How to make a suicide hub safe?
Old 05-03-10, 07:52 PM
youngandcurious
I Like to Bike
youngandcurious's Avatar
Hey i am planning on making a suicide hub, because i do not have enough money to buy a real track hub. So is there a way to make a safe suicide hub. I have heard of welding/brazing but i want something simpler.
youngandcurious is offline
Old 05-03-10, 08:11 PM
the_don
the_don's Avatar
Quoted: 7 Post(s)
super glue on the threads is the common method. But safe it is not.
the_don is offline
Old 05-03-10, 08:14 PM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Liked 27 Times in 18 Posts
Originally Posted by youngandcurious
welding
assuming steel cog and aluminum hub, that's a no go. Maybe rotafix your cog and make good use of front and rear brakes, or stick to a SS freewheel until you get a track hub
hairnet is offline
Old 05-03-10, 08:20 PM
NinetiesKid
NinetiesKid's Avatar
swap the hub with a track hub
kachow!!!
NinetiesKid is offline
Old 05-03-10, 08:21 PM
youngandcurious
I Like to Bike
kachow!!!
can i have yours?
Old 05-03-10, 08:26 PM
wroomwroomoops
Sir Fallalot
wroomwroomoops's Avatar
Quoted: 9 Post(s)
Liked 13 Times in 11 Posts
Best thing is to rotafixa the cog on the hub and add a bottom bracket lockring - but most importantly, use a rear brake for braking instead of backpedaling. This is, in a nutshell, what Sheldon Brown recommends.
wroomwroomoops is offline
Old 05-03-10, 08:39 PM
HoudiniSplicer
If you use brakes, you're fine. If you don't use brakes, rotafix the rear cog on and possibly use some JB Weld. If you're planning on going down a lot of hills, use brakes.
HoudiniSplicer is offline
Old 05-03-10, 08:49 PM
cnnrmccloskey
cnnrmccloskey's Avatar
Bikes: '82 Giante super challange, 70 Gitane Tour de France, GT Gutterball
Loctite red or JB Coldweld then rotofix and a back brake
cnnrmccloskey is offline
Old 05-03-10, 09:17 PM
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
If you really want to ride fixed THAT badly, then maybe just put your energies into getting a used track wheel and ride safely?
carleton is offline
Old 05-03-10, 09:19 PM
Pooptet
Pooptet's Avatar
Bikes: Windosr Clockwork
The title is contradicting
Pooptet is offline
Old 05-03-10, 09:27 PM
Doohickie
You gonna eat that?
Doohickie's Avatar
Location: Fort Worth, Texas Church of Hopeful Uncertainty
Bikes: 1966 Raleigh DL-1 Tourist, 1973 Schwinn Varsity, 1983 Raleigh Marathon, 1994 Nishiki Sport XRS
Quoted: 164 Post(s)
Liked 67 Times in 44 Posts
I actually have the parts to do a suicide hub on an old Schwinn when I get around to it. I picked up the parts for next to nothing at a swap meet. I figure it will be a learning experience. When I see how it goes together I will JB Weld it but also I will see if there is any way to put a set screw in it. I'm a mechanical engineer; I never depend on adhesives for critical joints.
I stop for people / whose right of way I honor / but not for no one.
Originally Posted by bragi "However, it's never a good idea to overgeneralize."
Doohickie is offline
Old 05-03-10, 09:35 PM
hairnet
Fresh Garbage
hairnet's Avatar
Bikes: N+1
Quoted: 352 Post(s)
Curious, how do you plan to do that? I don't know anything about how hubs are made, do you think there's enough material to drill and tap?
hairnet is offline
Old 05-03-10, 10:15 PM
Doohickie
You gonna eat that?
