9 speed DA 7700 cluster on DA 7402 8 speed cassette?
Old 08-02-21, 09:59 AM
tendency
Quoted: 236 Post(s)
Liked 171 Times in 104 Posts
I've got a DA 7402 130mm rear hub with 8 speed cassette freehub. Does anyone know if a stock 9 speed DA 7700 cluster will fit? Guessing not but hoping Shimano tightened the spacing on the 7700 and it may be compatible.
tendency is offline
Old 08-02-21, 10:05 AM
alcjphil
alcjphil's Avatar
Quoted: 1815 Post(s)
Liked 1,693 Times in 974 Posts
No, it won't fit. The overall width of Shimano 8 and 9 speed cassettes are the same, but Dura Ace 8 speed freehubs use a different spline pattern.
alcjphil is offline
Likes For alcjphil:
Old 08-02-21, 10:23 AM
tendency
Quoted: 236 Post(s)
ah crap forgot about the changing spline pattern.
so that begs the question: can i swap the freehub between 7700 and 7402 hubs?
tendency is offline
Old 08-02-21, 10:40 AM
masi61
masi61's Avatar
Quoted: 1163 Post(s)
Liked 441 Times in 314 Posts
Not the 7700 freehub body but the transitional “7403” freehub body accepts both the UniGlide threaded outer locking cog or Hyperglide lockring to accept 8, 9 or 10 speed Shimano HG cassettes.
Double check your Dura Ace 7402 to verify what you’ve got… use 2 chain whips and unscrew the outer UG locking cog.
A special splined Shimano tool is needed to actually remove the freehub body (the 7400 series use coarse threaded bolt with sharp threads that you do not apply grease to).
masi61 is online now
Old 08-02-21, 10:46 AM
tendency
Quoted: 236 Post(s)
I'm running a 8 speed HG cassette on it now .. does that mean I must have the 7403 hub?
tendency is offline
Old 08-02-21, 11:15 AM
masi61
masi61's Avatar
Correct! Since you are securing your HG cassette with an HG lockring it appears you have a 7403 hub. The spline pattern is actually the same. So you can run a 9 or 10 speed cassette on there. You might not be able to run an 11 tooth cog though, if that is important to you.
Likes For masi61:
