Nitto M-18 diving board fabrication
Bikes: '38 Schwinn New World, ’69 Peugeot PX-10, '72 Peugeot PX-10, ‘7? Valgan, '78 Raleigh Comp GS, ’79 Holdsworth Pro, ’80 Peugeot TH-8 tandem, '87 Trek 400T, ‘7? Raleigh Sports, ‘7? Raleigh Superbe, ‘6? Hercules
Quoted: 761 Post(s)
Liked 1,563 Times
I've got a Nitto M-18 on my '97 Cannondale T900 to support a rando bag. This era Cannondale has an MTB-style TIG-welded 'unicrown' fork with a pretty large distance from the hole in the center of the crown to the tire. This means if I use the 'diving board' that came with the rack, the rack is up higher than it needs to be (the rack is a good 1 1/4" up from the top of the fender). I want to lower it not least to lower the bag, but also so I can attach the fender to the rack to eliminate some rattling on rough roads. I (think I) can make a new diving board with a piece of aluminum bar stock from the home improvement store... but the diving board that comes with the Nitto is stainless. Is aluminum bar stock risky to use in this case? Seems most of the weight on the rack is supported by the stays to the mid-fork eyelets...
Jedi Master
I bent the nitto diving board in a vise to get it to work at the right height with my bag. I've talked to other people who had to do the same thing.
Quoted: 469 Post(s)
Liked 2,443 Times
Before
After
I cut the bracket down and drilled a new hole. I will say that drilling through this stainless was no fun(using a cordless drill). The results were good, and it allowed me to use the fork braze ons instead of P clamps.
Likes For Roger M:
Quoted: 761 Post(s)
Liked 1,563 Times
I'm not completely sure how long my 'relationship' with this Cannondale is going to last, so I was kinda trying to avoid messing with the Nitto diving board.... and being a cheapskate I suppose, because I could always get another for $20 or whatever (assuming it is 'in stock' anywhere when the time comes)! Probably I'll end up doing what you did, Roger M. (I actually ordered longer stays and cut them down to work with where the rack is positioned with the unaltered diving board.... but if I alter the diving board to where I want it I think the stays that came with it will work..... so there's $20-something down the drain!)
Quoted: 469 Post(s)
Liked 2,443 Times
I understand and can relate to cutting up something, knowing you can't go back. I'm glad I did it(under the recommendation of another forum member). I brought my rack down and rearward quite a bit, making the bag installation much better for me.
Good luck whichever way you decide to go.
Likes For Roger M:
Quoted: 2363 Post(s)
Liked 1,749 Times
Aren't there generic stainless steel brackets with a simple L-bend at the end, typically used to mount rear racks to the brake mount?
Quoted: 761 Post(s)
Liked 1,563 Times
I guess 'diving board' wasn't the right search term... $7, and out-of-stock pretty much everywhere, but seems like it would do the trick without having to mess around with cutting and bending...
Well, whaddaya know..... velo orange makes a rack strut in a couple sizes (I can't post a link for whatever reason....)
Quoted: 761 Post(s)
Liked 1,563 Times
