Buying an Older Bike
I want to buy a used Bianchi road bike to replace my hybrid but don't want to spend a lot. Those in a price range I like seem to come from early to late 2000s.
My question is: assuming reasonable maintenance, would the brakes, derailleurs, shifters, etc., still be good, that is, not need replacing on a 15-20-year-old bike? The groupsets are Shimano, either 105, Ultegra, or a combination of the two.
Ron
Ron
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
It depends on how used up the bike is. Metal parts wear and plastic/rubber parts harden and crack. Some parts are expensive to replace and others not so much. Maybe you have a knowledgeable friend that can help check out candidates.
Likes For sced:
Quoted: 1818 Post(s)
Liked 1,693 Times
Ron
Ron
Should Be More Popular
Quoted: 22590 Post(s)
Liked 8,924 Times
Quoted: 6191 Post(s)
Liked 4,807 Times
Just to restate what was said a little earlier, you'd be buying old components on that bike. Those exact model and part number long out of production. Depending on what goes bad, you might have to buy two other new components along with the bad component just to satisfy the compatibility requirements.
While you might find the bikes you are looking at will work well in the short term of two or three years for your budget, they might be a waste of money for the long term
Whatever you get in a used bike, make certain everything works or that you get it at a price that you can replace everything on it and not feel bad.
Haven't had my coffee yet this morning. Apologies for the doom and gloom response.
Actually, if you're willing to go off-brand, I think nearly everything in those groupsets could be drop-in replaced with current options. Pre-2015 10-speed shifters are an awkward point, but I think Microshift's R10 brifters are compatible.
Klaatu..Verata..Necktie?
Quoted: 10421 Post(s)
Liked 11,882 Times
So much depends on how much it was ridden, and where, as well as how well it was taken care of. For example, if the previous owners did a lot of descending, and thus a lot of braking, the rims might be worn out. Another thing - My 2006 Bianchi came with Fulcrum wheels, and on the rear, cracks developed around all the spoke holes, requiring a new wheel, so check wheels CAREFULLY. The previous owner(s) might or might not have routinely cleaned the drivetrain, replaced the chain, etc. If yes, then the chainrings and cassette might still be in good condition. If not, they might need replacement. Cables should probably be replaced, but whether the housings need replacing depends on how much the bike was used and whether they've ever been replaced - I always replace both when I get another used bike, plus I replace them every few years, depending on how much I ride.
Basically, unless you like doing the work yourself, I'd find a bike shop you trust and have them go over any bike you want to buy.
Likes For genejockey:
Would the version of Shimano bits make a difference in judging how well they've held up? I realize it will vary due to many factors. I expected to hear either "yeah, those things last forever," or "if they're that old they're crap."
In terms of fit, I'm just considering frame size (52-56cm). Not a serious bicyclist, no need for much customization.
What I actually expect is to buy one that seems good to my eye then take it to a shop for a tune-up. That's when I may get some bad news but I can't imagine it would outweigh the savings in purchase price.
Re price, when I was considering new, or nearly new, it might have been a Via Nirone 7/105, probably between $1600-1900. Then I browsed some used specimens and thought, why should I spend so much for my level of riding?
Not to mention, there aren't many offerings within an 2-hour's drive from where I live. So just making a trip to look at a candidate is something of a commitment. Also makes it awkward to take to a shop for a checkup before buying. Having suffered some degree of buyers remorse for much larger investments (house, RV), going out on a limb for a bicycle isn't intimidating.
Liked 4,807 Times
What I meant by 2 or 3 years out is that if you don't currently have a good bit of road bike riding experience already, then whatever you get now, you might find that it's not what you really wanted. And 2 or 3 years worth of riding experience on road bikes you'll have a much better idea what to get and what you want. If you ride a lot and you have the cash, then you might not mind spending the money on a mid to high priced bike.
So if you don't have a lot of experience, then get the lowest price bike that fits the conditions you will be riding.
As far as your comparison to where a bike fits in your budget for other things, you probably have the right idea. But still I wouldn't max out your budget for a 10 - 20 year old bike. Even if the new bike you were looking at was 1200 to 1500 dollars, then I personally feel the used bikes at a 1000 less were priced too high.
Though it might be that you live outside the USA, so I really can't make new and used comparisons that will apply.
Quoted: 1607 Post(s)
Liked 2,586 Times
If you are getting shimano components, good chance it is not Italian made.
Sunshine
Quoted: 10954 Post(s)
Liked 7,483 Times
I have 105 and Ultegra components from the late 80s and early 90s that work as well as my 105 and Ultegra components that are 1-5 years old.
I have also stripped off ans replaced 105 and Ultegra components that are old and a total mess.
If the bikes you are looking at are 20 years old and the drivetrains shift how they should, then you are likely fine. Just make sure the chain is lubed and the brake pads are fresh. Hardened brake pads are about all I would care about on a 20yo bike that shifts how it should shift.
Tire size limitations
I ride a 21 yo Litespeed and have come to the realization the older bikes were designed to run smaller tires, 25 max on the rear of mine and it rubs when climbing out of the saddle. The current trend for larger tires running lower pressure for comfort may not work depending on the bike you get.
Im also having to make drivetrain compromises as parts wear out because replacements aren't available. Good luck with whatever you get.
Two wrongs don't make a right but three lefts do! Unknown
Quoted: 167 Post(s)
Liked 291 Times
Old bikes can be good!
When I was in Belgium a few weeks ago, I couldn't find a rental so my brother-in-law offered me the use of an old Bianchi ML3 - a road bike from the early '90's.
It is an aluminium bike, quite heavy but also entry level so to be expected. It hadn't been ridden for more than a decade. It even had the original tyres!
I used it for the 4 days I was there. No problems at all. If it was mine, I would have changed the tyres and tubes, run new cables and put on new brake pads but other than that, it only needed a clean. Everything worked just fine. I did a 50mi+ ride including the famous Koppenberg climb on it on day 2 and it handled the cobbles no problem.
It is probably worth all of about $200 max. Likely less. But rode well.
The Bianchi bikes are manufactured to a great extent in Taiwan but that doesn't make them "Chinese". Design and standards, I have to assume, are still Bianchi.
Liked 2,586 Times
What isn't Italian, the components or the bike? Shimano is a Japanese company. From what I've read some of their stuff is made in Malaysia and the higher-end bits in Japan. The components don't determine the real lineage of the bike, to my mind.