Doohickie's Avatar
Quoted: 164 Post(s)
No. I haven't looked at it yet. I'm thinking of a teeny little set screw... the smallest I can get... and maybe drilling through the threads between the cog and hub (parallel to the axle), then just screwing the screw in without tapping, and just locktiting in place. I see the wheel as pretty much disposable; I got the whole bike for $10. If I decide I like FG then I'll get a proper wheel with a track hub. This is kind of a try-before-you-buy/learning experience project.
Old 05-03-10, 10:45 PM
blickblocks
blickblocks's Avatar
The point of the suicide hub is that you don't have to do it yourself. Instead of cutting yourself with a razor "across the street" or "down the street", you can just let your cog spin off while skidding down a hill. I swear getting hit by a semi is less painful than blood letting, and looks wicked cool.
Use a brake.
https://blicksbags.com/
blickblocks is offline
Old 05-03-10, 10:49 PM
Squirrelli
GONE~
Maybe put a bottom bracket lockring over the cog? It probably won't help much since they thread on in the same direction.
Squirrelli is offline
Old 05-03-10, 10:50 PM
TofuPowered
Turgid Member
TofuPowered's Avatar
Bikes: Salsa Casseroll, Soma Rush, Fuji Tahoe 29er Pro
the safest way to suicide a hub is not to.
TofuPowered is offline
Old 05-03-10, 10:54 PM
Squirrelli
GONE~
Agreed, I'd rather pay the extra money to get a proper track hub.
You can't ride when you are dead.
Old 05-03-10, 11:41 PM
Rob Glatfelter
Suicide up is only OK SS, nogo on FG.
Seriously, if you really want to trim it up, go SS until you can afford a new hub.
Rob Glatfelter is offline
Old 05-04-10, 02:48 AM
wroomwroomoops
Sir Fallalot
Quoted: 9 Post(s)
Aww... will the BS flood ever stop? Why don't you people actually think a bit with your heads instead of going with the herd and parroting each other?
"Suicide hub"
Originally Posted by Sheldon Brown
A rather alarmist and silly name for a freewheel hub used as a fixed-gear hub.
Any standard-thread freewheel type hub will also accept a fixed-gear ("track ") sprocket . This is a common technique for converting an older bike to fixed gear on the cheap.
Despite the silly name, this is no more dangerous than using a freewheel, as long as you keep front and rear hand brakes installed.
Old 05-04-10, 02:50 AM
wroomwroomoops
Sir Fallalot
Quoted: 9 Post(s)
And if you ask "Who the heck is Sheldon Brown anyway?" - well, he was only the greatest advocate for fixed gear riding ever to walk the earth (and pedal thereon).
Old 05-04-10, 06:52 AM
BassNotBass
master of bottom licks
BassNotBass's Avatar
Quoted: 111 Post(s)
A so-called "suicide hub" can be perfectly safe for street riding. The real danger comes from not using brakes regardless of whether "suicide hubs" OR track hubs are fitted.
BassNotBass is offline
Old 05-04-10, 09:11 AM
conbon
conbon's Avatar
Bikes: trek 560, specialized langster, specialized stumpjumper, felt bmx, GT pro series
My buddy was running suicide style without a lockring for a while and somehow he didn't die, then i stomped on his cranks backwards to show him what would happen. After seeing the cog backing itself off, he wanted to fix it. A bottom bracket lockring and some red loctite got it working fine, no problems since then.
-Connor
conbon is offline
Old 05-04-10, 09:33 AM
clink83
-Connor
Putting a threaded lockring on is a waste of time unless it is counter-threaded . I don't know about you, but I don't really feel like some red locktight is strong enough to withstand 200lbs of body weight.
clink83 is offline
Old 05-04-10, 09:44 AM
Doohickie
You gonna eat that?
Doohickie's Avatar
Quoted: 164 Post(s)
In my case I plan on running both brakes.
Old 05-04-10, 09:49 AM
Cynikal
Team Beer
Cynikal's Avatar
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times in 104 Posts
The OP has not commented on using brakes, I wish he would. Again, if you didn't hear it, it is only suicide if you run brakeless.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Cynikal is offline
