Front mudguard has slight friction with wheel, what should I do?
I got a bike recently. I noticed that there's a friction sound coming out periodically from the front wheel. I then checked to see what was happening and there seems to be a part of the wheel that has more contact with the mudguard (I figured this out by mixing the wheel like a record and noticed that it's only when a certain part of the wheel meets with the mudguard).
Is this a reason of worry? It's not annoying tbh since I don't notice it when I ride the bike but could this use up the tire prematurely?
Quoted: 6190 Post(s)
Liked 4,806 Times
If the tire is constantly rubbing on the tire, I'd suspect that either the tire is not in the frame properly or the fender supports are bent. If the tire only bumps the fender briefly, then probably the tire needs to be trued.
Neither is the only cause and fixing to solve just the rub without knowing if everything else is correct might leave you blissfully unconcerned that something worse is going on.
If this is a brand new bike, I'll always suggest take it back to where you got it and let them look at it or at least take it back to the nearest authorized dealer for that brand of bike.
yeah, it's like a SHHH____________SHHH____________SHHH_________ when I ride it slow enough to hear the friction sound
I'll just get it to the shop I got it from then
Just Pedaling
Bikes: YEP!
Quoted: 331 Post(s)
Liked 519 Times
My guess is the wheel isn't true or the tire isn't properly seated in the rim. I put fenders on my bike and there is very little clearance. In fact, sometimes I have to stop and roll the tires backwards to clear out debris that builds up between the tire and the fender. Road bikes were not meant to ride in mud or pine needle covered foot paths after installing fenders. But get the wheel trued or the tire massaged onto the rim and you shouldn't have any rubbing. Rubbing bad!
