Removing chainring bolts?
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
I am changing the chainring on my new Kilo TT FG bike. Are there any tricks to holding the slotted nuts? I looked on youtube for ideas but nothing that has worked thus far. I see that Park Tool sells a wrench for this, but I would have to mail order one.
Any help?
Any help?
'10 Specialized Hardrock
You can use a flat head screwdriver to hold the nut(s) , other than that get the Park 's tool .
Quoted: 83 Post(s)
I tried all kinds of improvised solutions the first time I tried this. Long story short, I had to buy the Park chainring nut tool. And even with the right tool it took a combination of finesse and force to get them loose.
Quoted: 5775 Post(s)
Liked 2,573 Times
I rarely need to hold the nuts. The trick is to loosen with a quick snapping action, which will pop the screw loose (doesn't always work). Once it's a bit loose you can usually hold the nut with direct thumb pressure. In a few cases where the thread may be sticky, especially if some shoemaker used locktite on the threads.
For installing and to prevent issues, you can use some lapping compound under the rim of the nut. This will effectively bind it to the ring and hold it while you tighten or loosen. If you prefer, locktite or a similar adhesive under the nut's rim does the same thing.
FB
Chain-L site
FB
Chain-L site
Quoted: 86 Post(s)
after a number of years of trying to "make do", i went to my LBS and tried to buy a chainring wrench. the mechanic GAVE ME his. he said they were cheap... i don't doubt him. it's just a piece of 1/16", on a good day, stamped steel that's been bent in a couple of places. pretty flimsy, but usually works.
BTW, when i don't have the tool handy, i've managed from time to time to get them off, and on, by vigorously turning the male portion while imparting a lot of sideways torque. the friction heats up the female portion causing her () to bind in the spider.
Quoted: 2026 Post(s)
Liked 1,096 Times
A wide blade screwdriver should span the slots in the nuts. The proper tool is the Park or similar spanner.
Liked 2,573 Times
after a number of years of trying to "make do", i went to my LBS and tried to buy a chainring wrench. the mechanic GAVE ME his. he said they were cheap... i don't doubt him. it's just a piece of 1/16", on a good day, stamped steel that's been bent in a couple of places. pretty flimsy, but usually works. .
FB
Chain-L site
FB
Chain-L site
Liked 2,573 Times
A wide blade screwdriver often works, but just as often doesn't because the screw extends beyond the depth of the slot. You need to use a blade wide enough, then grind out the center, so only two small edges of the blade can fit around the screw.
FB
Chain-L site
FB
Chain-L site
Liked 2,573 Times
Yes, if you have the right one (the discontinued red one), and a very steady hand. The current crop's pins are too fat.
FB
Chain-L site
FB
Chain-L site
I have used a snap ring plier with some success. Sometimes you can find them in the cheapy bin at your hardware store.
Liked 1,096 Times
Yeah, some do and some don't. The Shimano cranks of several vintages I have all have the bolts short enough that a wide screwdriver blade can span the nut's notches without interference. I've had others that don't work.
Quoted: 1438 Post(s)
Liked 1,092 Times
+1, Park CNW-2, the right tool for the job. Grease the threads to ease removing them the next time.
Senior member
Quoted: 943 Post(s)
Liked 658 Times
This is one that Truvative got right. Their chainring bolts take a 5mm hex wrench on the front and 6mm on the back. Wonder why a simple idea like that took so long to come up with.
rebmeM roineS
Quoted: 653 Post(s)
Liked 347 Times
Works like a charm.
Not quite there yet
Bikes: A bunch of old steel bikes + an ICE trike
Used to be these wrenches were included with each crankset. They work, but not real well. This is what you need:
https://www.amazon.com/Var-Combined-T.../dp/B004YJ2X7Q
Liked 1,096 Times
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
Just went to the harware store and bought a snap-ring pliers. We'll see what happens.
Warehouse Monkey
Quoted: 305 Post(s)
Liked 7 Times
Bent the pins on the pliers. I took the crank off and have it soaking in WD-40 for a bit. Next I take some heat to it break the bond.
Your cog is slipping.
This works just as well for occasional use if the Park Tool spanner isn't cutting it.
Bikes: Specialized Sequoia Elite/Motobecane Fantom Cross Team Ti/'85 Trek 520
Man, on all the cranksets (dozens, more?) I have disassembled over the last couple of years at the co-op, I have never had an issue taking the bolts off chainrings with nothing more than the allen key. I must just be lucky.
