Trouble mounting a 25 mm tire
I like to use 25 mm tires for commuting, but it is very difficult to mount the 25 mm tires that I use (continental ultra sport II wire bead) on my rims. I usually have to use soapy water and pump it up to max pressure before the tire will seat properly-- not very convenient when I get a flat out on a ride. Other than getting a new wheelset, I was hoping for some suggestions--other brands that maybe easier to seat, wire vs. folding...
Thanks
Thanks
The Infractionator
Bikes: Classic road bikes: 1986 Cannondale, 1978 Trek
Quoted: 875 Post(s)
One of the things you should expect with Continental tires is that they will be a b***h to mount....
Quoted: 276 Post(s)
Liked 6 Times
I had one tire/rim combo that was a real pain to mount until I bought one of these:
https://www.amazon.com/Kool-Stop-Tir.../dp/B001AYML7K
It's a great investment even if you use it once. It saved me hours of frustrations and skin being torn off my fingers. It's small enough to fit in a jersey pocket. I actually use mine every time I mount tires now just because it makes it so easy
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
Thanks
Thanks
Bikes: Lynskey Backroad; Lynkey Cooper CX
Quoted: 14 Post(s)
Liked 18 Times
Thanks
Thanks
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Quoted: 1438 Post(s)
Liked 1,092 Times
I use a thin rim tape (Continental Easy Tape) instead of the more common Velox cloth tape; it is thinner and more slippery thus making tire mounting much easier.
If you need a tool like a bead jack to mount your tires you had better have it with you on the road or you will have a long walk home. I won't run a tire/rim combo I cannot easily mount by hand; I might need to do it when it is getting dark and/or raining at the end of a long, tiring day. Isn't that when you always get a flat?
