is this still rideable?
Quoted: 1273 Post(s)
Liked 1,392 Times
specialized turbo cotton 700x26
still a tiny bit of the wear dots visible, but just noticed that a bit of the outer (black) part is delaminating from the inner (tan) part.
this is the rear, i’d be too chicken to risk it on the front but even in the back i don’t really want it to assplode 50 miles from home tomorrow. tire has approx 1,050 miles on it.
Quoted: 6193 Post(s)
Liked 4,808 Times
50 miles away from home I wouldn't want to risk having to find another tire. So unless you carry a spare tire with you, I'd change it out now.
But I wouldn't be worried about it assploding, if that is to be taken to mean you expect some sort of chain reaction to take place causing you great harm. I'd only expect it to either flat or hear some rubber slapping on a frame or stay. Hopefully I wouldn't ignore that too long before investigating.
Quoted: 964 Post(s)
Liked 1,628 Times
Back In The Day....
Clean it up with acetone then a little vulcanizing cement and put it together after dry. No biggy. If it fails? Hey, I heal fast...But now days...
Ii could be a sign of catastrophic failure and the old body cannot handle that. Take the tire off and do a complete inspection inside and out before proceeding. If any question as to its integrity then replacement for sure!
Likes For zandoval:
Liked 1,392 Times
thanks everyone. i was able to make it to the shop today and these are readily available, so i changed it in advance of tomorrow's ride. tubeless conversion will have to wait another 1,000 miles.
