Help for available upgrades
Hi
I`m new ti the bike riding and i have a low budget bike that has some shimano tourney mechanics in specific:
freewheel: Shimano mf-tz500, 6 speed
Shimano sl-rs-35 hand shifter
Shimano rd-ty21 rear shifter
Shimano fd-tz500 front shifter
So i have this issue the hand shifters or the rear spoket shifter does not wanna adjust properly and can`t change good through the gears.
So i want to upgrade my shifters to something cheap but more reliable. And i think my shifters are copies some chinese because reading from the reviews online from the bike company they say that they use low quality parts .
Thanks
Thanks
Quoted: 1572 Post(s)
Liked 643 Times
Before you start throwing money around, try this:
1. Shift your bike into a gear combination that makes the derailleur arm point downward.
2. Prop your bike up against a wall or something and look at the derailleur from the back.
3. If your derailleur arm seems to be pointing at your back tire (my bet on a bike that age) there's your problem. It should be pointing straight down.
The good news is that there's no need for fancy special alignment tools on a bike like yours. Just reach down with your hands and bend the whole derailleur until arm points down.
Quoted: 1815 Post(s)
Liked 1,693 Times
Alright I will try this but wanna upgrade something because it feels just like a bad bike it has 26inch wheels so I`m thinking on buying 26x1.50 tires I`m only riding on road so would be good. Also i have this quick release hub on the rear wheel but it loses it self when riding should i upgrade for different hub
Quoted: 1324 Post(s)
Liked 927 Times
By the time you spend the money on all those upgrades you'll be getting close to the price of a new 7-speed rear cluster, triple chainring bike.
Cheers
Cheers
That is crossing my mind I am also thinking about getting a new bike hybrid or trekking bike i only ride on road pavement so i don`t need fat tires or shocks. Also this one is too small for me im 6 foot 4 so 28inch wheeler looks good to me but i need to gather some money till them i`ll be rocking this one
Liked 643 Times
1. Hold the Quick Release lever straight out so that it's parallel with the axle.
2. Tighten the nut on the other end of the axle until it is just barely finger tight.
3. Now push the QR lever in so that it is perpendicular to the axle. If it isn't hard to do, you didn't do it right.
When you tighten a quick release this way, make sure you position the lever so that you can get a finger under it when it comes time to take the wheel off.
Clark W. Griswold
Quoted: 4335 Post(s)
Liked 3,958 Times
But yeah 6 speed is older tech a little newer than the 70s but not by leaps and bounds.
Me personally I would run any tourney bike into the ground (which shouldn't take long) and save your money for something decent that won't have tourney problems.
Liked 1,693 Times
Dura Ace SIS indexed shifters were mid 1980's tech. I was talking about 1970's tech when 6 speed was state of the art. My 1973 Raleigh Professional had a 6 speed freewheel
