Brinelling headset
Brinelling headset
Hey guys I've been working on this Pinarello Treviso flat bar road bike and when I went to adjust the headset I realized that the races are probably trashed Has the worst case of indexing I've ever seen. Did a bunch of research and found that replacing with loose ball bearings will sometimes fix the issue. The problem is that the fork is stuck in the head tube, and no amount of hammering will get it out. Seeking advice on if anyone knows a trick or if it should just be ridden like this. Thanks in advance guys
Fork stuck in head tube? Or, did you mean: stem stuck in fork steerer tube?
Likes For gearbasher:
Quoted: 2026 Post(s)
Liked 1,096 Times
Until that problem is solved, nothing else matters. Is this a threaded fork and the stem is stuck? The usual fixes include penetrating oil, heat and sometimes hacksaw blades.
Likes For HillRider:
Quoted: 3510 Post(s)
Liked 2,924 Times
Yeah--have to wonder here. How is the fork stuck?
Sorry I realized my post makes no sense lol I can't post pics yet because my profile is new. The steerer tube is stuck in the headset. Stem and spacers are off. There's play in the top bearings so it must be stuck on the bottom bearings
Liked 2,924 Times
I'm old-school, so I can't imagine a fork being stuck after the top headset pieces have been removed.
Quoted: 912 Post(s)
Liked 515 Times
Liked 2,924 Times
I'm thinking if the fork can't be removed--even after hammering??--there must be all kinds of problems going on here.
Mother Nature's Son
Quoted: 853 Post(s)
Liked 1,434 Times
My thought is maybe the steer tube has somehow been bent or misshaped. If not, maybe try PB Blaster and let it sit for overnight, then try to get it out. What kind of hammer and how hard are you hitting it. With just the bottom is stuck, it seems to me it should not be that difficult, if it is from corrosion. I have doubts about that. As suggested, get a couple of pictures loaded into the gallery.
Likes For delbiker1:
Quoted: 1943 Post(s)
Liked 2,164 Times
Liked 2,924 Times
Trying hard to imagine how a fork can be stuck at the bottom bearing.
Quoted: 569 Post(s)
Liked 581 Times
Bearings with false brinelling (bearing damage looking much like brinelling but is not) is caused by fretting and can occur with corrosion so I agree with delbiker1 use PB or Kroil or any penetrant lubricant to soak.
Likes For easyupbug:
Liked 2,924 Times
Quoted: 6193 Post(s)
Liked 4,808 Times
How are you experiencing the brinelling?
If you overtighten most any set of bearings, then they will feel bumpy or grinding that might be mistaken for brinelling. However it's not brinelling. It's just that you tightened them too tight and they are doing what I and others sometimes call indexing. It's just that they can't sit properly in the races from the excess compression put on them.
For bikes that have loose bearings, one also might experience a similar thing if too many loose bearings are put in the races and they don't have enough space to find their proper position on the races.
Liked 2,924 Times
"Indexing" to me means he has a headset that is completely worn out--there is a noticeable index or "indent" when the bars are placed straight ahead, indicating that there actually is an indent in that position (since the bars are facing straight ahead 90% of the time, and taking bumps in that position that eventually leads to an actual indentation in the race). This would feel noticeably different than a too-tight headset.
As Hillrider mentioned, the headset problem seems to be the least of his worries.
Liked 2,924 Times
Liked 2,164 Times
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,379 Times
Liked 2,924 Times
Does the fork still turn easily?
I'm not familiar with that Pinarello model, but I looked it up and it looks like a nice, classic lugged steel road bike. Assuming it is, the fork should have simply dropped out with no force whatsoever when you removed the stem or any other clamping hardware.
Quoted: 836 Post(s)
Liked 1,061 Times
I'll throw this out there not knowing enough details but, I see this newer Pinarello Treviso has a Carbon Fiber fork and frame. Question is if the steerer is aluminum or CF. If alu there is a chance the top headset race is stuck from corrosion or as mentioned a slightly ovalized upper steerer tube. Let some penetrant soak a day or so around the upper race and steerer then give it some good wacks (not a bludgeoning) with a wood block resting against the top of the tube and a hammer.
I have an American Classic sealed bearing headset on one of my bikes. The fork crown race (actually it's not really a race, but a seat for the inner race of the lower bearing) fits tightly in the inner race of the lower sealed bearing. When I need to remove the fork, it's stuck pretty tight. But, a moderate whack with a foot long section of 2x4 pops it right out. So, I can't picture how his fork is stuck in the head tube.
Liked 2,924 Times
This is a head-scratcher... Wish cjorg would come back and answer some of our questions. He could get his post-count up too!
Likes For smd4:
Liked 2,164 Times
If you can get the top cup out of the head tube, you might be able to slide a tube inside the head tube between the steerer and the inner wall of the head tube.
It needs to be long enough to be able to tap out the bottom cup. If you can get the cup out of the head tube, you can deal with the getting the steerer loose outside of the frame.
John
John
