powder coating seat post
Quoted: 722 Post(s)
Liked 353 Times
Debating having bike powder coated.
frame, forks, seat post
will the seatpost still fit in frame?
anyone know if it is an issue.
Quoted: 1074 Post(s)
Liked 295 Times
Is your seatpost a snug fit today?
If yes, then it is likely to be unbearably snug after PC.
Of course there’s nothing stopping you from guesstimating the fit and either sand down the post a little or hone/ream out the seat tube a bit to compensate.
Also, while PC is tough, it isn’t that tough. If you actually plan to use the adjustability, it will scuff and scrape.
And there is the clamp too.
Quoted: 713 Post(s)
Liked 796 Times
It's a bad idea. Powder coating is fairly thick and will probably be thick enough to prevent the post from even fitting in the frame. If you could get it to fit, you would need to make sure you know exactly how far to insert it, because it will be scratched from being inserted in the frame. I have built several frames for friend who loves to color match everything to the frame. He always asks me to powder coat the seat post and I always tell him "No".
Old fart
Quoted: 3582 Post(s)
Liked 3,394 Times
Have your powdercoater put a plug in the top of the seat tube before coating.
SE Wis
Quoted: 2740 Post(s)
Liked 3,386 Times
Can they mask to the known insertion point? Can you "guesstimate" thickness and use a smaller post that will fit after coating?
Quoted: 2026 Post(s)
Liked 1,095 Times
That's about the only thing that's practical and assumes you won't change the saddle height in the future. Otherwise the coating will make the seatpost an excessively (or impossibly) tight fit and will be scratched and peeled off if you insist on forcing the post in.
Friendship is Magic
Bikes: old ones
Quoted: 26382 Post(s)
Liked 10,360 Times
...powdercoat on a seat post is just an exceptionally bad idea. It's right up there with "Here, hold my beer."
Likes For 3alarmer:
Quoted: 6177 Post(s)
Liked 4,794 Times
Aluminum? If you have some friends in the metal fabrication business, ask if they know of a local or nearby plater. They usually do anodizing and you can get it anodized in black, blue, yellow, green or red. Maybe some other colors.
Might be if the owner likes the way you BS with him, he'll toss it in with something else that is being done and not charge much if anything.
Might be easier just to buy one the color you want.
Liked 1,095 Times
Liked 4,794 Times
Well of course they do.
https://www.google.com/search?q=colo...w=1010&bih=920
No recommendations though....
Or are bikes only black or silver in your ideal world?? <grin>
Quoted: 4195 Post(s)
Liked 3,837 Times
Not asked but a valid comparison are quill stems, specifically custom made ones. The, pretty much now unavailable, stem kits has quills (the part that inserts into the steerer) that were ground a tad less then their starting 22.2mm diameters to both slide fit in 1" steerers and to allow for the paint thickness. Now the difference was that the quill had the job of tightening inside the steerer (with the wedge) and a usual seat post will get clamped by the seat tube and it's clamp. There's enough scratched and marred posts with even "correct" fitting to think that the added PC (which is especially thick a coating compared to a nice wet paint coating) won't get scuffed and scratched. Now what would be interesting is to see if a post that was one "size" smaller and was PC'd enough (might take more then one application) could fit AND also be able to be tightened AND stay that way after real use. Still I would expect cosmetics to suffer. Andy
AndrewRStewart
AndrewRStewart
Liked 2,943 Times
for seat posts; zinc nickel plate steel or electroplate aluminum. Apply a lithium grease for aluminum to aluminum, nickel grease for steel to steel, PTFE-based paste [teflon] for aluminum to steel.
-Oh Hey!
-Oh Hey!
Quoted: 2597 Post(s)
Liked 1,923 Times
Quoted: 722 Post(s)
Liked 353 Times
I guess i wont have the coolest matching frame and components bike in town.
thanks.....
thanks.....
