How come OC rims never caught on?
Old 11-03-22, 10:37 AM
icemilkcoffee
icemilkcoffee's Avatar
Quoted: 979 Post(s)
Liked 884 Times in 528 Posts
It seems like a good solution to a long standing problem. How come OC rims never became industry standard?
icemilkcoffee is offline
Old 11-03-22, 11:32 AM
cyccommute
Mad bike riding scientist
cyccommute's Avatar
Quoted: 5248 Post(s)
Liked 2,808 Times in 1,660 Posts
‘Tis a puzzle! It can’t be cost, since the Velocity A23 OC cost $106 vs the A23’s cost of $102. It could be a patent thing. It could also may be part of the inherent conservatism of bicyclists. While we seem to like some new technology, there is some that we just won’t embrace.
Wheels tend to fall into the very conservative well of bicyclists. Triple butted spokes are a very good idea but mentioning using them can start a flame war almost as vehement as chain lube. I’ve had cause to review wheel building calculations for various hubs lately and the topic of off-center rims came up. It’s somewhat surprising how much the off-center rim changes the spoke tension differential. For a 135mm hub, changing from a center drilled rim to an off-center drilled rim decreases the drive side/nondrive side tension from 51% in the former to 70% in the later. I don’t know why people don’t take advantage of that improvement.
Stuart Black
cyccommute is offline
Likes For cyccommute:
Old 11-03-22, 11:37 AM
Troul
:D
Troul's Avatar
Liked 2,114 Times in 1,421 Posts
OC rim with a tall flanged hub could be something to invest in for durability. Maybe OC is limited by how narrow it can be positioned before it becomes a fatigue concern?
-Oh Hey!
Troul is offline
Old 11-03-22, 12:16 PM
seypat
Quoted: 2751 Post(s)
Liked 1,923 Times in 1,201 Posts
Pardon my ignorance, but can it be used with a standard brake caliper? We're in the disc era now, so it might catch on.
seypat is offline
Old 11-03-22, 12:21 PM
njkayaker
Quoted: 3764 Post(s)
Liked 1,044 Times in 733 Posts
Yes. The brake tracks are in the same place as centered rims. It's the arc between the parallel brake surfaces that is off center.
njkayaker is offline
Likes For njkayaker:
cyccommute
cyccommute's Avatar
It can absolutely be used with a standard brake caliper. The A23 OC is rim brake rim. It can be used with disc, of course, but it is primarily for use with rim brakes. Ritchey which kind of pioneered the OC rim in modern times, was making them before disc brakes became a thing. Oddly, Ritchey doesn’t make the OC rim anymore.
Stuart Black
Old 11-03-22, 12:23 PM
njkayaker
More expensive to manufacture and stock/distribute.
With centered rims, you only need to make one part. With off-centered rims, you need to make (and stock/distribute) two parts.
Old 11-03-22, 12:26 PM
icemilkcoffee
Quoted: 979 Post(s)
Most mid to high end bikes run a rear rim with more spokes than the front. So you already have two different parts by necessity.
Old 11-03-22, 12:29 PM
masi61
masi61's Avatar
Quoted: 1010 Post(s)
Liked 335 Times in 238 Posts
When I had some 32 x 32 used Dura Ace 7900 hubs built up with Velocity A223 rims, I tried to get the rear in OC but could not obtain one in the polished finish that I wanted so I went with the symmetrical A23's both front and rear.
I have since built up a second similar set this one with 28 spoke Dura Ace 7850 rear and an 24 spoke Dura Ace 7800 front but this time using Velocity Quill rims. The rear is symetrical and not offset.
I would have liked to have spec'd the offset versions but these just did not seem to be available.
masi61 is offline
Old 11-03-22, 12:40 PM
njkayaker
Err. Yeah.
I wonder if some rims will the higher-count "rear" wheel for the front (and use an even higher count for the rear).
It still might be significantly cheaper not to also produce the off-centered feature.
There must be a fairly strong disincentive not to produce OC rims as the norm (enough to offset the benefit).
I doubt it's because cyclists are "conservative". You'd have to really look closely to notice the off centered aspect.
Old 11-03-22, 12:45 PM
Shimagnolo
Shimagnolo's Avatar
Quoted: 3022 Post(s)
Liked 4,419 Times in 2,246 Posts
I have 4 bikes.
3 of them have been running Velocity O/C rims for years, on wheels I built myself.
(The 4th one is rarely ridden has has some of them thar store-bought wheels).
I swear by O/C rims.
Shimagnolo is offline
Likes For Shimagnolo:
Old 11-03-22, 12:50 PM
pdlamb
Quoted: 2163 Post(s)
Liked 1,387 Times in 883 Posts
So a combination of reducing SKU for big bike OEMs and low available + low demand for aftermarket (replacement) wheels?
pdlamb is offline
Old 11-03-22, 01:05 PM
Iride01
more daylight today!
Iride01's Avatar
Quoted: 5005 Post(s)
Liked 3,513 Times in 2,438 Posts
Perhaps it was a solution for a problem that didn't affect most users.
Iride01 is offline
Old 11-03-22, 01:23 PM
Darth Lefty
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 2956 Post(s)
Liked 1,862 Times in 1,213 Posts
I think that the #1 problem with inexpensive wheels is almost completely solved for most people by the DB spokes found on slightly better wheels, and extra things like OC rims and triple butted spokes are just not necessary enough on top of that.
I had a Diamondback MTB that came with oc rims about five years ago. This caused some problems with tubeless setup, because they put the depression in the rim on-center with the spoke holes and not centered between the sidewalls, and it had a hard time sealing up on the "short" side because there was no "shelf" to start the bead sliding into its channel. I have not seen other rims made this way nor can I think why they did it. It was a strangely unique problem.
Genesis 49:16-17
Darth Lefty is online now
Old 11-03-22, 01:32 PM
njkayaker
‘For a 135mm hub, changing from a center drilled rim to an off-center drilled rim decreases the drive side/nondrive side tension from 51% in the former to 70% in the later. I don’t know why people don’t take advantage of that improvement.
Because this difference doesn't end up mattering much in the real world.
There doesn't seem much conservatism in mountain bikers. If OC rims had a significant useful real world advantage, they would be the norm (or common) on mountain bikes. Kind of like how disk brakes came to be.
OC rims should also be more common for wheels that mostly serve the secondary market.
Old 11-03-22, 01:35 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
Quoted: 2593 Post(s)
Liked 2,296 Times in 1,297 Posts
The mountain bike I bought recently (Ibis Ripley AF) came stock with off-center rims.
Kapusta is offline
Old 11-03-22, 01:39 PM
njkayaker
Sure, OC rims exist. How common are they on mountain bikes? Maybe, they are already the norm there. If OC had a big advantage, they should already be common on mountain bikes.
Old 11-03-22, 01:53 PM
Kapusta
Advanced Slacker
Kapusta's Avatar
I don’t know how common they are. it’s not something I really pay much attention to. I did not even realize these rims were off-center until I had had the bike for about a week.
Kapusta is offline
Old 11-03-22, 03:27 PM
cyccommute
cyccommute's Avatar
Based on the few offerings around, they don’t appear to be significantly more expensive. $4 more from Velocity and about $10 for Kinlin.
Some disc wheel manufacturers are offering OC rims for front wheels since those didn’t need to be dished before discs.
Stuart Black
Old 11-03-22, 03:28 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3196 Post(s)
Liked 2,505 Times in 1,473 Posts
I'm sure that's part of it. Until the mid-70s, standard wheels on British bikes were 32 hole front, 40 hole rear. Bean counters and the bike boom supply chain issues contributed to simplifying inventory by using 36 holes both front and rear.
JohnDThompson is offline
Old 11-03-22, 03:37 PM
cyccommute
cyccommute's Avatar
That’s a very significant difference even in the real world. Heavier riders…who suffer more broken spokes…can really benefit from them. The whole boost idea is an attempt to solve the tension difference on dished wheels by making the dish superfluous. 157mm hubs are basically dishless.
There is some. There are also mountain bikes that come with OC rims as OEM. Not many but there are some.
Stuart Black
Old 11-03-22, 03:44 PM
rosefarts
With a mighty wind
Quoted: 872 Post(s)
Liked 611 Times in 364 Posts
I’ve built with them. No issues. They came stock on my mountain bike too.
The Kinlin rims I bought from bike hub store were offset and not advertised that way. Seems possible that a lot more out there are doing it, just not talking about it.
Seems that a lot of wider 30+mm mountain bike rims are offset until you get into the fat range.
I’ve never seen a road rim offset. I’ve heard of their existence.
rosefarts is online now
Old 11-03-22, 04:20 PM
urbanknight
Over the hill
urbanknight's Avatar
Bikes: Giant Defy
Quoted: 688 Post(s)
Liked 750 Times in 450 Posts
I figured it was a matter of aerodynamics with the deeper carbon rims getting so popular, but you can still get OC rims for sure.
It's like riding a bicycle
urbanknight is offline
Old 11-03-22, 07:32 PM
icemilkcoffee
Quoted: 979 Post(s)
Kinlin, Ritchey, Velocity, Shimano, DT Swiss all make or made road OC rims.
Old 11-03-22, 07:43 PM
genejockey
Klaatu..Verata..Necktie?
genejockey's Avatar
Quoted: 7288 Post(s)
Liked 7,756 Times in 3,952 Posts
I've got Fulcrum wheels on 2 bikes. The Fulcrum Racing 5s are OCR, while the more expensive Racing 4s are not. *shrug*
genejockey is offline
