Brand New Bianchi Campione 00s with Full Campagnolo Mirage/Veloce
Hello hello,
Can someone help post the pictures from my gallery album in this post please?
This Bianchi Campione was stored in a garage for over 20 years collecting dust. Condition is brand new.
Seems to be a 2001 Bianchi Campione with Campagnolo components.
derailer campagnolo mirage
brakes: campagnolo veloce
cranks: campagnolo veloce
Is it rare to have it in this condition?
ttps://imgur.com/FEYWPqG
Thrifty Bill
Quoted: 1236 Post(s)
Liked 964 Times
Is it rare in that condition? No. Bicycles are in the recreational/exercise category, a lot are bought and never ridden. Condition is all about how the bike was stored over the years. Once it comes out of a box, its not new. Even unridden, bikes degrade over time. Tires get dry rot, grease dries out, etc.
and some information:
Campione 2000
The 2000 Bianchi Campione is a triathlon/road bike with a chromoly frame. The frame comes in celeste or Metallic Yellow. It was released in 2000 and costs $1,049 brand new. Due to the frame materials and other factors, we estimate that this bike weighs around 20 pounds. The Campione 2000 is fully rigid.
Components
The Campione 2000 comes with Campagnolo Mirage components, including an ITM Alutig stem, an aluminum Bianchi headset and Campagnolo Mirage Ergo shifters.
Drivetrain
The Campione 2000 has 9 speeds and has a Campagnolo Mirage derailleur.
Wheels
It comes with Vittoria Zefir tires (622mm x 23mm) and Mavic CXP 21 rims.
Frame & Fork
Frame Construction TIG-welded
Frame Material Chromoly, double-butted
Fork Bianchi
Fork Materal Chromoly, double butted, unicrown crown
Rear Shock Not applicable
Components
Component Group Road Mix
Brakeset Campagnolo Veloce dual pivot brakes, Campagnolo Mirage Ergo levers
Shift Levers Campagnolo Mirage Ergo
Front Derailleur Campagnolo Mirage, braze-on
Rear Derailleur Campagnolo Mirage
Crankset Campagnolo Veloce, 39/53 teeth
Pedals Look 206
Bottom Bracket Campagnolo Veloce, 111mm spindle
BB Shell Width Unspecified
Rear Cogs 9-speed, 13 - 26 teeth
Chain KMC, 1/2 x 3/32"
Seatpost Bianchi aluminum, 27.2mm diameter
Saddle Selle Italia Trimatic
Handlebar Extensions Not included
Handlebars ITM Bianchi Anatomic
Handlebar Stem ITM
Headset 1" Miche Racing
Wheels
Wheel Size 700c wheels
Hubs Campagnolo Mirage
Rims Mavic CXP 21, 32-hole
Front Tire 700 x 23c Vittoria Zefir
Rear Tire Not Available
Spoke Brand Stainless steel, 1.8mm double-butted
Spoke Nipples Unspecified
Thrifty Bill
Liked 964 Times
Trying to sell on ebay is a lot different than successfully sold. In the end, your bike is not new, it's used. Now it may be in excellent condition, that is a plus for sure!
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
Bikes: Too many to list
Quoted: 1765 Post(s)
Liked 1,124 Times
I purchased a nice Univega in this condition a few years ago in similar condition to what you describe --- it was a 50cm with Campy Veloce triple groupset and a decent set of Fulcrum wheels
I gave the gent $275 and immediately stripped the bike and used the components to build a DeBernardi frameset i had recently aquired
I gladly paid the $275 and likely would have stretched it to say -- $325 due to the condition , but no more than that --- it was very nice to have a donor bike that i could re-use almost everything though but Veloce and Tig Welding just didnt add up to a lot to me at the time
If its Celeste green it might be worth $500 to somebody - who knows.
Edumacator
Quoted: 2439 Post(s)
Liked 3,124 Times
I suggest looking at comps for SOLD items on Ebay to get a general idea for the larger audience that is the world...then look at FBMP for what is might fetch in the local world.
We wouldn't want to steer you wrong with valuations...are you buying or selling?
Quoted: 1372 Post(s)
Liked 1,751 Times
Pic assist...
