Nagging question: is "vulcanizing fluid" just plain old rubber cement?
Old 11-05-18, 02:00 PM
  #76
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22596 Post(s)
Liked 8,925 Times in 4,158 Posts
Originally Posted by cthenn
3 pages on rubber cement, TLDR, but I use Slime rubber cement. Came in one of those "standard size rubber cement" canisters, and cost me like $8. I'm sure it will dry up before I use it all, but the times I've used it, it's worked perfectly. Important part is getting the legitimate Rema patches though.
But is rubber cement the same as vulcanizing fluid?
Originally Posted by rjones28
Addiction is all about class.
datlas is online now
Old 11-05-18, 05:06 PM
  #77
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3587 Post(s)
Liked 3,400 Times in 1,934 Posts
Originally Posted by nycphotography
I have run out of patches. Where can I get "quality patches in bulk"??
(Seriously, I am ready to order asap, as I need to glue one inside a tubeless tire that won't seal).
You can get a box of 100 Rema patches for less than US$20:
https://www.amazon.com/Rema-25mm-Round-Patches-100/dp/B0017RV5K4/ref=mp_s_a_1_1/135-9705877-8216945?ie=UTF8&qid=1541459081&sr=8-1&pi=AC_SX236_SY340_QL65&keywords=rema+tire+patch&dpPl=1&dpID=61zJxEIZkmL&ref=plSrch
JohnDThompson is offline
Old 11-05-18, 05:22 PM
  #78
cthenn
Bikes: 2023 Canyon Aeoroad CF SL, 2015 Trek Emonda SLR, 2002 Litespeed Classic, 2005 Bianchi Pista, Some BikesDirect MTB I never ride.
Quoted: 647 Post(s)
Liked 136 Times in 89 Posts
Iowknow....all I know is it works sealing inner tube punctures!
cthenn is offline
Old 11-05-18, 05:32 PM
  #79
GuitarBob
Kit doesn't match
GuitarBob's Avatar
Bikes: 5
Quoted: 187 Post(s)
Liked 27 Times in 19 Posts
I find the 25 mm patches too big for most road tubes, so I use the 16 mm jobs:
https://www.amazon.com/Rema-F0-P-16m.../dp/B001S36CNC
https://www.amazon.com/Rema-25mm-Rou...kmL&ref=plSrch
GuitarBob is offline
Old 11-05-18, 05:40 PM
  #80
cruiserhead
Quoted: 42 Post(s)
Liked 6 Times in 6 Posts
vulcanizing glue is not the same as rubber cement.
The reason you see some patch kits w/ glue say "rubber cement" is the same reason this exists:
vulcanizing cement works with the backside of the patch to chemically bond to the innertube
rubber cement is just an adhesive
cruiserhead is offline
Old 11-05-18, 08:47 PM
  #81
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 923 Times in 569 Posts
I loaned out a bike & it got a big staple in the tubular tire.
The little patch kit glue tube was partly gone off, & one of the patches (staple went all the way through the tube) didn't hold.
Redid it with contact cement, which worked well.
Apparently, the above sign means "keep off the grass".
woodcraft is offline
Old 11-06-18, 06:37 AM
  #82
nycphotography
NYC
nycphotography's Avatar
Quoted: 1169 Post(s)
Liked 107 Times in 62 Posts
"I like your smile (I bet you do from down there!!) but don't like when you step on my face" = keep off the grass with some chinese humor. I imagine some of those symbols may have some interesting double meanings.
nycphotography is offline
Old 11-06-18, 10:37 AM
  #83
popeye
Bikes: S works Tarmac, Felt TK2 track
Quoted: 359 Post(s)
Liked 179 Times in 111 Posts
Could you please run a test using just inner tube for a patch?
I bought a bag of little tubes of glue from China some years ago
but the patches failed. No one else has suffered this fate so
perhaps it was just an outlier.
popeye is offline
Old 10-13-19, 01:47 AM
  #84
chimpanzee
Originally Posted by DannoXYZ
Quick glance through ingredients shows:
Elmer's No-Wrinkle Rubber Cement
>70% Heptane
20-25% natural latex rubber
1-5% Isopropol alcohol
Rema Vulcanizing Fluid
60-95% Naphtha, petroleum, hydrotreated light
1-2.5% N-Ethylcyclohexylamine
other brands also contains: acetone, heptane, trichlorethylene, zinc-dibutyl dithiocarbamate/dibutylamine
Now we can see that the office-stationary "rubber cement" is clearly of different composition than "vulcanizing fluid" regardless of how it's labeled. Leave a bottle of rubber-cement open and you end up with a ball of rubber about 25% the size of the container. Leave a bottle of vulcanizing fluid open and it evaporates to nothing; very different stuff. The N-Ethylcyclohexylamine is a vulcanizing accelerator/catalyst which speeds up vulcanizing enough to occur at room-temperature (heat does the same thing). Ever see "RTV" on various rubber-sealants like caulk? The red uncured rubber on the patches provides the sulfur and in the old days with skinwall tyres, you can see a brown circle appearing on your tyre if you install the patched tube right away. This is caused by the release of various gases during the curing process.
