Spoke nipples unscrew on 32h FW rebuild
Mad bike riding scientist
Quoted: 6147 Post(s)
Liked 4,093 Times
On the other hand, I see a whole lot of OEM wheels that are poorly tensioned and even out of dish which is something that should have been checked at a bike shop as part of the preparation process before sale. I fix those…when I have time, which isn’t often.
Stuart Black
Stuart Black
Quoted: 597 Post(s)
Liked 768 Times
Based upon what? This was your first wheel build by your own admission and you had spoke nipples unscrew. If you read just a little bit about building wheels, you’ll find nearly universal suggestions on using a spoke preparation of some kind. Even back in the day, people used linseed oil for the same purpose. Modern spoke preps are easier to use as they dry faster.
HTH, Joe
working on my sandal tan
Quoted: 3868 Post(s)
Liked 2,560 Times
I mostly use oil when building wheels, but am not opposed to other things like linseed oil, Spoke Prep, beeswax, or blue/purple Loctite. Belt and suspenders.
It's not uncommon for my wheel builds to get interrupted by something else, some don't get "done-done" for a couple of days, so I tend not to use anything that would harden soon after applying.
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 248 Times
Every co-op I’ve been to has such an (over)abundance of wheels that there is no need to build or even rebuild wheels. There’s also never enough volunteers with the proper skills nor time to do wheel builds. There’s too many other things that need to be done in a co-op to spend the time building wheels.
Liked 4,093 Times
You need to characterize your co-op statements to indicate just Colorado. Just because it is that way in your area doesn't mean it applies everywhere else. Our co-ops are managed and operate differently here in CA. They align and build wheels although I can't say they do a very good job.
Stuart Black
Stuart Black
Quoted: 327 Post(s)
Liked 248 Times
You seem to assume everything is the same as your area. I noticd that in many of your posts. Yes things are different here.
You can choose to believe or not, I don't care. Yes many of our co-ops do wheels too. You carry on like you are the only one that is familiar with co-ops. I find most of your posts patronizing. Were not all out to diminish your bike BF stature.
Likes For frogman:
Liked 4,093 Times
Retail shops where someone might spend that kind of money for a set of hand build wheels don’t usually build wheels either. 40 years ago probably half the mechanics in shops knew how to build wheels. Today, I’d put it at 1 in 10 if that. There’s just no money in wheel building.
As to building wheels, I really doubt that even if a co-op dealt in building wheels, they would build enough for them to be a notable problem in a retail bike shop. On the other hand, if they did build enough of them to be a notable problem in retail bike shops, people would stop buying them which means a co-op would quit building and selling them.
Stuart Black
Stuart Black
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Quoted: 327 Post(s)
Liked 248 Times
I “assume” that because it is mostly true. I have traveled a lot by bicycle or with a bicycle in the US. I’ve been to many bike shops and co-ops across in the US. They are all very, very similar. Bike shops will offer new bikes and tend to not work on older bikes. Co-ops are nonprofit, bare bones, volunteer oriented operations that deal in old bikes and old bike parts while depending on donations of bicycles, equipment, money, and time from the community. They also tend to serve clientele that is probably not going to drop $500 or more on a set of hand built wheels.
You can quit trying to convince us that everything is as your assumptions indicate and you keep repeating yourself. A nice smoke screen but the fact remains it is different in CA than in CO. :-) When you find yourself down in a hole its time to quit digging. Our shop has two mechanics that formerly worked in co-ops and we trained to be first class mechanics. And yes they built wheels. We all are enjoying your crazy comments.
Quoted: 2332 Post(s)
Liked 2,094 Times
I've never seen or heard of a bicycle coop.
I use linseed oil on round spoke threads or just nothing on aero flat spokes
Bikes: lots
Liked 2,932 Times
Likes For cxwrench:
Quoted: 2304 Post(s)
Liked 2,742 Times
As to OP's question, that that loosening is really wierd, Could be not enough tension or using lube on the spoke threads, not on the nipple wheel interface.
Another possibility is that the tire pressure is too high, causing flexing and loosening of spokes. I got this information from a well regarded shop that is building a wheelset for me (I am building a different one myself.....got to get good at it) and they noted that going from a 28mm tires (gp5000) (run and 95 back, 90 front and i am 240) to 32 mm i should drop about 8 pounds pressure and going to a wider rim I should drip another 8 lbs, otherwise there is flexing and spokes loosen. I was multi tasking and so did not get the mechanics down pat, but this could be a consideration
as to all the other stuff
here is a link where the poster said his shop doesn't work on 10 speeds any more https://www.bikeforums.net/bicycle-m...placement.html
my local bike charity does build wheels and has the full gear high spoke cutting and threading machine, all the park tools and gauges etc.
Bicycle co-ops or bike kitchens are around all over the country
I see a wide mix of skills in local shops, the ones that have been around work on pretty much everything but the knowledge of vintage bikes is going fast. Chain and "trek and specialized" stores seem to focus on sales and some service
Lots of variations even within the county I live in (santa Clara County in CA)
Half way there
Quoted: 985 Post(s)
Liked 879 Times
Salvaged wheels from donated bikes are either in good enough shape to be trued or they are tossed into the scrap metal bin. An exception would be a higher end wheel where the hub and maybe the spokes are salvaged. The bottom line here is that we rarely have good bare rims with which to start an efficient building process.
Likes For Moe Zhoost:
Liked 2,094 Times
Liked 2,560 Times
Another possibility is that the tire pressure is too high, causing flexing and loosening of spokes. I got this information from a well regarded shop that is building a wheelset for me (I am building a different one myself.....got to get good at it) and they noted that going from a 28mm tires (gp5000) (run and 95 back, 90 front and i am 240) i should drop about 8 pounds pressure and going to a wider rim I should drip another 8 lbs, otherwise there is flexing and spokes loosen. I was multi tasking and so did not get the mechanics down pat, but this could be a consideration
Some professional wheelbuilders will install a tire and pump it up for their final truing, to check if the wheel goes out of true or particular spokes get too slack. If it's the type of setup to drop a lot of tension, the temptation is to really crank up the spoke tension, but you need a good way to ensure that you're not exceeding the maximum tension rating.
Likes For ThermionicScott:
Bikes: lots
Liked 2,932 Times
It seems like you're either not paying attention to or not understanding the OP's question. He's not asking about spoke windup but spokes loosening after riding the finished wheel. Round or aero doesn't matter...if you're going to prep the spokes to keep them from loosening later you're going to prep whatever you're building with.
Likes For cxwrench:
Liked 2,094 Times
I gave him a one sentence answer ions ago as have others.
Spokes on properly tensioned wheels do not loosen.
OP probably does not know what proper tension is or how to achieve it and therefore, the discussion moved beyond his error(s).
Furthermore, you are the one making thread detours. I simply listed how I prepped my spokes and then you got all smartie with me and now you are saying I failed to understand the OP. Geesh
Quoted: 327 Post(s)
Liked 248 Times
Our local co-op has plenty of salvaged wheels so there is little reason to build them. Occasionally a volunteer will spend some time building a few just for the experience or to help another member, but this is not common.
that was turned in that had very little use. Fully Campagnolo Super Record equipped. The co-op's around here cater to the Silicon Valley area in the SF south bay and our north bay. Large segments of our areas are quite affluent. Mercedes in the driveways :-) People buy their bike and they keep them in their garage and don't ride them and turn them in. It is a decent tax write off to donate them. I have been trying to point out it is incorrect to stereotype the co-ops. They are not all the same.
Likes For frogman:
Bikes: lots
Liked 2,932 Times
You are the one not paying attention.....
Quoted: 1074 Post(s)
Liked 295 Times
One thing I’ve seem listed as contributing to the risk of unwinding on radial laces is that on a cross-lace, there may be a tiny bit of bend between spoke and nipple, as the nipple may not be entirely free to swivel enough to match the alignment of the spoke perfectly.
This mismatch, tiny as it is, creates a little more friction in the threads compared to in a radial lace.
Should ride forces ever cause a spoke to go slack, this friction might keep a cross lace from unwinding where a radial would.
Likes For dabac:
Quoted: 597 Post(s)
Liked 768 Times
A radial pattern on a hub that’s not driven or braked, is not assumed to put more tension on the hub. However, the direction of the pull takes a path through the flange where there is less material present, which is why hubs not intended for radial lace sometimes crack at the flange when laced radially.
Liked 4,093 Times
Stuart Black
Stuart Black
Twistgrip
I used loctite once. I never did it again. It provides insufficient working time and locks the spoke so you end up adjusting the others to match. My wheels improved once I started lubricating my threads. I usually have to re-tighten a couple of times during break-in.
Upon reflection: new rim with new spokes works well and stay put. I often use old rims. They usually need a couple of readjusts.
Quoted: 3355 Post(s)
Liked 5,434 Times
I've been building my own wheels for 25 years, using Triflow to lubricate the nipples, and never had a spoke loosen. My primary reason for lubricating the nipples, is to reduce friction on the outside of the nipple, where it contacts the rim. It makes adjustment easier on rims without grommets.
Now I did have an occasion where spokes loosened on a wheel I did not build. This was an almost new 1994 Cannondale.
Now a few days earlier, I had to take emergency evasive action to avoid being killed by an idiot cager who came flying around a corner where I was legally using the MUP crossing at a major highway. I instinctively threw the bike 90 degrees to the direction of travel to stop, which would have been a "lay down" in the motorcycle world. I'm thinking this sudden side loading of the rim might have triggered the spoke loosening, but I just don't know.
Bikes: lots
Liked 2,932 Times
Inappropriate use of "Now" at the beginning of a sentence. 10 yard penalty and loss of down.
Likes For cxwrench:
