difference between single and double front of saddle?
difference between single and double nose saddle?
What's the difference between a single and a front nose saddle in terms of comfort and performance? I'm more interested in comfort on long rides than performance.
Kamen Rider
Bikes: Fuji Transonic Elite, Marechal Soul Ultimate, Dahon Dash Altena
Quoted: 351 Post(s)
Liked 277 Times
Basically, imagine you have a regular full length saddle with a central cutout or relief channel. Chop off the front half of the saddle, and you'll arrive at something like the above. Why? To get around the UCI rule regarding saddle positioning so that you can sit further forward than with a more traditionally-shaped saddle.
Quoted: 10236 Post(s)
Liked 5,183 Times
I use the above saddle, and like it. My other bike is fitted with a WTB deva. I like that as well.
Ok, but how does the double nose affect comfort or performance? The double nose saddle appears to be twice as wide in the front so it makes more contact with the perineum, does that mean it's easier on that area and there's less numbness on longer rides? I understand that it's easier to sit at tip of the nose when needed, but what about when you regularly sit fully in the seat, does it negatively affect performance? Are the inside of the thighs in any way rubbing against it (probably not). If it's much more comfortable, why are most saddles made with a single nose? Why would someone not want a double nose saddle?
Quoted: 8273 Post(s)
Liked 9,028 Times
As with all saddles, what works for one person might not for someone else. Saddle fit is the most personal thing on a bike. You have to try it to see if you like it, you might hate it. I've given away saddles before.
Kamen Rider
Quoted: 351 Post(s)
Liked 277 Times
As for concerns about inner thigh rubbing - the general advise is, if your thigh is rubbing, lower your saddle, or get the narrower model. And if your thigh is still rubbing with the narrowest model... then maybe it's not the one for you.
Speaking from my own experience - I rode a 600km brevet with the PR 2.0. Very comfortable, just some annoying thigh rubbing because I am a pretty thin person (my regular saddle is a Fizik Arione). I also tried the PN 3.0 on a 200km brevet. Better, no thigh rub, but it's only comfortable in a low, aero position (e.g. on the drops or aerobars). Try to sit up a bit and the 120mm width just doesn't work well for me.
Likes For guachi:
Liked 9,028 Times
Put that thing on your bike and go ride for 8 hours and tell us how comfortable it is. It's not a bar stool, on a bike your legs move and do work, a big tractor seat would get in the way.
Expired Member
Quoted: 3660 Post(s)
Liked 5,408 Times
+1 I doubt most folks could ride something like that for more than an hour unless they were on a "sit up and beg" cruiser. A lot of cycling stuff seems odd to people who don't ride. Probably the same with any activity.
Likes For shelbyfv:
Liked 5,183 Times
seems there is no consensus as to advantages of a double nose over single nose saddle. It also seems the single nose saddles are more prevalent.
what does "BB" stand for? I'm trying to decipher your post and am I correct that you mean that single nose saddle renders better uphill performance than double nose?
Quoted: 4393 Post(s)
Liked 4,836 Times
Likes For PeteHski:
Trying to keep up
Bikes: Pinarello Prince, Orbea Onix, Ridley Fenix
Quoted: 79 Post(s)
Liked 136 Times
This is correct. There is literally no consensus when it comes to saddle choice. Saddles come in all sorts of shapes and sizes, just like people's butts! Unfortunately there's a fair bit of trial and error involved in choosing a saddle, but I would start off with something more conventional than the ISM and see how it goes. Some shops have demo saddles to try too. I've been through a few saddles in my time, but I'm really liking this one from Fizik. It's pretty easy on the man gear with the cut-out and comfortable for all day endurance rides. The best saddles are the ones you don't actually notice when riding.
Advocatus Diaboli
Quoted: 4731 Post(s)
Liked 1,531 Times
I don't really understand the stubby nosed appeal. Is it an appearance thing? I never ride sitting on the nose of my non-stubby saddle, nor find the nose to be in the way. So what is gained by having that last ~4cm lopped off the front (a bit of weight savings)? I considered the Selle Italia "Boost" version of the SP-01, but didn't see any advantage so I've been happy with the standard. FWIW, the stubby version seems to be priced higher also.
Liked 4,836 Times
climber has-been
Quoted: 3425 Post(s)
Liked 3,561 Times
Likes For terrymorse:
Advocatus Diaboli
Liked 1,531 Times
You've kind of answered your own question right here. Before moving to a short nosed saddle I was using a Fizik Aliante (very conventional thin long nose) and found it pretty uncomfortable riding on the nose. I actually find I can ride quite well on the nose of my shorter saddle as it's a bit wider and flatter. Looking at them side by side it's about an inch shorter overall.
climber has-been
Liked 3,561 Times
This source suggests the opposite, that sitting back on the saddle improves climbing by opening up the knee angle at the top of the pedal stroke:
...by sitting back on the saddle the knee angle will increase by a couple of degrees. This may seem small but we can also see from the Knee Angle graph that this could give 5-10% more power at this point in the stroke
Ride, Rest, Repeat. ROUVY: terrymorse
