Recommends?
Recommends?
Just looking for advice here. So, after years of talking about it and my encouragement, my wife is now keen to get an electric hybrid. She's 55 and very unfit so electric is an ideal route in. What she wants is something that she can ride with me at home around the rolling north Somerset countryside and in our holiday home in the Pyrenees;not a racing style bike with drops but a flat handle bar hybrid, something we could do some longer distance touring on too possibly.
So, it needs to have enough battery oomph to do a fifty mile round trip over a small mountain pass involving a 14km col of between 4 and 10% gradient each side, and comfortably.
I think this is doable with something like this Cube/Bosch combo (it won't let me post the URL)
Any thoughts would be welcome.
For myself, I'm a fit road cyclist used to cycling in the mountains without power assistance so evening up the difference would work pretty well.
ACCESS HYBRID
Pro 500
Industry guy
Two thoughts:
Try to rent a couple styles. There are any number of designs( rear hub, center drive) in a variety of styles- atb, fat bike, hybrid and even road.
It sounds like your needs are significant. Mountain passes with those grades, I would suggest a center drive unit. Better torque applications,
better weight distribution and generally a better engineered design.
Avoid cheap (Chinese) because it will be more expensive in the long run.
Avoid a front drive unit for control reasons.
Good luck,
rusty
Good luck,
rusty
Quoted: 882 Post(s)
Liked 821 Times
As above, the needs you delineate suggest a mid-drive. No matter what you hear, your wife will be happy with any of the big OEM's (Haibike, Specialized, Trek ......).Look for a big battery (600 wh+).
Bikes: Pedego Interceptor 26", Schwinn Santis with a rear hub direct drive conversion. Cannondale Quick 4.
It might be wise to look for an ebike dealer to rent in Spain with an option to purchase to see if it would handle those requirements before buying one in GB and it not being up to task and beyond any return window.
Thanks
Thanks for the ideas, people. Not much chance of hiring a bike in Spain right now as travel in Europe has mostly stopped. But it's a good idea.
The one I thought would be good is
www dot wiggle dot com forwardslash cube-access-hybrid-pro-500-275-e-bike-2020
which is 500w and a little on the heavy side (22kg) for the price so I might look a bit further
Quoted: 32 Post(s)
Liked 19 Times
My Verve + 2 from Trek is 51 pounds and not powerful enough and not with enough range for your request. That's around $2,500 in the Mid US. Maybe the one step higher Bosch mid drive would do the trick for you. Be Well, Bluesfrog.
