WTB uniglide cassette 13-32
Quoted: 2337 Post(s)
Liked 2,820 Times
hen's teeth time
thanks all
thanks all
tantum vehi
Quoted: 1167 Post(s)
Liked 992 Times
how many sprockets?
1970 Gitane TdF; 1973 Gitane TdF
1979 Trek 710; 1981 Trek 412; 1981 Trek 710
1984 Specialized Stumpjumper Sport; 1985 Specialized Allez SE; 1988 Specialized Sirrus; 1989 Specialized Rock Combo
1984 Ross Mt. Hood
1988 Centurion Ironman Expert
1991 Bridgestone RB-1
1992 Serotta Colorado TG
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
Quoted: 5888 Post(s)
Liked 3,471 Times
https://www.ebay.com/itm/264748412791?hash=item3da43c2f77:g80AAOSwM0VeQF9G
That's not a bad price for a 34 tooth uniglide cog. The prices they're asking on eBay for complete uniglide cassettes is insane given that it's not a big deal to convert the hub to hyperglide.
There's some good info here,
https://www.bikeforums.net/bicycle-m...yperglide.html
and here
https://www.sheldonbrown.com/k7.html
and here
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
Agreed. I'd be tempted to purchase a HG cassette with a 32 big cog, break it down and select the ones I wanted to use.
Using a file or a Dremel with a cutoff wheel, widen the one small notch in each chosen HG cog- this takes just a few moments.
Put your new hybrid cassette together using the spacers from your current cassette (or the appropriate sized spacers for the number of cogs you are using): the UG small first cog threads on to the freehub and secures the rest of the HG cogs.
Not difficult, done it many times.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
So while you (squirtdad ) could build a whole cassette out of NOS cogs, I'd agree with the rest that taking apart a modern cassette and using the cogs you need (save for the thread-on 1st cog) would probably be more cost-efficient. Just make sure that the cogs you want to harvest are full cogs and not partials that are riveted onto another one.
Something like this 8-speed 11-32 would be a good candidate: https://www.ebay.com/itm/33359850800...cAAOSwYIxX24je
But not this HG200-7 12-32: https://www.ebay.com/itm/12478807732...AAAOSwF~9g13wI
RUSA #7498
Liked 2,820 Times
Liked 2,820 Times
and here
and here
tantum vehi
Liked 992 Times
Sunrace makes 8s cassettes and I don’t think any of them have spiders, they’re all full sprockets. I’ve done this too.
1984 Ross Mt. Hood
2015 Elephant NFE
1984 Ross Mt. Hood
2015 Elephant NFE
aka: Dr. Cannondale
Liked 3,402 Times
OK, checked my remaining UG cog stash and this is what I have:
1st threaded cog: 13, 14,15
Non-threaded cogs, can be used in any position: 14,15,17,19,20,21,23,24.
So for 6 speed, you could do something like 13-15 -17- 20-24 and then a big jump to your 32.
All these cogs are NOS, some have the shiny upscale finish others the lower end black oxide finish.
Likely, but cannot guarantee, that I have the correct 6 speed spacers on hand.
If any of this sounds like what you need, shoot me an e-mail at rccardr@cox.net
Recovering Bikeaholic
aka: Dr. Cannondale
Liked 3,402 Times
If I recall the OP's setup correctly, it's 6 or 7 speed UG Dura Ace.
DA 740X freehubs have a unique hub mounting system unlike any other Shimano freehub and also require a special tool.
Converting the freehub to HG/UG would mean using a 7403 8 speed unit- super expensive, 130 OLD, very hard to find- and the special tool- super expensive, hard to find.
Likes For rccardr:
Liked 2,568 Times
Klaatu..Verata..Necktie?
Quoted: 10416 Post(s)
Liked 11,876 Times
Oh, hey - are your wheels Dura Ace EX? Because that requires a Dura Ace threaded smallest cog. And does your RD have the capacity for a 32t cog? I'm currently running 6sp Dura Ace EX on my Lotus Supreme, with a 13-26 600 cassette, but I had to remove the bolts that hold the 5 unthreaded cogs together AND use the 13t Dura Ace threaded cog from the rust-encrusted 13-23 I got it with.
Liked 11,876 Times
Ther is a tool to remove the freehub. I've seen them on Ebay for $60-ish. I don't know that I've seen a 6-speed Hyperglide freehub, though.
Liked 2,568 Times
6 and 7 speed freehub bodies are usually the same width. If the OP can disassemble his freehub and replace the outer shell in the way I'm thinking, he could run 7-speed cassettes on his wheel with no need for a $60 tool to completely detach the freehub body from the hub.
aka: Dr. Cannondale
Liked 3,402 Times
The ‘outer shell’ of DA 740X and any HG Shimano freehub are not interchangeable.
Shimano never made a 740X compatible HG freehub in 6 or 7 speed width.
To the best of my knowledge, the only way to get DA 740X HG compatible is to use a 7403 freehub.
This would necessitate locating the special tool (note fairly accurate pricing above), moving to 130OLD, and locating a 7403 freehub. The last 7403 freehub I sold went for $80.
Far less expensive to adapt HG cogs to the UG spline pattern (takes literally minutes) and use the existing UG small cog to secure them to a perfectly good freehub.
Liked 2,568 Times
Thanks for the clarification, rccardr !
