Oops! Maybe broke my headset?
So I had a bike shipped up and mailed to another bike shop, and then reassembled at the other bike shop. I got it out of the shop, started riding off, and suddenly the handlebar is like turning in my hands, but not the wheel. It's barely attached.
So I get it home (like 10 miles away) and sure enough, the handlebars seem to be moving independently of the fork. I see this big inviting nut at the very top of the headset, so I tighten it up, and viola, it feels tightened. So I get on it, and bike a mile or so, and it starts getting sloppy again. It's loose again. Crap.
So I get off, tighten it again, same story. Stays tight for like a mile. So finally I decide to REALLY tighten it. I tighten the crap out of it. As I'm doing it, I hear a loud crack, and suddenly it's loose again. And if I try tightening it again, as soon as I get it moderately tight, it makes the crack sound and loosens again. So I clearly overtightened something and maybe broke something.
After doing a more thorough investigation, I realize it's the frigging stem clamp that was loose, not the star nut. I tighten the clamp, and tighten the star nut as best I can without it snapping loose again, and now it feels fine. The fork is plenty tight.
So my questions are:
A) What did I break?
B) What exactly does that star nut at the top of the headset adjust anyway?
Any verbal thrashing you guys are going to dish out at me for adjusting stuff without having any idea what I was doing, trust me, I've already given it to myself tenfold.
Elitist Troglodyte
Bikes: 03 Raleigh Professional (steel)
Not nearly enough info...
Got pics?
Got pics?
Stupidity got us into this mess - why can't it get us out?
- Will Rogers
- Will Rogers
Cascadian Nationalist
The star nut is just to set the proper tension on the bearings. The stem being clamped down is what actually holds everything in place. So to properly adjust your headset, you would loosen the stem, set tension using the star nut, crank down the stem bolts. All to proper torque blah blah etc. I'd guess the crack was the star nut slipping in the steerer.
Likes For Ashen:
Okay, sorry no pics but I'll try to clarify.
It's a Surly Long Haul Trucker bike. It has a threadless headset. There's a 5mm allen bolt at the top of the headset, it's the adjustment for a threadless headset. I cranked down on it too hard until I heard a snap or crack, and now I can't tighten it much without it making the same snap/crack sound and instantly loosening again. Just wondering what I broke, and what exactly the stupid thing does in the first place.
The top screw is used to preload the headset bearings. The stem is held in place by it's screws. Once they are tight you could take the top cap off. This explains it better. Book-mark this site.
https://www.parktool.com/repair/readhowto.asp?id=65
Gitane Fix(at)ed
Bikes: Nice Gitane Fixed Gear, Cheap and cheerful rigid MTB, Wonky commuter, A fully 105 road bike with a pipe steel frame
Good and complete explanation.
Quoted: 2026 Post(s)
Liked 1,095 Times
My take is that they neglected to tighten the stem clamping bolts when they assembled the bike but, since you noticed it right away, why on earth did you continue to ride it? Count yourself as extraordinarily lucky that you weren't involved in a very serious accident.
Guest
Bikes: I never learned to ride a bike. It is my deepest shame.
Liked 6 Times
I, too, have heard the sickening crack when tightening a headset. In my case it was the headset top-cap cracking. This is fairly easy to do with a plastic top cap - they are strong enough to preload the bearings and no more.
Replacing a top cap should not cost more than $5 or $1 (for a fancy one).
Not to make you feel bad, but you really should have gone back into the shop when the stem slipped the first time - you could have been seriously hurt if the bars slipped at the wrong moment.
Even if you fix the cracked top-cap (i think), adjust the headset, and clamp the stem down yourself you should call the shop and tell them their techs might be a little to sloppy - mistakes like that can cost a person his life.
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
so basically the op tightend tehs hit out of the hS c amp because ;he thought that ti would suecure sthe stem but t obviously didn't. It's the ste m bolt sthat do it. Well gg
probaqbly bultlled the starnut thorught the ****in sterrer
Likes For LarDasse74:
Very likely so, but I have no idea what that means. I don't know the anatomy of a headset too well. All I know if before I effed with it, it was tightening a LOT more than it currently can, because as soon as I get even a half turn it cracks again and loosens. Something's definitely different, so I figured I'd broken something. I don't know what you're referring to when you say something like "it preloads the bearings"
A little more background I guess, I didn't specify because it didn't have anything to do with my question. The handlebar felt fine until I was about 6 miles away from the bike shop. Not precisely that far, but it was obvious I was more than halfway home. I'd been dropped off at the shop, so the bike was my only way home. I was closer to home than the bike shop by the time it was noticeably loose. It wasn't so loose it was spinning in my hands until I was pretty much home, and by the time I'd gotten off and was walking it because it felt REALLY squirrely when I tried getting on it after stopping.
