2019 Trek Stache 5 - what to upgrade?
I just had my LBS order a Stache 5 for me. I really wanted a Stache 7, but couldn't bring myself to spend the extra $600-$700. In an attempt to get the low gearing similar to the Stache 7, I am having him install a SunRace 11-46T cassette. He offered to set me up tubeless at no cost. Is there anything else that should be upgraded before I pick it up?
FWIW, even stock, this bike will be a significant upgrade for me. I am coming from a 17 year old Trek 4500.
Save your money until you get a few long hard rides in. Pedals, grips and seat can make a big difference in comfort and therefore enjoyment. After those are figured out the next upgrade is tires for me, assuming the stock ones usually aren't perfect for my riding
Likes For eshew:
Thanks.
The LBS offered to set me up tubeless at no cost. I am assuming that means labor and sealant because the bike is supposed to be tubeless ready. I have never done tubeless, as I have never seen a need to. My gravel bike is tubeless ready, but I have never had a flat or seen a need to run lower pressure, so tubeless just seemed like more of a hassle than anything else. I figured I will try it, but I also know that the LBS is probably counting on future sales of sealant.
I have been considering Jones h-bars as longer rides with flat bars usually result in my hands going numb. I can only imagine that this will be exacerbated by the wider bars of the Stache. Time will tell on that because I am not ready to dump that kind of $$$ on bars just yet and apparently people like them because I can't find any used ones for sale.
Bikes: Cannondale Six5, Specialized Stumpjumper FSR & old Hard Rock
Thanks.
The Jones bars have lots of sweep, 40 degrees? My sweet spot is 15-20. Very comfortable on the wrists. Salsa bend 2 bars come in 17 and 23 degrees. Tubeless is great, lower pressure, lots of grip. I recommend getting a 0-30 psi gauge and use it.
Quoted: 257 Post(s)
Liked 70 Times
congrats and welcome to the 29+ party!!!
have him save the inner tubes for you as backup
Ride her lots and have fun
If you plan to bike pack, check all the choices
Thanks.
Well set-up tubeless isn't a hassle at all in my opinion. Topping off sealant every few months (can vary depending on your climate) is not a big deal, especially with removable valve cores, which eliminate the need to break a tire bead to add sealant. Buy a big bottle of Orange Seal or Stan's and it will last you a really long time if only used to occasionally top off one bike's tires.
