Ever see something like this?
Old 03-11-19, 09:03 PM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
Liked 523 Times in 347 Posts
You guys ever seen something like this?
Was in the process of starting a sprint and the front derailleur adapter just snapped in half. (less than 4 months old).
This is a Dura Ace FD-R9150 SM-AD91-L adapter (34.9mm). I was already in the big ring (no front shift) and had just shifted the rear before stomping on it. I ended up ordering a replacement off Amazon and sent Shimano a message to see what they have to say.
jadocs is offline
Old 03-11-19, 10:51 PM
Litespud
Bikes: 2000 Litespeed Vortex Chorus 10, 1995 DeBernardi Cromor S/S, Nashbar 3sp commuter
Quoted: 603 Post(s)
Liked 698 Times in 393 Posts
Looks like pot metal, the MDF of metals. Turns up everywhere these days
Litespud is offline
Old 03-12-19, 01:32 AM
thehammerdog
thehammerdog's Avatar
Quoted: 675 Post(s)
Liked 314 Times in 206 Posts
You must have huge powerful quads
thehammerdog is offline
Likes For thehammerdog:
Old 03-12-19, 01:58 AM
Racing Dan
Racing Dan's Avatar
Quoted: 1190 Post(s)
Liked 247 Times in 164 Posts
Or it was installed with too much torque.
Racing Dan is offline
Old 03-12-19, 06:23 AM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
Yeah, I've been searching and haven't found much info. I can't speak to torque as it came assembled from the manufacturer. I think it does look like pot metal, like Litespud mentioned. I only put out 817 watts before it snapped. I can only imagine it being some kind of defect.
jadocs is offline
Old 03-12-19, 10:38 AM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
Well, Shimano said they would warrantee it, but I would have to bring the bike to an authorized dealer and have them look it over, order the part and install it.
jadocs is offline
Old 03-12-19, 10:42 AM
Steve B.
Quoted: 2203 Post(s)
Liked 954 Times in 556 Posts
Titanium bike with cast aluminum clamp using a steel bolt ?.
The aluminum gives first when over tightened, so likely at whomever assembled.
I can't say I've ever read of this.
Steve B. is offline
Old 03-12-19, 10:46 AM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
I agree Steve, I wish I could say that it was overtightened, but can't. I do know both bolts have the same torque specifications 6-7nm.....and the bolt that secured the derailleur to the adapter did not feel overtightened when I took it off.
jadocs is offline
nomadmax
Quoted: 918 Post(s)
Liked 1,317 Times in 643 Posts
I've never seen a FD clamp break but I'd take that all day long over a crushed seat tube on my titanium bike
nomadmax is offline
Old 03-12-19, 10:49 AM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
Yep.... Thankfully everything else appears to be fine. As soon as I heard it pop (loud), I knew I broke something and coasted to the side of the road.
jadocs is offline
Old 03-15-19, 12:44 PM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
New adapter clamp is installed. I know the torque is spot on as I did it myself. Will see if this was just a fluke occurrence.
jadocs is offline
Old 03-15-19, 12:53 PM
Lemond1985
Sophomore Member
Lemond1985's Avatar
Quoted: 1626 Post(s)
Liked 1,048 Times in 627 Posts
Maybe it was already broken from a previous front shift made under heavy torque, and was just barely hanging together. The rear shift was enough to knock it loose.
That's a possibility I suppose.
Lemond1985 is offline
Old 03-15-19, 12:55 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 2917 Post(s)
Liked 1,857 Times in 1,127 Posts
+1 this.
We had a rash of this type of failure with Huret Jubilee front derailleurs at Trek.
JohnDThompson is offline
Old 03-15-19, 01:18 PM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
I could see that being a possibility, but the sound was impressive. Guy that I was chasing heard it and thought someone crashed, that's how loud it was. I made the rear shift just as he was passing on my left and it popped when he was in front of me.
jadocs is offline
Old 03-15-19, 01:19 PM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
+1 this.
Interesting, I agree it has to be this, or a defect.
jadocs is offline
Old 03-15-19, 01:24 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4173 Post(s)
Liked 1,167 Times in 765 Posts
Interesting about the too-much-torque theory.. aren't folks always warning against clamping a seatube when putting bike in a stand for fear of crushing the seat tube (ie. always use the seatpost). I can't imagine those workstands with the rubberised clamps would ever exert more psi on the tube than a 1/2" wide metal FD clamp.
Sy Reene is offline
Old 03-15-19, 01:31 PM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
I think they are talking about the top tube being clamped, especially with respect to carbon fiber bikes.
With regard to the FD adapter, even in the dealers manual, they warn you to check with manufacturers specifications with regard to torque because the stated 5-7 n.m. may be too much depending on the material used on the frame (I assume they are talking about carbon fiber frames), but I could be wrong.
jadocs is offline
Old 03-15-19, 02:25 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1267 Post(s)
Liked 1,175 Times in 504 Posts
800W won't break anything. Definitely a flaw in the material. Could have been exasperated by how tight it was on the frame and if you were/are heavy and putting that 800W in while yanking on the bars for leverage. Tubes flex and *POP*.
Pay a couple of bucks and grab a new bracket and be done with it.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Psimet2001 is offline
Old 03-15-19, 02:27 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
Wrong angle completely. Too tight puts strain on the clamp as well and if there is already a defect in the material then it if the frame flexes at all it will help accelerate a failure.
Old 03-15-19, 02:32 PM
redlude97
Quoted: 1959 Post(s)
Liked 216 Times in 159 Posts
I see a Di2 FD, did you adjust the leverage screw on the FD to push up against the seat tube? If not maybe the front shifting fatigued the adapter
redlude97 is offline
Likes For redlude97:
Old 03-15-19, 06:06 PM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
Already repaired. Those were seated watts (mid acceleration), so I was not torquing the frame (per se) by pulling up on the bars. I agree 800 should not break anything and it must be a defect.
Yes, the support bolt was engaged. I also double checked it when I re-installed the FD onto the adapter...it's tight and the chain guide outer plate is aligned perfectly.
jadocs is offline
Old 03-15-19, 06:16 PM
TimothyH
- Soli Deo Gloria -
Quoted: 6839 Post(s)
Liked 718 Times in 453 Posts
I think @redlude97 is onto something.
It broke exactly where the 2mm support bolt contacts the band clamp.
See page 28 at https://si.shimano.com/pdfs/dm/DM-DA0001-10-ENG.pdf
My guess is that the support bolt was never tightened properly or tightened too much. It only has to be just barely touching the band clamp.
Odd that it snapped when shifting the rear and not when shifting the front. I would have liked to have heard it blow.
Glad nobody was hurt! I'm going to the garage to check the 2mm support bolt on my Di2 bike right now. Its been about 2 years since I touched it.
-Tim-
TimothyH is offline
Old 03-15-19, 06:37 PM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
-Tim-
Huh...that's a great point! Just barely touching huh? Dang it, now I have to go back and double check and hope it doesn't mess with the alignment....brb
jadocs is offline
Old 03-15-19, 07:16 PM
jadocs
jadocs's Avatar
Quoted: 941 Post(s)
So I backed it out, then turned it back in until I felt it touch, re-checked the torque and made some fine adjustments on the adjusting bolt and trim.
jadocs is offline
Old 03-15-19, 07:26 PM
Psimet2001
I eat carbide.
Psimet2001's Avatar
True on the support bolt. In which case it was most likely over-tightened (my guess).
