what is that thingy on the fork
Quoted: 2026 Post(s)
Liked 1,095 Times
Yes, you are. The adjustable wrench is set to butt up against the edges of the crown race from underneath. You tap against the underside of the wrench head to loosen the race. The steerer threading has no effect.
Again, this only works if the race is larger than the fork crown.
Mad bike riding scientist
Quoted: 6200 Post(s)
Liked 4,204 Times
Sorry. Thought you were talking about installing the race.
Stuart Black
Stuart Black
Quoted: 2337 Post(s)
Liked 2,813 Times
I also made my own installation tool. If I ever get to work on some ultra high-end fancy bike maybe I'll get something nicer with this seems to do the trick for now.
As for removals, I looked up a few videos and, again, for the kind of bikes I'm working on a hammer and screwdriver will probably be fine.
are you replacing the entire headset? make sure you measure and the correct replacement size.
as for finding online sheldon or park tools
https://www.sheldonbrown.com/headsets.html
Quoted: 645 Post(s)
Liked 797 Times
How do you get that down around the outside of the steerer to press on the crown race? Unless there's an extra cylinder involved that you're not showing. This apparatus might be used to install the upper and lower head tube cups, but not the crown race. I use a metal tube with a section of PVC pipe pressed onto the "business end", and I sit the fork down onto a section of rounded-off 2x4 spanning a couple of trestles, so the fork legs aren't absorbing the shock. Couple of whacks with a dead blow hammer installed the last crown race. You could also cool the fork in the freezer and drop the race in some boiling water first, to enable a smoother press-fit. I've seen some people heat the race on a gas ring, but I wouldn't put that anywhere near a CF fork.
bike whisperer
Quoted: 1523 Post(s)
Liked 716 Times
Nm, late to the party
Sheldon Brown's bike info ~~~ Park Tools repair help
Half-step triple, using double gear ~~~ 6400 STI rebuild walkthrough ~~~ Want 8/9/10s @126mm OLD? OCR. ~~~ Shimano cassette body overhaul ~~~ Ergopower Escape wear repair ~~~ PSA: drivetrain wear
List of US/Canada bike co-ops ~~~ Global list
