Time for new Cassette?
Old 10-04-15, 08:45 PM
illusiumd
Quoted: 30 Post(s)
Couple newb questions. Got a new chain and the thing is skipping on multiple cogs. I replaced the chain with the same model - so I'm assuming that means time for new cassette? I probably should have replaced the chain some time ago - I've probably put around 2k miles on the old chain and cassette.
So I have a 12-27 and was just going to get same so to reduce hassle. If I got something pretty similar like a 12-25 would I need to adjust the DeRailleur?
illusiumd is offline
Old 10-04-15, 09:04 PM
FBinNY
Quoted: 5009 Post(s)
Liked 1,125 Times in 655 Posts
Not all skipping is caused by the new chain on old cassette phenomenon. While it's possible, I wouldn't have have expected that a cassette could wear to where a new chain skips in so few miles.
Also the new/old issue usually affects only the one or two most used sprockets, and/or the smaller ones.
So before giving up, I'd do some due diligence and check for things like RD trim.
OTOH - if you saved the old chain it's the best clue about the current issue. If it's stretched only 1/2% or so, then odds favor the cassette being OK. More than 1% odds are against the cassette, and in between then anybody's guess.
FB
Chain-L site
“Never argue with an idiot. He will only bring you down to his level and beat you with experience.”, George Carlin
FBinNY is offline
Old 10-04-15, 09:24 PM
Homebrew01
Super Moderator
Homebrew01's Avatar
Quoted: 1145 Post(s)
Liked 775 Times in 513 Posts
You should not have to make any changes going from 27 to 25.
Homebrew01 is offline
Old 10-05-15, 04:47 AM
Squashednuts
I had a similar experience, I replaced the chain & it started skipping. My first thought was a new case te so I duly researched prices.
I didn't want to fork out the cash so Checked chain again.
I'd mis threaded the chain around the rear derailleur. I'm not suggesting that you're as cack handed as me mearly that a new cassette may not be the answer
Squashednuts is offline
Old 10-05-15, 06:10 AM
Bill Kapaun
Really Old Senior Member
Bill Kapaun's Avatar
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds.
Quoted: 1630 Post(s)
Liked 986 Times in 699 Posts
A 12-25 cassette won't result in any other "adjustments" that any other cassette wouldn't require.
Due to manufacturing tolerances, you may have to turn the barrel adjuster from 0 turns, up to a 1/2 turn. That's just normal.
Going to a smaller largest cog MIGHT allow you to shorten the chain 1 linkset, but it wouldn't be necessary.
Bill Kapaun is offline
Old 10-05-15, 07:53 AM
illusiumd
Quoted: 30 Post(s)
Great, thanks for the advice folks. Sq -> how'd you misthread?
Old 10-06-15, 03:03 AM
Squashednuts
On the bottom black cog
I managed to pass the chain outside of the metal guide so it was only connecting with 1/2 the teeth on the cog.
I did two rides of an hour twenty each time before I noticed my mistake
File Type: jpg
Old 10-06-15, 03:25 AM
Bike Gremlin
Mostly harmless ™
Bike Gremlin's Avatar
Bikes: Custom made on Scott Speedster frame, Custom made on a 1996. steel MTB frame (all but frame changed at least once in the past 20 years).
Quoted: 1037 Post(s)
Liked 118 Times in 80 Posts
Perhaps a b-screw adjustment on RD. To keep it closer to the 25 cog.
Bike Gremlin is offline
Old 10-08-15, 11:48 AM
BikingZombie
Bikes: Surly CC
Didn't that make a hell of a racket while riding?
BikingZombie is offline
nickc3
Bicycle Mechanics
28
04-18-17 07:35 AM
Deontologist
Bicycle Mechanics
3
03-24-15 06:43 PM
velociraptor
Bicycle Mechanics
7
02-01-15 07:14 PM
Bishbike
Bicycle Mechanics
9
04-12-14 12:19 AM
bikenut2011
Bicycle Mechanics
12
01-10-11 05:14 PM
