Cannondale R1000 crank replacement
Bikes: 1984 Nishiki Touring, 1999 Cannondale R1000 Triple CAAD3
I have a 1999 Cannondale R1000 Triple CAAD3 road bike with I believe all stock components. The middle of the 3 crank gears is really worn down and not really usable. I’m wondering if anyone knows of a replacement middle crank in the set, and where I can get it. Also, would it be worth replacing the entire group set? The cassette is a 9 speed, and I’d be interested in putting on a 10 or 11 speed. Any suggestions? Thanks
Quoted: 8279 Post(s)
Liked 9,033 Times
What crankset is it? Is it Coda, Ultegra, 105?
They're called chainrings and depending on what you have they might be hard to find. You can probably use flat rings if you can't find what you now have. You have to use the same bolt circle.
If the middle ring is worn the others may be also, as well as the chain and cassette.
I recently replaced the chain and center ring on an Ultegra equipped bike. I found a used 105 ring which looked different but works fine.
To switch to 10 speed you have to change the shifter and would be a pain and not worth it unless you got everything free.
Liked 9,033 Times
Looks like it might be Ultegra.
Cannondale Bike Catalogs-1999 Vintage Cannondale Catalogs :: Live in the moment (tistory.com)
