Socket Head Screw Assortment
I am looking to get an assortment of socket head screws set for my bikes to have on hand. Can anyone recommend a place to purchase? Thanks in advance!
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3886 Post(s)
Liked 6,480 Times
Check eBay and filter on US sellers.
And also check harborfreight.com.
Likes For SurferRosa:
Bikes: 2021 Trek FX Sport 4, ~1996 Mongoose Crossway 4.50
Quoted: 94 Post(s)
Liked 1,308 Times
Belmetric: https://belmetric.com/socket-products/
I wouldn't trust the quality from an eBay seller. Especially for a critical component that has safety consequences, don't take a chance.
Belmetric is the go-to place for us car guys.
Mark
Mark
Quoted: 427 Post(s)
Liked 699 Times
The local Ace Hardware has drawers of all kinds of nuts, bolts, etc. And yes, they do have metric. With so much going pre-packaged, if you have an Ace nearby, might want to check.
Quoted: 2026 Post(s)
Liked 1,096 Times
McMaster-Carr and Grainger are large industrial supply houses and both will sell to individual purchasers in person and on-line. If they don't have it it probably isn't made.
Bolt Depot and Fastenal are specialty fastener shops that also sell on-line and are good sources.
Likes For HillRider:
Quoted: 6193 Post(s)
Liked 4,808 Times
Do you break or otherwise trash a lot of screws for your bikes? Seat post clamp bolts are probably the only screw on a bike I've had to ever replace and not more than I have fingers on one hand.
Likes For Iride01:
Licensed Bike Geek
As others mentioned, ACE Hardware has a very good selection of fasteners in stainless metric.
Quoted: 1303 Post(s)
Liked 1,910 Times
I buy mine in bulk from Fastenal, they are a large screw and bolt distributor. I buy in 100 piece packages and get stainless steel for the bikes. HTH, MH
Quoted: 4806 Post(s)
Liked 3,928 Times
Yet another vote for Ace, aka A-Boy Electrical and Plumbing. Boxes of 100 sound nice and cost effective but I want a variety of different lengths. I like several different head styles depending on application.
Here in the PNW, we have Tacoma Screw, another very good fastener source. (I forget what I started going to the Seattle one for but I quickly discovered they had #2 round heads and nuts that made perfect replacements for the beautiful SS screws my favorite harmonicas are assembled with. Yes, a step down in class, but now, if I had to disassemble one to remove a bit of food clogging a reed, I could use a standard dinner knife and my thumb and not need a special tiny Phillips no one had. One of the trials of playing the blues. Low light, late at night and around food. Food particles are the curse! The founder of the harmonica company and designer of the ground breaking harmonicas 40 years ago chuckles when I tell him I routinely remove his works of art and replace them with those cheap screws but he doesn't scold me.)
My local “The Hardware Store” used to be an Ace franchise and I believe a Hardware Hank before that . More of an independent store now. What used to be a good selection of fasteners is now a GREAT selection! Metric as well as SAE, socket head, Phillips, Torx etc. They are always my first stop. I found Fastenal to be a bit spendy but the selection is, as one might expect, very good.
Box stores aell small quantity fasteners in poly packs at inflated prices. Thats OK if you need something quick to finish a job, but expensive on the long haul.
Check and see if you have a local fastener supply house. You'll get good process there AND they might have an assortment like you asked for.
Failing that parts houses like the before mentioned McMaster, Fastenal and (new to me) Balmetrics are your best bet.
Liked 1,096 Times
Before you go too far and buy a huge assortment, keep in mind the great majority of the bolts used on bikes are M5x0.8mm in a rather limited range of lengths, certainly nothing longer than 25mm, and an occasional M6x1.0mm for seatpost clamps and similar. The only other threading I'm familiar with is M8x1.0 (not the more common M8x1.25) used for square taper crank bolts and M10x1.0 for rear derailleur mounting bolts but neither of these are routinely replaced.
elcraft
Marine hardware sources like West Marine, regularly stock metric stainless fasteners. Some of the fasteners are available with Hex Socket/Allen Key drives or Phillips style drives.
One caveat, though, Stainless screws fastened directly into aluminum cab be subject to Electrolytic corrosion, especially near coastal areas and salted roads and Winter bikes. A good quality dielectric grease should be used as it is both anti rust/ corrosion resistor and electrically insulates (or at least improves insulation) to ward off the electrolysis process.
Fastenal and Grainger both sell assortment kits of metric bolts and nuts. Fastenal also sells sets in hardness ratings. Although not really as critical on a bike, I do use the same assortment for auto applications.
There is also the choice of stainless, anodized, or chrome. Hardly anyone uses chrome. Stainless looks better but it galls with over tightening. Anodized is stronger but will rust out eventually. An assortment is overkill but I know the feeling. Most of what you need is for racks and bottle cages. Some racks take longer bolts. And as noted above, anti seize paste, dielectric grease, and Loctite are your friends.
Quoted: 1561 Post(s)
Liked 1,734 Times
I've never heard of anyone needing an assortment of generic screws in order to work on bikes. Most of the screws used on a bike are specialized screws and not generic off-the-shelf items. And most of the time when you strip something on a bike, it's not the screw but the threaded hole in the aluminum part that gets stripped out.
Quoted: 1109 Post(s)
Liked 1,200 Times
I've never bought an assortment of bolts (not screws... my bikes don't have any screws, only bolts) for a bike, but for some reason I have dozens of them in a little box I keep in my bike-shop-area. (garage). On the rare occasions I need something I don't have in that little box of sh.., I mean stuff, I go to my local Tru Value hardware store where they have every imaginable fastener and lots of other neat little things.
Mad bike riding scientist
Quoted: 6219 Post(s)
Liked 4,217 Times
Probably the best choice. No need to keep too many on hand.
Stuart Black
Stuart Black
Quoted: 166 Post(s)
Liked 252 Times
Probably anyone that builds, restores, or flips bikes wants/needs a assortment. some will make do with droppings from other bikes others just want a bin. Most of the hardware is pretty standard stuff...
for the OP if you want bulk mcmaster, or fastenall. if you want a little kit amazon or ebay. if its just one or two stray things hardware store.
Liked 4,217 Times
Stuart Black
Stuart Black
Quoted: 303 Post(s)
Liked 136 Times
Google cable end crimps for sources, same on amazon as well. Note different sizes for derailler versus brake cables.
Or any bike shop .....
I bought 100 stainless SHCS in 5Mx0.8 20 yrs ago from Mcmaster and haven't use 10 of them since. I second those
that note a lot of the bolts on bikes are special heads or odd lengths. The 5Mx0.8 or 6Mx1.0 are common in bottle
cage, some derailler bolts and fender or rack mounts, but a lot of the other fasteners are bicycle only use.
Likes For sch:
Liked 4,217 Times
ebay is another source. You can get them in lots of different colors or even with skulls if you like.
Stuart Black
Stuart Black
Likes For cyccommute:
Liked 4,217 Times
About the only “bicycle use” only fasteners that I can think of are ones on the derailer that need a stop. Most everything else are 5M and 6M. Older bikes might use something less standardized but modern bikes (post 1995), there’s very few bolts that you can’t find replacements at you local hardware store.
Stuart Black
Stuart Black
