Easy hydraulic brake question...
Old 06-30-22, 02:11 PM
67tony
67tony's Avatar
Bikes: 1987 Centurion Ironman Master, 1992 Koga Miyata Exerciser, 1992 Schwinn Crosscut
Quoted: 209 Post(s)
Liked 175 Times in 92 Posts
I understand the fluid line, but why is there also an electrical line coming out of my Tektro Zoom brake levers?
67tony is offline
Old 06-30-22, 02:16 PM
Polaris OBark
ignominious poltroon
Polaris OBark's Avatar
Quoted: 2220 Post(s)
Liked 3,400 Times in 1,774 Posts
Electronic braking. It is the latest New Thing.
Polaris OBark is offline
Old 06-30-22, 02:18 PM
Polaris OBark
My guess is that it is for an e-bike, so that the motor cuts out when you apply the brakes.
Likes For Polaris OBark:
Old 06-30-22, 02:38 PM
67tony
67tony's Avatar
Quoted: 209 Post(s)
That's it!
I feel like a noobie but, hey, when it comes to disc brakes...I AM a noobie!
67tony is offline
Likes For 67tony:
Old 06-30-22, 04:41 PM
Polaris OBark
It might have a similar functionality for shifting, especially if it is mid-drive.
Old 06-30-22, 10:32 PM
alcjphil
alcjphil's Avatar
Quoted: 1813 Post(s)
Liked 1,692 Times in 973 Posts
Actually, the wire connects to the controller to activate regenerative braking
alcjphil is offline
Old 06-30-22, 11:22 PM
Leisesturm
Quoted: 2488 Post(s)
Liked 735 Times in 520 Posts
Maybe. I am trying hard to think of the production e-bike that has regen as an OEM feature. It is certainly 'possible' that a set of Tektro e-brake levers might be attached to a system with regen, but it is far more likely and typical that the electrical line from the brakes to the controller senses braking effort for the reason given earlier: motor cutoff, because having the motor remaining powered while braking is wasteful, if not possibly dangerous. The momentary ducking of motor energy for smooth shifting is usually triggered by electric lines coming directly from the shift lever(s) or the shift cable(s).
Leisesturm is offline
Old 07-01-22, 05:12 AM
hokiefyd
hokiefyd's Avatar
Bikes: More bikes than riders
Quoted: 1443 Post(s)
Liked 759 Times in 568 Posts
Some systems may offer regen and some systems will simply cut the motor power, but the brake lever function is the same in any case -- it's simply a switch to tell the e-bike control unit that the rider has activated the brake. Depending on the bike, the control unit may go through several logic steps to determine what to do next, but the answer to the question posed in the original post is the same: it's an electrical switch used in e-bike applications. It can be ignored (and sometimes even removed from the lever entirely) if used in a conventional bike application.
hokiefyd is offline
Old 07-01-22, 08:08 AM
67tony
67tony's Avatar
Quoted: 209 Post(s)
The bike is an Aventon Pace 500, about a year old.
Entry level price of $1,400 but pretty decent quality in my opinion.
No regenerating braking system, for sure.
67tony is offline
Old 07-01-22, 08:22 AM
trailangel
trailangel's Avatar
Bikes: Schwinn Varsity
Quoted: 1931 Post(s)
Liked 742 Times in 422 Posts
That's some good bait!
trailangel is offline
