Presta valve caps
#51
I recently read an article (I don't remember where) that said valve caps are necessary for schrader valves because dirt and dust can foul the mechanism, but caps aren't necessary on presta valves because they seal themselves when screwed down properly. I use caps so the presta valves don't rip my jersey when I fix a flat and take the bad tube home for repair or disposal. I also think it looks better, but that's just me.
#52
Quoted: 890 Post(s)
Liked 2,048 Times
Rule 60. From the good book: https://www.velominati.com/
“Ditch the washer-nut and valve-stem cap.You are not, under any circumstances, to employ the use of the washer-nut and valve-stem cap that come with your inner-tubes or tubulars. They are only supplied to meet shipping regulations. They are useless when it comes to tubes and tires”. Amen
#53
Grupetto Bob
Bikes: Bikey McBike Face
Quoted: 2557 Post(s)
Liked 5,583 Times
#54
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 248 Times
Nope. The plastic cap won't keep air in the tube; they don't seal tight enough, and if the valve is open, the cap will just push down on it and make it leak faster.
The only use I have for a presta cap is as an emergency shraeder adapter. Cut off the tip, turn it upside down, and screw it on. You can then use a shraeder pump or gas station compressor.
https://www.purecycles.com/blogs/bic...hrader-adapter
#55
Liked 248 Times
Now there is possible same situation with the Presta as well, but most people do not use the cap because those valve just don't seem to care as much as Schrader does, like I said earlier if you're going to be in a wet and or muddy environment you should use the presta cap, and the schrader cap. Most roadies don't ride in the rain so most roadies ditch the presta caps, but my touring bike came with Presta valves so on that bike I use the cap, but not on my regular bikes.
#56
On Your Left
Quoted: 3004 Post(s)
Liked 2,433 Times
More of a problem is the tire sealant making the valve stick and clogging the pump head.
#57
Liked 248 Times
I would rather be safe than sorry, and the weight of a cap is so slight I can't even feel the weight in my hand, so I'm not bothered by the weight of it.
#58
On Your Left
Liked 2,433 Times
Presta caps a t!ts on a bull. They serve no purpose.
Likes For GlennR:
#59
Quoted: 3352 Post(s)
Liked 1,056 Times
Yes this is true, Some brands of Prest tube have screw in valves just like Schraders, be sure and check this out before throwing away what is a good tube.
#60
Quoted: 1606 Post(s)
Liked 2,211 Times
#61
Quoted: 603 Post(s)
Liked 1,061 Times
Personally, I find the presta valve to be a homely little device, so even if the cap isn’t really needed, and it isn’t, my preference is to cover it up.
Tim
Tim
Likes For tkamd73:
