Cleaning up progress on my $10 1984 Schwinn World Sport
Bikes: 1984 Sekai 5000 Superbe, 1987 Raleigh Seneca Mountain Tour, 1984 Schwinn World Sport, 1978 Raleigh Grand Prix, 2021 Handsome She Devil, Mystery Vintage purple road bike
Quoted: 99 Post(s)
Liked 124 Times
Well I’ve been cleaning up some of the parts on my $10 find and the crankset is looking pretty shiny. I’m still waiting for my 44 piece toolkit to arrive that I bought off EBay so I can’t take the chain off yet till I get the tool. I’ll buy a brand new chain and I’m wondering now how will I know if the rear and front derailleurs are in good working condition? My bike repair stand is also on its way to me as well.
Likes For tpadul:
Quoted: 701 Post(s)
Liked 667 Times
The chain is not rusty and by the looks of the chainrings, it has not been used much. Remove it, let it soak in a solvent overnight and clean it with a scrub brush, it should last a few years depending on how much use and how well you maintain it, i.e. keeping it clean and lubricated which you would have to do with any chain.
Or, scrub it with soap and water, rinse well, let dry in the sun and then lubricate it.
Quoted: 701 Post(s)
Liked 667 Times
My guess is the derailleurs are fine and just need to be taken apart and cleaned. Use a solvent and wire brush to remove the rust
Likes For branko_76:
Quoted: 801 Post(s)
Liked 1,000 Times
Good job on the cleaning. It looks great. I am agreeing with branko_76 that the chain doesn't look too bad. I bought a chain checking tool recently, that is kind of handy not having to guess at how worn the chain is.
I like Oz Cycling chain maintenance videos and techniques. Even if you don't follow what he does, it is helpful.
Likes For Velo Mule:
Extraordinary Magnitude
Quoted: 2597 Post(s)
Liked 1,678 Times
I am of the train of thought that the 84 and later Schwinn World Sport is a bike that punches well above it's pay grade. (that's a dumb mixed metaphor)
You've got a CrMo main frame with hi-ten stays and fork. The bike rides REALLY nicely. The Suntour AR stuff functions as well as any Suntour stuff does, it only gets more fancy looking.
You've got a kickstand plate- how cool is that!
I'd be tempted to get some Cyclone derailleurs and some fancy band-on shifters and dolly that bike up!!!
Commence to jigglin’ huh?!?!
Quoted: 99 Post(s)
Liked 124 Times
Bikes: 1989 Schwinn World Sport. 1994 Diamond Back Response Elite MTB. 1964 Schwinn Typhoon. 1974 Bridgestone Sprinter, 2015 Scott Sub 10 Citybike.
Quoted: 1687 Post(s)
Liked 78 Times
Thanks!!! So I'll look up the Cyclone derailleurs and please tell me what "band-on shifters" are? Is that the brand name? Band-on? And I am going to get rid of the drop handlebars and replace them with some upright handlebars like the Tourist kind, what kind of brake levers should I get? Can I still use the same Dia-Compe brake levers with upright handlebars? My back really hates riding in the position with the drop handlebars.
These were drop bar bakes:
Likes For Shp4man:
Liked 1,678 Times
First- if you don't like the drop handlebars- address that first. So to me, that would mean bars and brake levers... you can keep the stem mount shifters until you decide you like the ride.
Bars like this would be pretty slick- if you can get them for around $20- score- and you get the grips...
https://www.ebay.com/itm/1979-Schwin...IAAOSwhw9fA9yX
I've got nothing to do with the auction or seller- And you can poke around for other similar bars. Another thing- I like those Schwinn grips- I had a couple bikes that I was making upright bars work on- and those 1950s style Schwinn grips were my favorite of the bunch- I think I still have a set in the basement. "just in case."
Brake levers...
These guys look like they'd fill the spot pretty good:
https://www.ebay.com/itm/Vintage-198...MAAOSwVFZfTb5i
Again, no affiliation with the seller or auction.
The 'band on' shifters I was referring to were shifters attached to a band clamp that would attach to your downtube-
Likes For The Golden Boy:
Quoted: 99 Post(s)
Liked 124 Times
Thank you!! That looks so awesome!! Those are the kind of handlebars I want!!!
Liked 78 Times
Likes For Shp4man:
WGB
Bikes: Panasonic PT-4500
Quoted: 1783 Post(s)
Liked 2,305 Times
Likes For WGB:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3846 Post(s)
Liked 6,437 Times
You could probably find an inexpensive Sugino or SR crankset with aluminum rings and rid the old steel set.
Suntour ratcheting shifters work better than most anything friction and look appropriate on a bike like this. I saw some in the bin at my lbs for under $10. Check with your co-op.
Remove. Fully overhaul. Replace. Test.
Quoted: 796 Post(s)
Liked 522 Times
Wald makes some nice inexpensive touring bars I have used on conversions just make sure your current stem clamp diameter and the bars are compatible https://cambriabike.com/products/wal...gaArZ8EALw_wcB
And Velo orange has some inexpensive brake levers to work on this type of barshttps://velo-orange.com/collections/...-brakes-levers
If you have a Bike Co-op near you they can also be a source of this type of component for not a ton of $$
Likes For ryansu:
Quoted: 620 Post(s)
Liked 1,205 Times
Soak the rusty chrome pieces like that front derailleur in white vinegar for a few hours, maybe 4 to 6 but don't leave them in the vinegar too long as it can cause the plating to peel more and will attack any aluminum pieces. A short soak won't effect the aluminum though. Most of the rust will wipe right off after about a 4 hour soak. To get what doesn't come off the first time you can then try soaking them a little longer or hit the remaining rust with #0000 steel wool soaked with WD-40, I prefer the steel wool and WD. Any areas where the plating is gone or heavily pitted can be coated with clear finger nail polish to protect them from moisture.
Likes For Murray Missile:
Liked 1,678 Times
I'm pretty sure that's a melt forged, swaged alloy chain set.
Quoted: 211 Post(s)
Liked 1,400 Times
Your making good progress.
Lots of good tips on the thread.
Regarding the chain...I've had good luck using KMC 6,7,8 speed chains with the removable quick link.
I get them for about 12 to 14 bucks.
It sure makes it easier when cleaning chain, adjusting chain length or changing derailers.
I've also been pleased with these upright handlebars for about 35 bucks.
https://www.ebay.com/itm/SUNLITE-NORT...IAAOSwK7palz-V
Likes For cooperryder:
Quoted: 211 Post(s)
Liked 1,400 Times
Thats very innovative!
For a budget build that's will save the cost of new levers. I probably have 7 or 8 sets of similar levers in parts bin.
Quoted: 99 Post(s)
Liked 124 Times
Worked more on the clean up this long weekend and removed all the cables and tossed them. Ran into a problem trying to remove the handlebars as the bolt was stripped so I did take the frame into the LBS and they are removing it for me. They also removed the freewheel for me from the rear wheel.
so I spent the weekend soaking parts and degreasing them and cleaned up the wheels.
Found cheap Bell 27 tubes at Walmart for $4.97 that will fit the 27 x 1 1/4 tires, ordered new tires online today.
Took apart the stem shifters and need some grease before I put those back together.
I think I found a spray paint match for the spots I want to touch up. Unfortunately the Goof Off heavy duty I was using to get the caked on Adhesive off the frame stripped away the paint In those spots
Quoted: 2350 Post(s)
Liked 1,728 Times
Without a chain checker tool, you can still _measure_ the chain for wear. Hold the chain tight and measure center-to-center over 24 pins (12 full links). On a new chain, that last pin will measure to exactly 12". If your chain measures more than 1/16" beyond the 12" mark over that 12-fulll-link span, it's worn and should be replaced.
Bikes: A few too many
Quoted: 1359 Post(s)
Liked 2,173 Times
I would try an auto parts store a buy the premixed touch-up paint they have...I am certain that you will find a metallic paint that will suit your purposes better than the nonmetallic blue from Krylon....auto touchup in my estimation is also a better choice quality-wise than regular rattle can stuff from the big box stores.
Krylon used to be better before the changes made to make it more E.F.
Looking good.
GL, Ben
Likes For xiaoman1:
Quoted: 99 Post(s)
Liked 124 Times
OP,
Looking good.
GL, Ben
Looking good.
GL, Ben
Quoted: 796 Post(s)
Liked 522 Times
That Schwinn is getting some love! I like to put a bit of 3 in 1 lube on the pivot points (and springs) on the derailleurs and brakes after the clean up. I have dribbled lube into the FW which is better than nothing but the more I read and see on the forum the more I think the FW should either get replaced - what I normally do, or get taken apart and cleaned and lubed inside and reassembled. I leave that up to the experts like pastorbobnlnh (https://www.freewheelspa.com/) RJ the bike guy does have a
on it You Suntour Perfect is a desirable FW IIRC,
Likes For ryansu:
Quoted: 99 Post(s)
Liked 124 Times
Well the LBS helped me with the stripped fork bolt and we were able to get the handlebars and the fork and stem off the bike, I did go to an auto parts store in town that does custom paint matches for cars and I found a metallic blue color that matches the bike.
my cruiser handlebars have arrived and my new tires as well. Decided to get the cool looking Blue tires to match the frame.
I hope to spend some time this weekend working on getting the rust spots cleaned up on the frame.
Right now it’s a box of parts in a corner of the house but little by little it is coming together.
I want a more comfortable vintage type cruiser saddle instead of the one it has now so I’ve been looking at the vintage Mesinger Schwinn Saddles with the “S” on them.
Top color is the one that matches the current color. Took the frame to the Auto parts store and took the sample card outside in the natural light to compare with the frame.
señor miembro
Liked 6,437 Times
It's been tough finding decent alloy riser bars on line lately. I recently ordered three pairs of these & I'm satisfied with the size & finish. But, I just checked ebay wheelandsprocket(215,634) & they're sold out again. Too bad. They were a great deal at around $22 each.
Kalloy AI092 Tourist Bar 70mm Rise 25.4x580mm Silver
Here's how they look on an upright conversion bike:
Likes For ramzilla:
