keep dropping my chain
reluctant roadie
Hi all. Searched to no avail. I've just converted my hardtail to singlespeed using the Forward Components EBB. I think I have the tension set pretty well, but on my first real ride I kept dropping the chain. It generally happened when climbing while hitting a bump or drop.
I maxed out the tension with temporary improvement but then the problem suddenly got quite bad and I had to bail. The chain is pretty well tight witout obvious loose or tight spots. I was able to get it back on without detensioning each time.
Any ideas on the issue? Chainline? The chainring is on the outermost position and the cog is most of the way outboard. Looks pretty straight. I'm running 44/25, with a new LX crank/outer ring, and a Shimano cassette cog with spacers on a Deore freehub. Something to do with the sizeable cog and chainring? Clumsy riding (I think not!)?
Thanks guys.
Thanks guys.
If anything the big cog helps you get more contact with the chain and will help you hold your chain. And if the line is straight, my guess would be your tensioner. They are really hard to set up right, you want it as close to the chainstay as possible, with the spring set pretty loose.
But you dont mention a chain tensioner, which could be an issue. If you have vertical drop out(which is probably the case) you should be running a chain tensioner, even if you try to run a "magic" ratio.
reluctant roadie
https://forums.mtbr.com/showthread.php?t=490528
reluctant roadie
Bikes: team miyata, '73 p-14, MB-3, centurion lemans, Mystery TT, mongoose atb '85
also, if you're able to reseat the chain without removing the wheel, it doesn't sound like you have enough tension on the chain... maybe replace a link with a half-link and retention?
don't even
Bikes: Peugot Conversion, Jamis w.i.p.
I was having a similar issue a while back and thought the chain seemed plenty tight enough but it would drop on bumps or i could hear it skipping if i was really trying to climb, I just took it into my lbs and in like 5 minutes they tossed in a half link and all was solved. Haven't had an issue since. (not saying this is definitely the problem you have, just relating a similar situation. but it couldnt hurt to take it in. shrug.)
reluctant roadie
I think the chain tension idea is the place to start. I'm out of the adjustable range with my EBB so I'll update you once I throw in a half link. Thanks guys.
Yup
Location: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
Quoted: 9 Post(s)
Liked 6 Times
Its the casette cog.
There is no way that the chain is coming off because of tension issues. That chain is tighter than my fixed gear bikes and my s/s mtb. Get a s/s specific cog. You have a combo that is designed to make shifting gears easier, and with heavy torque and even slightly off chainline, off comes the chain. S/s cogs have higher/pointier teeth to engage the chain. I use a ramped chainring on my bike with s/s cogs and it's never come off.
And out of curiosity, why 44-25? Thats a bizarre choice, less than 2-1 ratio. Are you doing massive climbs? I run 34-14 and 32-16 on mine ( two rings, two cogs). Smaller chainrings give more options as well for chainline adjustment. You can move the chainring to the inside of the spider and/or get a shorter b/b to straighten the chainline.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
reluctant roadie
Yeah, I know 44-25 is weird. It's not that weird, though. It's equivalent to 32-18, which a lot of guys around here run. We have a lot of brief but very steep climbs littered with typical New England roots and boulders which can stop you dead and bounce you off your bike. There are not a lot of fast flowy sections where taller gears would be of benefit.
I'm going to re-examine my chainline, and then consider recovering the 32t chainring that I poached for another bike to run with a different cassette cog, possibly a SS-specific one if it turns out my chainline is OK.
Thanks for your thoughts.
dumb question, but you're not running an 1/8 cog with a 3/32 chain right?
Elitist
Quoted: 1386 Post(s)
Liked 92 Times
I had a bike where the rear triangle was not very stiff. Whenever I would torque really hard (as when climbing) it would flex and dramatically change the chain line and drop the chain.
reluctant roadie
Decrepit Member
Also, if the chain is dropping inside the chainring, you could use a Deda Dog Fang on your seat tube.
Likes For matheui:
