Go Back  Bike Forums > Bike Forums > Fatbikes
Fatbikes are fun and here to stay.
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 02-06-23, 11:24 AM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
Liked 22 Times in 9 Posts
I thought it might be nice to put a positive post at the top of the page. I've been living around Fairbanks, AK for ten years, and after all this time seeing fatties out and about, I finally bought a pair for my wife and I.
We have a Kona Wo and a Kona Woo. I'm having fun learning tire pressure vs. snow/trail conditions.
There is no substitute for a fatbike if you want to ride a bike on snowpacked trails. I've tried lol.
Hooligans is offline
Old 02-06-23, 12:30 PM
Daniel4
Bikes: Sekine 1979 ten speed racer
Quoted: 1477 Post(s)
Liked 633 Times in 433 Posts
I purchased my fatbike in 2015 specifically as a snowbike for comuting. Now that I'm retired, I ride it through the snow to the gym and around town.
I experimented with tire pressure a lot riding at 4 psi a long time. I think it's at 8psi now. Too low and the rolling resistance will really drain you.
My last long ride was 37.5km for about 4 hours but that includes 45min at McDonald's for a Big Mac meal to fuel up before returning home.
Daniel4 is offline
Likes For Daniel4:
Old 02-06-23, 12:37 PM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
I don't know what pressures I'm using because it's all just by feel. Basically I'm figuring out that there is a balance between resistance from sinking in snow at higher pressure, and resistance from the tires at too low a pressure.
Old 02-25-23, 09:11 AM
pipeliner
Quoted: 43 Post(s)
Liked 71 Times in 40 Posts
It's a process, learning what pressure to run for what surface and how much you weigh. Tubeless helps a bunch with resistance but so does tire design...use120 tpi tires for low pressure riding.
pipeliner is offline
Likes For pipeliner:
Old 02-25-23, 12:28 PM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
I've also figured out that I can run a softer front pressure to keep the tire from cutting into the trail as much, and a somewhat firmer rear to compensate for my weight over the tire.
Likes For Hooligans:
Old 02-28-23, 12:37 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2704 Post(s)
Liked 2,457 Times in 1,388 Posts
Optimum pressure depends a lot upon what you’re riding on. Deeper soft snow I might be around 3-4. Firmer snow and ice 4-5. Dry trail 7-9.
Also, some tires roll much slower than others as pressures drop. High TPI casings with more supple sidewalls don’t slow down as much at lower pressures as tires with thicker, stiffer sidewalls.
Kapusta is offline
Likes For Kapusta:
Old 02-28-23, 01:02 PM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
Thanks. I have Vee Tire Avalanche/Snowshoe front/rear.
Old 03-01-23, 02:17 PM
prj71
Quoted: 2909 Post(s)
Liked 1,107 Times in 732 Posts
Worst tires ever for snow. I had a pair. I would dump them and get a good tire from either 45nrth or Surly.
prj71 is offline
Old 03-01-23, 03:36 PM
DangerousDanR
Bikes: Time Scylon, Lynskey R350, Ritchey Breakaway, Ritchey Double Switchback, Lynskey Ridgeline, ICAN Fatbike
Quoted: 384 Post(s)
Liked 435 Times in 236 Posts
I have studded Snowshoe tires for ice season and Jumbo Jim tires for snow season. Both are fine for how I use them. I am a recreational trail rider and commuter.
DangerousDanR is offline
Likes For DangerousDanR:
Old 03-01-23, 03:56 PM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
That's the first I've heard that they're the worst. They come standard on new Konas (Woo). The Wo gets Schwalbes.
Old 03-01-23, 04:01 PM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
My riding is all for recreation and fitness, as well as dogjoring with huskies now and then. I envy those of you that go to work on your bikes ( in winter too! ).
Old 03-01-23, 04:09 PM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
I just noticed in a previous post that you have a Woo on Surly tires. Did you replace the Vee Tires on that one because you didn't like them?
Old 03-01-23, 11:00 PM
MarcusT
MarcusT's Avatar
Quoted: 714 Post(s)
Liked 543 Times in 302 Posts
I know many fat bike owners ride snow, snow, snow, but believe me when I say, even without snow they are a blast. The flotation, sure grip of the tires make almost any terrain rideable.
Yes, there is the weight issue, but for the fun, it's worth it.
MarcusT is offline
Likes For MarcusT:
Old 03-02-23, 12:10 AM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
I've only had my fatbike since well into this winter but I'm definitely looking forward to try it on other surfaces this summer!
Old 03-02-23, 05:12 AM
FREEBIRD1
Quoted: 80 Post(s)
Liked 188 Times in 98 Posts
I take them out on dry trails all the time, the ride is great, cruise a creek shoreline etc.
FREEBIRD1 is offline
Likes For FREEBIRD1:
Old 03-02-23, 05:22 AM
bikemig
bikemig's Avatar
Quoted: 5863 Post(s)
Liked 3,393 Times in 2,038 Posts
A fatbike is one of the few modern bikes that I think I'd like to buy one day.
bikemig is offline
Likes For bikemig:
Old 03-02-23, 07:05 AM
RB1-luvr
I don't know.
RB1-luvr's Avatar
Bikes: '90 B'stone RB-1, '92 B'stone RB-2, '89 SuperGo Access Comp, '03 Access 69er, '23 Trek 520, '14 Ritchey Road Logic, '09 Kestrel Evoke, '08 Windsor Tourist, '17 Surly Wednesday, '89 Centurion Accordo, '15 CruX, '17 Ridley X-Night
Quoted: 266 Post(s)
Liked 662 Times in 354 Posts
I have only ridden my Surly Wednesday once in snow (a race). Although I've owned it for approx. five years, I'm just recently beginning to ride it regularly on mtb trails. It is so fun. I have approx. 10 psi in the tires (3.8" wide).
RB1-luvr is offline
Old 03-02-23, 09:41 AM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
Looks fun to me!
Old 03-02-23, 09:42 AM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
Heck yeah. I'll be doing some of that!
Old 03-02-23, 11:41 AM
prj71
It's common knowledge among fat bike enthusiasts that the Vee tires are junk. Manufacturers put those low grade tires on to keep the price of the complete bike down. The tires have poor grip in snow, they wash out easily and snow sticks to them instead of shedding. They would be OK for summer riding in dry conditions, but in anything else they're kind of useless.
I have a Kona Woo. The tires were dumped within a month for Surly Bud and Lou. Light years better than the Vee tires.
My Specialized Fatboy is equipped with 45nrth Flowbeist and Dunderbeist. Close to same grip as Bud and Lou but roll better.
prj71 is offline
Old 03-02-23, 12:38 PM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
Good to know.
Old 03-04-23, 08:19 PM
CrimsonEclipse
Quoted: 278 Post(s)
Liked 391 Times in 217 Posts
(sarcasm) I was told that fatbikes are a dying breed (sarcasm)
My monstrosity is always used in a place where there is rarely snow.
1. Because I do what I want
2. Because it's hilarious...
CrimsonEclipse is offline
Likes For CrimsonEclipse:
Old 03-05-23, 12:16 AM
Hooligans
Hooligans's Avatar
Bikes: Rockhopper
That's what I'm talking about.
