook then, because I don't need you to explain it. Observations can exist without explanation. Reality does not require that I understand or explain it. I simply observe that when I'm riding the Cannondale I find myself constantly seeking the smoothest part of the bikelane, and on the Litespeed, I don't.
And not trying to explain why your bikes ride the way they do for you. Just thinking about it for my own satisfaction. If the Cannonale is a Crit Series bikes, with that track bike-like wheelbase, I wouldn't be surprised that you seek smooth pavement. My mid-'80's SL/SP Bianchi Specialissima, with pretty much the same geometry as the Crit Series Cannondales, was quite a jackhammer, too.
#109
climber has-been
Liked 4,085 Times
Old wooden rim anecdote: Want to know who used to ride on wooden rims? The infamous Jobst Brandt, author of the Bicycle Wheel, cantankerous engineer, and "guy who knows more than you do" about all things bicycle. He used to vacation by bicycle in Switzerland every summer, and being a big guy who liked to descend big mountain passes with crummy roads, he would heat up his aluminum rims and blow out his tires. These were the days when you pumped your tubulars to stupid high pressure, because "a hard tire is a fast tire".
Being an engineer, Jobst knew that aluminum was a great heat conductor, and he figured the rims were passing the braking heat into the tires, so the solution was to insulate the tires from the heat. Enter wooden rims, with their low conductivity. Some time in the 1960s, Jobst asked my dad to build up a set of wheels with wooden rims, which did help prevent tire blowouts, but the braking was crummy. I think those were the only two wooden rims our shop had ever built up, before or since.
Many years later, we still had one wooden rim in the shop, which by then had been relegated to stretching tubular tires before being mounted on a wheel.
Likes For terrymorse:
#110
Liked 13,226 Times
Yep. That "thunk" explains why aluminum isn't used for bells, as a rule. It damps vibration too effectively.
Cannondale:
HTA: 73
STA: 73.1
WB: 98.1cm
Litespeed
HTA: 73
STA: 73
WB: 99.1
Likes For genejockey:
#111
The Wheezing Geezer
Bikes: 1976 Fredo Speciale, Rivendell Clem Smith Jr., Libertas mixte
Liked 1,146 Times
The only wooden rims that I have seen were on a stayer bike - a specialized track bike made for moto-paced track racing. It had a smaller front wheel, with a backwards-curved fork, almost like a caster. It seemed like it was built in the '60s, maybe? Hanging up in a bike shop in Tucson, and somehow connected to Wally Summers, who went to Montreal in '74 and '76.
I have a pair of wheels with Scheeren Weltmeister tubular rims, constructed with wood blocks at each spoke hole to distribute stress, allowing their 8 oz. rims to be stronger than competitors 11 oz. rims. They are lighter than my carbon wheels, which I have never ridden, btw.
Beneath the valley of the underbikers.
#112
Liked 4,339 Times
#113
Liked 13,226 Times
Yeah, 400g would be quite light for an aluminum rim. The fact that wooden rims weigh about the same as aluminum rims is not surprising. The strength-to-weight ratios are similar.
So wouldn't you be trading the risk of blowing tires for the risk of your rims catching fire?
#114
Liked 13,226 Times
Turns out the flared part of the handle on my Zefal HPx frame pump was striking the bottom or the top tube. I put a little piece of foam in between and no more *PING!!*
#115
climber has-been
Liked 4,085 Times
Get to the bottom of a long descent, your brake pads are done, and you have burns on your legs.
#116
Liked 4,339 Times
The primary reason for the demise of wood rims years ago was caliper brakes. Where aluminum (except for the sidewall wear factor) rules supreme. Now that we have disc, wood will work just fine except we've given up on the tires that work so well with it - tubulars.
Likes For 79pmooney:
#117
When I first rode my Litespeed, every so often when hitting a sharp bump, the damn thing would just go *PING!!!* At first I thought it was stone strikes, but then I quickly realized it was happening at the same place on every ride. I still didn't know what was causing it. Then they dug a trench down one of my favorite short dropoffs, right down the bike lane, and patched it really badly.*PING! P-P-PING! P-PING!* for about 20 seconds. THAT was when I named the bike "Pinball Wizard".
Likes For Trakhak:
#118
Liked 8,313 Times
Hmmm. Seems to me - not an engineer! - that the amount of heat created by the friction required to brake would be the same no matter what the rim. Aluminum being conductive, the whole rim would act like a big heat sink, whereas wood being a poor conductor of heat would keep it all right at the pad/rim interface.
Likes For tomato coupe:
#119
I've seen folks on HGTV take a torch to wood siding to achieve a certain look. OP could try that. OG Carbon
#120
The placebo effect must be considered in the context of a titanium bicycle's smooth ride as it refers to the psychological benefit a rider might experience simply because they believe that riding a titanium bike should provide a smoother experience. If a cyclist is convinced that titanium offers superior ride quality, they may subjectively feel a smoother ride, even if the actual physical difference compared to other high-quality materials is non-existent. This perceived improvement due to belief and expectation is a form of the placebo effect.
#122
Indeed. I guess I'm not harboring any frame material prejudice, because the bike I enjoy riding the most is a fixed-gear Specialized Langster with oversized aluminum tubing throughout, including the frame and the straight-legged fork.
Sixty years of riding high-end bikes, and I still don't really understand what people mean when they say that a bike built with one frame material is more comfortable than a similar bike built with another frame material. Unless the bikes also have different wheelbases.
#123
Balsa, please let it be balsa...
#124
Liked 13,226 Times
I long ago gave up on assuming I knew what others could perceive. How could I possibly know?
#125
Ti frames are great in many ways. Wouldn't mind owning one, I guess. But I suspect I'd still prefer my aluminum frame/aluminum fork Specialized Langster fixed-gear bike. Just came back from 3 1/2 hours in the hills of Baltimore County on the Langster. Again, I don't know what "comfort" means in the context of road bikes, but I get a lot of pleasure out of riding that bike.
This topic reminds me of another: the claim that the layup of the fabric in carbon forks is configured to absorb shock. Seems possible, but I'd guess that the main design objective is to provide adequate strength with minimal weight. Not sure how much wiggle room in the design there is for making them more shock-absorptive as well.
Back in the '80's, a teammate damaged his steel fork in a race and got a replacement carbon fork, one of the first I'd seen. I asked him how the new fork felt. "The same," he said.
Now, four of my six bikes in active rotation have carbon forks. How do they feel compared to the steel and aluminum forks on the other two? The same.