A lot has changed in the past 20-30 years. Just because there was only one way to vulcanize rubber 30-years ago, doesn't mean that technology hasn't improved. Look at how materials technology has improved in frame materials, and how mechanical engineering designs created index shifting. Auto and computer technology has improved significantly in the past 30-years.
In the end, it's not an all-or-nothing, black & white, yes/no issue on patches. It comes down to a shades-of-grey on how well various compounds holds a patch to a tube. I'll do a demo video of "rubber cement" versus "vulcanizing fluid" after 24-hrs curing and show how easy or difficult it is to pull off a patch using both these products.
You can get 8oz Slime rubber cement can for $6 at Pep Boys (more than twice expensive $15 on Ebay)
https://www.pepboys.com/slime-rubber...478?quantity=1 ]
via https://cdn.shopify.com/s/files/1/22..._-_NA.pdf?1202
3 Composition/information on ingredients ·
Chemical characterization:
Mixtures · Components:
8032-32-4 Ligroine 40-60%
9003-35-4 Formaldehyde, oligomeric reaction products with phenol 10-20%
586-62-9 Terpinolene Asp. < 10%
The chemicals don't match the ones for Rema (see above, in BOLD RED)
Someone correctly pointed out, it's better to match REMA vulcanizing fluid with REMA patches (which I like, you can get 100 pack for $16 from Ebay)
I've used Elmer's Rubber Cement with varying success with REMA patches. Sometimes they seal, sometimes they don't
See also this other thread:
https://www.bikeforums.net/bicycle-m...-cement-4.html
chimpanzee is offline
Old 10-14-19, 09:43 AM
  #85
Spiduhman
Spiduhman's Avatar
Bikes: S2, Wilier GTR (Arr), Giant VT, Myata 3-10
Quoted: 17 Post(s)
Liked 6 Times in 3 Posts
" on 16mm Rema patches for almost all road tube repairs, also " on the 100 pack. The next size up are handy for mountain tubes and bigger road tubes - just to use the patches, mostly, as 16mm are sufficient for punctures, if not cuts...
I get the smallest tubes of glue to carry with on the road - best not to open/puncture the seal until needed, then carry two tubes of glue, the opened one and a new one as well. I carry a spare inner tube, so hardly ever patch on the road.
The larger tubes of glue stay home.
Try this: before putting your tube of glue away after use, hold it cap side up and carefully squeeze out all the air, such that an arc of liquid is bulging out, then put the lil' lid on there - now there's no air in the tube, and you've lost only the solvent that's evaporated whilst the cap was off (an' don't leave the cap off while playing with your patch). Big difference, you'll find, especially if you're never allowing atmosphere to be drawn into the tube of glue in first place - uncap, maintaining pressure, squeeze out your drop, recap. Carry on.
Spiduhman is offline
Old 10-17-19, 04:40 AM
  #86
chimpanzee
I just bought 8oz Slime rubber-cement (has an activator element, plus solvent) from Autozone for $6, designed for car tire repair.
[ Can also be obtained from Pep Boys for $5.36 (20% sale), or Walmart for $5.97 ]
The patch with Elmer's rubber-cement failed for a 700c tube. I cleaned it up, & used Slime rubber cement. The instructions made no mention of allowing it to completely dry (as in REMA vulcanizing vluid), so I applied the (used) patch with cement still wet (I did allow it to dry somewhat). It seems to work..!!
I returned the Elmer's Glue to Office Depot.
I've had car tire repairs, using a patch. The tire guy used a grinder to clean the roughen the tire, applied glue (Slime, Xtra Seal, whatever..), applied patch, then used a pizza-cutter type of tool to press it in.
Old 10-17-19, 12:11 PM
  #87
Colorado Kid
Quoted: 358 Post(s)
Liked 136 Times in 82 Posts
Just got back from the local farmer's supply store and yes, they have Rema (And other brands) patch kit for sale. Tractor size...I guess you could cut them down or sell off the extra. No, I'm not a Farmer but they do have good prices on a lot things.
Colorado Kid is offline
Old 10-18-19, 12:49 PM
  #88
firebird854
Bikes: 2016 Specialized Tarmac Expert
Quoted: 258 Post(s)
Liked 114 Times in 62 Posts
This post was interesting.
firebird854 is offline
Old 05-03-20, 02:53 PM
  #89
Oneder
Bikes: Wahoo of Theseus, others
Quoted: 428 Post(s)
Liked 67 Times in 46 Posts
So in essence can I use elmer's if I cut up an old inner tube or not? Do I still need special patches? What is different about the patches if so?
Oneder is offline
Old 03-28-21, 09:52 AM
  #90
wesley77803
Bikes: 1989 Trek 660, 1985 Trek 620
Quoted: 10 Post(s)
Liked 12 Times in 5 Posts
The picture on Amazon looks just like the Slime rubber cement picture in the previous posts.
From https://www.amazon.com/ask/questions...k_ql_ql_al_hza
Slime 1050 Rubber Cement - 8 oz.
Is this product considered to be a vulcanizing cement like xtra seal so that it can be used with mushroom type patches for radial tires?
The rubber cement itself is not vulcanizing. It activates with appropriate patches that are vulcanizing. It will work with all Slime patches to achieve your desired results.
ITW Global Brands
Manufacturer · June 25, 2018
wesley77803 is offline
Old 03-29-21, 05:15 PM
  #91
Duo
Bikes: The Good Book of bicycling
Quoted: 535 Post(s)
Liked 36 Times in 29 Posts
Harbor Freight still sells a big tube of patches, now $5. https://www.harborfreight.com/inner-...kit-47614.html
Still the same problem with the tiny glue tube. Think I need to look at the big bottle Slime rubber cement as my patch collection multiplies when the glue dries up.
Most of us have been told that the rubber cement is special in these patch kits, and very well may be for some kits. thanks for the study.
Duo is offline
Old 08-06-22, 07:24 AM
  #92
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Liked 582 Times in 399 Posts
Originally Posted by rpenmanparker
I'm telling you that vulcanizing fluid is just rubber cement, period.
Originally Posted by RPK79
Is this the definitive answer?
How about running some through the old HPLC?
sweeks is offline
Old 08-06-22, 07:28 AM
  #93
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
If you have a can of the fluid, storing it upside-down is said to achieve the same result.
sweeks is offline
Old 08-06-22, 07:54 AM
  #94
Spiduhman
Spiduhman's Avatar
Quoted: 17 Post(s)
That should keep the container from "breathing" past the lid, however, the rigid container means a new pocket of air each time the container is opened, and subsequent loss of volatile component, likely insignificant at first, but adds up quickly when the container is part full, having been opened and shut many times by then, a large batch of air each time, etc.
Ride on!f
Likes For Spiduhman:
Old 08-06-22, 08:05 AM
  #95
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
Ride on!f
what if you open it upside down?
Sy Reene is offline
Likes For Sy Reene:
Old 08-06-22, 10:30 AM
  #96
sweeks
sweeks's Avatar
Quoted: 980 Post(s)
Ride on!f
For the sake of argument, that assumes a complete exchange of air each time the container is opened... which may not occur, especially if the repairperson is expedient. But of course, there will be some loss of solvent, and it will increase over time. As often as *I* patch tubes, though, that can will last a good long time!
sweeks is offline
Old 08-06-22, 12:20 PM
  #97
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
It's too bad nobody's selling a reasonable ketchup packet (or smaller even) version of this stuff. Heinz goes for $.10/packet and that includes the ketchup. Take an 8 ounce jar of Rema for $20 and divide to little 3 gram packets would/ should be doable at about $.30/packet.
Sy Reene is offline
Likes For Sy Reene:
Old 08-07-22, 11:12 PM
  #98
SproutsChoppers
GlueSniffer
SproutsChoppers's Avatar
Bikes: Green Machine Big Wheel trike
Originally Posted by woodcraft
To make this a really classic thread, they should be lit on fire while on the bike.
Kudos for the inquiry.
Word to thine mother! All repairs and scientific inquiries should be seteth on firethFYI
SproutsChoppers is offline
Old 08-08-22, 08:03 AM
  #99
datlas
datlas's Avatar
I don't think we ever definitely solved the question, but the OP has left the building. Sad!
Old 08-09-22, 05:54 AM
  #100
nycphotography
NYC
That sounds ominous :-(
