Carbon Fork Lifespan?
Klaatu..Verata..Necktie?
Quoted: 10397 Post(s)
Liked 11,860 Times
My bike passes every ride. Inspection does nothing to increase the inherent durability of something. F1 cars crash, rocks hit them, and certain structures deal with a little bit of heat. Part of my bmw's structure is carbon fibre and it should outlive me.
I could be wrong but I doubt any commercial aircraft has its fuselage checked for cracks every 100 hours. Not even the new Marine One gets that treatment.
your god hates me
Bikes: 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
Quoted: 1246 Post(s)
Liked 1,273 Times
Quoted: 2333 Post(s)
Liked 2,097 Times
I've only had one serious failure, it was aluminum. I was hurt. Bad. Very bad. I've ridden carbon frames since December of 1985. I can only say it does not scare me.
Likes For GhostRider62:
Quoted: 3943 Post(s)
Liked 7,286 Times
Likes For tomato coupe:
Liked 11,860 Times
Likes For Bob Ross:
Liked 7,286 Times
Quoted: 10236 Post(s)
Liked 5,181 Times
Not accurate.
Part 91 aircraft used for hire require a 100 hour inspection. Example: cessna 172 used for flight instruction. I can assure you that the mechanic is not checking for micro cracks on every square inch of the airframe.
Airlines go by cycles. Every part has to be inspected at a certain amount of cycles, and each part has a different cycle requirement, and it varies for each airframe.
Likes For bampilot06:
Quoted: 338 Post(s)
Liked 408 Times
Which is good news, it won't just "fail riding along".
Quoted: 2479 Post(s)
Liked 2,948 Times
Where did you read that? Haven't come across that sort of claim for many years, and never about carbon fiber. Perhaps it's an updating of the bike racer folk wisdom that steel frames become softer with accumulated mileage. (They don't.)
Resident PIA
Bikes: Gunnar Roadie, Look 765 Optimum, Spesh Aethos
Quoted: 211 Post(s)
Liked 355 Times
What should I replace my 18 year old cf fork with?
Shad
I knew where I was when I wrote this
I don't know where I am now...
05 Gunnar Roadie Chorus/Record
67'er
Shad
67'er
Should Be More Popular
Quoted: 22579 Post(s)
Liked 8,919 Times
Likes For datlas:
Quoted: 4387 Post(s)
Liked 4,828 Times
IME of using CF in motorsport, any failure is far more likely to be due to impact damage, inappropriate loading or some kind of design/production issue.
Likes For PeteHski:
Quoted: 338 Post(s)
Liked 408 Times
https://www.academia.edu/30520244/Fa..._Bicycle_Forks
https://www.ncbi.nlm.nih.gov/pmc/art...9/#!po=24.5763
And so on and on.
Quoted: 6944 Post(s)
Liked 10,944 Times
And so on and on.
And so on and on.
So, they started with cf forks that were defective, and measured their responses to stress cycles. Does not seem relevant.
The second paper is not about bike forks specifically and includes much terminology that is unfamiliar to me -- so I don't know whether it's relevant.
Likes For Koyote:
Quoted: 4225 Post(s)
Liked 2,945 Times
More importantly, have the baby bolts showed up yet? Are they still missing?
Quoted: 338 Post(s)
Liked 408 Times
Well, some forks in the first paper lasted for a lot of cycles and some didn't, depending on the kind of manufacturing defect (which, you know, are present on most forks, it's just a question of how many and how significant, and they hugely impact fatigue life), which all exhibited a gradual loss of stiffness before fatigue failure, as you would expect.
The other is just about generic fatigue modelling of composites. The earliest reference on residual stiffness dates from 1975. It is not exactly news. You can read a heap of the stuff if you like.
Before metal lovers latch on, I've just recently read a paper about fatigue modelling and testing on a steel bicycle frame and it of course died to fatigue, and depending on pedalling forces and their angle, in significantly less cycles than a quality made CF fork would.
If you ride lots and lots of miles for many years, one day you will have to replace your bike. I wouldn't have thought that this would be so controversial.
Likes For Branko D:
Liked 8,919 Times
Liked 11,860 Times
Bikes: '23 Poseidon Redwood, '07 Specialized Roubaix Comp Triple, '12 Gravity Fixie, '21 Liv Rove 4, '06? Giant EB Spirit
Quoted: 345 Post(s)
Liked 237 Times
Try to destroy a carbon fork
You may be shocked at how strong the thing is. I did this to a fork after an accident. Banging with a sledgehammer left only a scratch. Trying to compress the legs in a vice (got scary after reducing span by 1/2 with no cracking sounds - released and was fine). Cut with a hacksaw and even with a 1/3 cross section cut I couldn’t beak it apart by bending on my knee. I believe carbon forks are ridiculously strong (at least those that pass testing requirements). I have no worries about a carbon fork disintegrating or weakening over time from normal use. With normal use it should last a lifetime or three
Liked 10,944 Times
In the middle of the pandemic, as we were driving home one day, I was telling my wife about the bike supply chain problems. As we pulled into the garage, I waved a hand at my five bikes, and said, "I'm pretty smart to have stocked up, aren't I?" Her agreement was a bit less than wholehearted.
Liked 2,945 Times
Likes For himespau:
Professional Fuss-Budget
If a bike manufacturer told you that you had to replace their frame every 5 years, do you think those frames would sell well...?
Likes For Bacciagalupe:
Liked 8,919 Times
I don't see these as comparable. Helmets aren't load-bearing items; are intentionally designed to be replaced; and aren't made with carbon fiber Helmets are consumables, forks are durables.
The helmet analogy is not perfect, and belongs in a different thread, but clearly a helmet that has been cared for and not crashed does not need to be replaced either.
Likes For datlas:
