Motobecane 707 , year 1985???
Bikes: Motobecane 707
Hi, just recently bought Motobecane 707 road bike. And straight away want to update it with new components. Just had new seat, a new break pads . Order a new handlebar and stem for more comfort ... I thing I need it. Have done just 300km with Continental road tyres ( just do some light gravel also ) . Guys dont judge me please , never ever had my own bicycle, this one my own . Pictures will update later on. So the think is I want to update it with 10,11 or 12 speed groupset ( budget around up to 600 euros ) . I need your help here guys to find out what bottom bracket I could use with compatible crankset?
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
Hello and Welcome to the forums. What country are you and the bike in? First of all while upgrading to a comfy seat is good idea and new brake pads will make it safer I'd hold off on other upgrades. Do you have any pics?
Depending where you are upgrading a French bike can be complicated. Until some point in the '80s French bikes used a French thread bottom bracket rather than English or Italian like most manufacturers, they also had a slightly smaller stem, I think 22.0 instead of the more 'standard' 22.2 so you may not be able to easily find a replacement.
Personally unless the bike has a full ChroMoly steel frame and fork I'd enjoy it like it is and look for a nicer newer bike to upgrade.
Sugar "Kane" Kowalczyk
Hi, i live in Germany , as long as I know bicycle was bought localy couse there is label of the city that I live near. At the moment I cant post pics or url , it says after 10 post I will be able
Quoted: 5888 Post(s)
Liked 3,471 Times
Yeah, that's an anti spam measure. You can post pictures to your profile. Someone will then post pictures to this thread.
Liked 3,471 Times
That's an 80s Motobecane. I should have said that we will need pictures of the drive side showing the crank, derailleurs, etc. Also pictures of any tubing stickers saying what kind of metal was used are also very useful.
Bianchi Goddess
Liked 2,923 Times
Well there’s pictures and then there’s pictures. Not much detail here
Stop reading my posts!
Quoted: 1442 Post(s)
Liked 1,059 Times
never heard of a Moto "707" so most likely a model for the FR or European market.
My guess is by '85 Moto was not using either FR or Swiss BB threading, but OP can perhaps pull off one crank and read ALL the markings on a cup, what I can read in the single pic tells me almost nothing, then pull the other and measure the spindle length.
With that info shopping for a new BB should be easier (better than guessing).
Likes For unworthy1:
SE Wis
Quoted: 2743 Post(s)
Liked 3,390 Times
Two things determine what bottom bracket (BB) you need.
The crankset itself determines length and type of BB
The frame (shell width, threading or lack of threading)
Until you decide what crankset you want to run and what your shell is, no one can tell you what BB you need.
Liked 3,471 Times
Easiest and cheapest way to get modern gearing is to buy a set of wheels, cassette, chain, rear derailleur, and a set of microshift bar end shifters like these, https://www.microshift.com/models/bs-m10/
That way you can continue to use the original crank. You will want to overhaul the bottom bracket though. You also will need to spread the frame a bit since it is likely set at 126 mm and modern road wheels are generally 130 mm. This is likely the cheapest, most cost effective way to go 2 x 10 on that bike. Plus indexing bar end shifters are nice.
A compact crank (50/34 or 46/30) would be a nice upgrade as well but you have a budget of 600 euros. You may have to skip the crank for right now to pay for the other stuff you need to get 2 x 10 gearing.