As already mentioned, the OP's bike is not brand new even though it might have seen very little use. As a rider, it is a very nice steed but as a collectable item, no so much. The Campy group is not matched, a bit of a draw back in my opinion. The frame is internally lugged and the uni whatever fork is equally of minimal interest to most collectors. To me, the handle bar tape looks to be poorly done and the rear derailleur cable is, again, unprofessional in appearance. Both of those things, though mostly cosmetic, will negatively impact value (my opinion). The celeste green is, indeed, a value feature as it the bike's condition. I might add that the bike is a popular size and will appeal to one of the larger markets.
Condition is always important and the OP's bike is in stunning condition, with only a couple of minor concerns. But an old bike, even a brand new or unused one, still needs maintenance attention. I, personally, no longer trust old tires and 22 years old is old. Nor do I trust grease in hubs, bottom brackets or headsets to be worthy of great lubrication abilities. Simply put, tires and grease do deteriorate over time. The same can be said for brake caliper blocks.
Is it rare to be in its condition? I would say yes but not super rare. Again, as mentioned, lots of road bikes were purchased with great "get fit" intentions in mind. Sadly, or not, depending on one's point of view, lots saw incredibility little use and found their way into early storage. Sometimes storage was excellent, allowing the bike to reach today in pristine cosmetic condition...
sometimes not so much...
I am not sure if the OP was seeking a value appraisal. Were I buying the bike, I would pay $500.00 in a heart beat. Were I selling the bike, I would ask for and hold out for $1000.00.
Friendship is Magic
Bikes: old ones
Quoted: 26418 Post(s)
Liked 10,380 Times
...Bianchi marketed all levels of bicycle over the years. The top of the line ones are pretty nice, if you get them roadworthy and put new rubber and bar tape on them. Yours is not one of the top of the line ones. We just had a long thread in the regular C+V about how people offer low valuations here, without sufficient consideration for all the factors. I confess I have zero interest in the brand newness of a bike that sat in a garage, gathering dust for 20 years. It sounds like something that will require at least disassembly of all the component parts, and reassembly with new grease. And probably new rubber all around.
It was sold as a Tri bike, which means it was not marketed or designed for the same audience as the classic bike people who are looking for one of their better models, made from Genius, or whatever was trendy in 2000. And Mirage is sort of a middle of the road package.
But good luck with the sale of it. I honestly have no idea what the value might be to someone looking for just that thing. I don't even know who that would be. Triathlon guys generally don't look for older tri bikes, they want the newer, lighter stuff. And the old bike guys don't look for them, because the real race bikes are more fun to ride. By the year 2000, Bianchi was selling a bewildering array of bicycles, including full suspension MTB's, aluminum, steel, and CF road bikes. If you Google up the 2000 company catalog pictures, you can get an idea of where this bike sits in the hierarchy.
Quoted: 3241 Post(s)
Liked 2,512 Times
Here's one from a flipper in my area. And another. And another. All are older lugged frames.
https://richmond.craigslist.org/bik/...497082915.html
https://norfolk.craigslist.org/bik/d...502504785.html
https://fredericksburg.craigslist.or...486528885.html
Quoted: 586 Post(s)
Liked 612 Times
Funny how people who should know better can't spell Campagnolo properly. Add to that the inference that this is or was worth $3,000.00 is beyond the pale.
I'm talking about the third one above, in Fredericksburg.
Technically true. The bike retailed for 1100$ in 88/89. That is 2,717.88$ today. If you include tax, you're around 3000$.
Thrifty Bill
Liked 964 Times
Savvy buyers will know a bike that has been sitting for a couple of decades will need a thorough service. I am not talking a bike shop tuneup.
Quoted: 586 Post(s)
Liked 612 Times
From an online calculator...
$550 in 1988 is worth $1,358.94 today
Friendship is Magic
Bikes: old ones
Liked 10,380 Times
...a whole lot of bikes back then did not sell for the MSRP, when first they were sold new.
There has been a lot of mission creep in the pricing of new bicycles since then, so maybe it rubs off by association.
Liked 1,124 Times
y.
y.
You sure? That looks like conventional road geometry and at that time period, tri bikes usually had 650 wheels, a pronounced upright seat tube and the bars to go with it IIRC .
Following as I have an older version myself 1976 bianchi Specialissima barcelona top of the line for the time all original campagnolo components and never ridden.
