Bicycle helmet strap extenders?
Old 01-21-22, 08:52 AM
Harhir
Harhir's Avatar
Bikes: Fahrradmanufaktur Trekking Bike, 2 x Lightning Phantom, bikeE and bikeE2, Cycle Genius Raven
Quoted: 153 Post(s)
Liked 79 Times in 48 Posts
All. Is there something like bike helmet strap extenders? I have a long head and I am having a hard time finding a helmet with straps long enough. My current helmet barely works with the strap all maxed out. But with the cold weather I like to wear my hoodie under the helmet which makes it impossible to close the strap. Does anyone know if there is something like a strap extender?
Otherwise I might need to make one myself out of an old helmet.
Thanks
Harhir is offline
Old 01-22-22, 09:20 AM
KerryIrons
Quoted: 90 Post(s)
Liked 124 Times in 69 Posts
Thanks
Get yourself to a fabric store for the nylon straps and probably the clips as well that match the size of your helmet. Then you just make a short strap with a male clip part on one end and female clip part on the other end. It might chew on your chin with the extra clips so you could wrap them with fabric. DIY success.
KerryIrons is offline
Old 01-22-22, 10:11 AM
UniChris
UniChris's Avatar
Bikes: 36" Unicycle, winter knock-around hybrid bike
Quoted: 861 Post(s)
Liked 354 Times in 257 Posts
Fabric store clasps won't be compatible though.
Also slide clasps may not hold well on other webbing types - found that recycling some in a backpack, ended up having to tie off the adjustments.
UniChris is offline
Old 01-23-22, 08:58 AM
BobbyG
BobbyG's Avatar
Bikes: 2015 Charge Plug, 2007 Dahon Boardwalk, 1997 Nishiki Blazer, 1984 Nishiki International
Quoted: 1236 Post(s)
Liked 1,190 Times in 597 Posts
You might check some local thrift shops for helmets with compatible clasps, and use those for the extender.
BobbyG is offline
Old 01-23-22, 08:50 PM
Doug64
Doug64's Avatar
Quoted: 1087 Post(s)
Liked 634 Times in 338 Posts
The easiest way, at least for me, to make a strap extender is:
  • Measure your strap, it s usually 5/8" or 1/2" wide.
  • Buy a sidelock buckle @ Rainshed
  • Buy some nylon webbing @ Rainshed
  • If the buckle fits the buckle that is on your helmet now it is easy.
If the Buckle does not fit:
  • Remove the male side buckle, and replace it with the male side of the new buckle.
  • Thread a piece of webbing through the female side of the new buckle, fold the webbing back on itself making 2 layers of webbing.
  • Thread the old male buckle onto the piece of the open ends of the webbing that was just folded over. This will form a loop with the male side of the old buckle on one end and the female side of the new buckle on the other end.
  • Determine how much extension you need, and trim to fit.
It should work
P.S. If you are going to cannibalize an old helmet for parts, the process is the same.
Doug64 is offline
Old 01-24-22, 11:03 AM
Harhir
Harhir's Avatar
Quoted: 153 Post(s)
I actually found an older kids helmet in my garage. I thought I had thrown this one out years ago when became too small for my daughter. Good thing I did not. Same buckles. So I cut off the strap and made my own extender. It was easier than I thought.
Harhir is offline
Likes For Harhir:
