Shimano cassette lock-nut question
Quoted: 112 Post(s)
Liked 25 Times
11 spd Shimano lock nut is label "11 spd only"
.Will this lock nut cause a problem on a 10 spd Shimano casstte?
The Sram locknut does not specify a spd.
Expired Member
Quoted: 3653 Post(s)
Liked 5,391 Times
I don't think you'll be able to engage it on a 10 speed cassette.
Quoted: 6177 Post(s)
Liked 4,794 Times
Shimano probably has a reason. I doubt it's a conspiracy to make you buy more lock rings. Even if you have to buy the entire cassette to get one, that doesn't sound like something that's going to make Shimano much money.
Even if it fit and seemed to hold everything securely, I'd probably still replace it with the correct lock ring when I could get one.
Likes For Iride01:
Bikes: yes, i have one
Quoted: 1136 Post(s)
Liked 1,179 Times
I think the only difference is either the outer diameter of the ring or the thickness, can't recall which. One or the other was to accommodate 11 speed or 11 tooth cog.
Likes For spelger:
Quoted: 1943 Post(s)
Liked 2,164 Times
It is thread length.
11t cogs sit further out so you need more threads on the lockring. There might be a diameter issue, but I’m skeptical of it as I’m running a 1st position 14t cog for an 11 speed CS-6800 with an 11t lockring.
If it torques without the threads going too deep, you shouldn’t have an issue.
John
John
Quoted: 112 Post(s)
Liked 25 Times
Thanks for responding.
Using a 10 spd cassette with the 1.85mm washer, proper thread engagement, and torqued down per spec.
If there is no play in the cassette I should be ok.
Expired Member
Liked 5,391 Times
Quoted: 2026 Post(s)
Liked 1,095 Times
I'm using that exact combination on a Shimano 11-speed freehub body. A 10-speed Shimano cassette and the 1.85mm spacer with the OEM 10-speed lockring and it torqued down properly with no play or movement. It has worked fine for several thousand miles.