Step ONE when I got back was to call the bike shop and tell them they screwed up the buildup of my bike when it was delivered. They offered to re-do the repair if I brought the bike back in. I couldn't get back there because I had a currently unsafe bike in my hands as my only means to get around. So I told them I'd fix it myself and asked for a refund, and for the mechanic who worked on my bike to get a talking to. The shop owner refunded my money and promised to chew out the mechanic.
Obviously that was a mistake, because I had no idea HOW to fix the bike, but it seemed simple enough at the time. I tightened the top cap, it felt firm, I figured problem solved. Obviously I was wrong. If it makes ya'll feel any better, I DID take a small digger when I took it out the next time, when I tried mounting it the wheel heeled way over while the handlebars stayed in my hands, and I fell off, giving me a pretty clear indicator I'd missed something. Lesson learned.
Anyways, so the current situation is I can't tighten the end cap as much as I could before I overdid it, and I'm getting the impression that if the stem is clamped on tightly now (it is) that it's not a safety issue. If that's the case, I'll just have them see if I snapped something off in there next time I bring it in for a tuneup (to a different shop obviously), which it's due for soon. Thanks for the info, all.
Gitane Fix(at)ed
In any case, you really NEED to pay attention to some issues if you want to enjoy your bike without any problems.
The headset is one of the things you need to be aware of.
As other already said, the top cap is used to set the preload on the headset bearings. Since your stem was not properly fixed, tightening the top cap is a very bad idea since it will put too much pressure on the bearings, and could ruin the headset in some extreme cases. Additionally, the steerer/handlebars will be stiff and you don't need any of that.
I would really recommend to perform a proper adjustment of all this. It's a 5 min operation, you learn some stuff and it may help you avoid some problems later.
The algorithm is the following:
- Completely unscrew the top cap. Look inside the steerer and observe the star nut. See how the star nut bites into the steerer and how the top cap screw will screw in the star nut.
- Un-tighten the handlebar stem. Observe how the stem fixes itself on the steerer. Try to slide the stem up and down on the steerer and look at the headset bits.
- Understand that the stem needs to be at the good position in order to not let the steerer move vertically (shake) but not to press too hard on the headset bearings (stiffness)
- Now, start to screw to top cap back and go until the stem is at the good position (i.e. you just begin to feel that the top cap screw is harder to screw). Do not overtighten!!!
- Tighten the screws of the stem. Be careful about stem orientation wrt. to the wheel. Tighten the screws in a diagonal pattern. Be firm, but stop when you feel it's right (difficult to judge) or when you (visually) see that the stem starts to tighten (very slightly deform) at the vicinity of the screws. In any case, check whether the stem is solidly fixed to the steerer.
- Screw just a bit more the top cap, in order to be sure that it doesn't unscrew by itself. Since the stem it's now holding everything in place, the top cap is not needed to do something after that. In the extreme case where you cannot tighten correctly the steam cap (i.e. you reached the screw end course and the steam cap is loose), then that means that the star nut moved inside the steerer. It's an easy fix too, but you can also let the LBS to do that.
Likes For DarkCloud:
Collector of Useless Info
Get a new star nut, and if your top cap is plastic, a new top cap. Pound the old star nut out and install the new one. Adjust the headset properly, and you're done. Star nuts cost a buck or two. A bike shop could do this for you in <5 minutes.
aka Timi
Likes For imi:
Cat 6
Quoted: 500 Post(s)
Liked 183 Times
Sorry operator, way too much punctuation.
72 Frejus (for sale), Holdsworth Record (for sale), special CNC & Gitane Interclub / 74 Italvega NR (for sale) / c80 French / 82 Raleigh Intl MkII f&f (for sale)/ 83 Trek 620 (for sale)/ 84 Bruce Gordon Chinook (for sale)/ 85 Ron Cooper / 87 Centurion IM MV (for sale) / 03 Casati Dardo / 08 BF IRO / 09 Dogma FPX / 09 Giant TCX0 / 10 Vassago Fisticuff
Great State of Varmint
Liked 15 Times
This is often a mistake made by newer mechanics:
You want to tighten the stem-cap a little before torquing down the stem-bolts. Use a torque-wrench and set the bolts to the manufacturer's specs - going from one to the other slowly increasing the torque until they are the same. Then check the stem-cap and check for any play in the headset, and making sure it moves freely side-to-side when the front wheel is lifted and the bike tilted.
Bikes: !982 Trek 930R Custom, Diamondback ascent with SERIOUS updates, Fuji Team Pro CF and a '09 Comencal Meta 5.5
Quoted: 1299 Post(s)
Liked 739 Times
Is there a specific reason you feel compelled to "answer" a 13 1/2 year old thread?
Likes For maddog34:
Quoted: 2594 Post(s)
Liked 1,922 Times
Bring this thread back to life!
Quoted: 1607 Post(s)
Liked 2,213 Times
breaks not brakes! Is there anything like a partial break, really? If it is broken, it is broken, period. Even if the parts don't separate, the functional intent is compromised.
Likes For SJX426:
