Re-cabled my Bianchi and new seat post...Much needed change......
This is the before pic.. the day I purchased it last Spring...
And now..
I did the seat post and cables this week... changes last Autumn were the seat and handle bar stem....
And now..
Throw the stick!!!!
The before picture has to have the worst cabling job I have ever seen. Good job on the new ones. Your new saddle position seems to be a pretty big change, hope it works out for you.
I may be fat but I'm slow enough to make up for it.
Artificial Member
Bikes: Retrospec Judd, Dahon Boardwalk, Specialized Langster
Quoted: 6731 Post(s)
Liked 5,443 Times
Now if we can just get those valve stems in the same position and the chain on the big ring...
Saddle position in 1st pic i believe is how I purchased it. I paid for a bike fitting about a month after I got the bike.... Its through that bike fitting that I changed to the current set up, except I have moved the seat just a bit for forward since then....it has made me feel more "centered" on the bike.
The first picture looks like a torture device.
I'm confused - did you build it? You noticeably have a lower and shorter stem. On the first picture it looks like it's more suited for a more relaxed-tourer.
Artificial Member
Liked 5,443 Times
My understanding is he bought a bike from the most clueless LBS possible.
Quoted: 453 Post(s)
Liked 104 Times
If the stem needed to be shortened by as much as it has & slammed, it indicates that he bike is the wrong size; add to that the change from a layback to straight seatpost, all adds upto the frame being too big. The bike look like a very large size, and there's not much seatpost exposed, look at the Bianchi website, to get an idea of what it should look.
Guys...
I bought it used from a friend of my wifes son..needed money for college type thing...My wife agreed in to the purchase really before I could say much...
The frame is a 55cm... I am 5-10 1/2.. with a 30" inseem.. my arm are not the longest either.. and I am fat.
I think I should be on a 53.. but this one does fine. I ride for 1 to 2 hours 3-4x a week and I do fine.. So far i have lost 40lbs..with another 30lbs to go. Once I do that I will be looking at a new bike.
You might want to do a doubles check on that size...I have that same bike and that sure looks like a 61cm to me
Quoted: 63 Post(s)
OOOOFFAAAA.. you guys are almost right (and quite astute!)....I measured from the center of the BB to the top of the head tube quickly and I get 23"... which makes it a 58cm...
Yes, I have short legs......
Well, I am stuck with it till I sell it... anybody want a 58cm Bianchi??
L-I-V-I-N
If you are reasonably comfortable (over that kind of mileage), I'd say you're good for now. And I'd say they did a good job of getting a larger frame to more-or-less fit you. But your next frame should clearly be a size smaller (as a starting point). Congrats on the weight loss!
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
I like beans
Bikes: Tarmac Pro, Bianchi Zurigo, Raleigh Gran Sport, Fuji Del Rey, Ironman Centurion
You'll be okay for now esp. since you got a fitting. My pops got me a 61 thinking I'd grow, but I now ride a 56 grr. Rode that bike for a good 10 years with a super dinky stem. Finally got a 56 when I got out of college and suddenly knew how a bike was supposed to handle.
Artificial Member
Liked 5,443 Times
