Show us your Raleigh Super Course!
#1952
Likes For daka:
#1953
Quoted: 659 Post(s)
Liked 595 Times
There is no bottom bracket and I read it’s english threading. Not being familiar with British ‘72 stuff, will there be a problem with finding one? Will Shimano fit this?
#1954
Quoted: 3803 Post(s)
Liked 6,639 Times
The BB only cares about threading, not manufacturer! In my experience, it's somewhat of a crapshoot as to whether it'll be standard English/BSA threading or Raleigh-proprietary threading. I think it depends on whether the Raleigh brazer was right-handed or left-handed (BSA shells to the left; Raleigh-threaded shells to the right).
Likes For nlerner:
#1955
Quoted: 659 Post(s)
Liked 595 Times
#1956
The Raleigh threaded bottom brackets are easy to spot because they are wider, as much as 71-72 mm .
Likes For daka:
#1957
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 356 Post(s)
Liked 120 Times
Finally picked one up
Just picked her up today. Don't know if I got a good deal, but paint and chrome look ok, snd original.
needs adjusting and front wheel doesn't spin well. Will see where it goes.,, I guess another winter project 😏
Likes For rossiny:
#1958
elcraft
Wow, looks completely original excepting the derailleur mechs, Suntour was;not OEM. But a common period upgrade from the usual Huret challenger or Simplex that was OEM.paint and chrome look stunning.
#1959
Very pretty! I'm certain you will enjoy it.
#1960
Quoted: 356 Post(s)
Liked 120 Times
Thanks
thanks , was a birthday gift to myself ! Yes I been looking at it, and doesnt seem used almost no scratches ! I paid 275, he wouldn't budge lower on price from 300 asking . It needs all the bearing checked and cleaned and greased , cables adjusted etc. Probably pads. I noticed if I push on crank I can get a bit of side to side movement , but it will be fun checking and redoing . The seat is riding on the seat post almost. I might need a new post and see if seat can be used . I like a longer stem and brake levers .. Any suggestions will be helpful I may post in thud vintage section . Thanks again
#1961
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
The good news is that your bike is guaranteed to use a standard English threaded bottom bracket, so you can put any modern or vintage replacement in once you measure the DS spindle length.
Likes For Unca_Sam:
#1962
Quoted: 356 Post(s)
Liked 120 Times
Good to hear
My experience with the Normandy hubs found on earlier Raleigh lightweights was that the cones are "soft" and tended to pit easily. It has been difficult finding one today with intact cones.
#1963
If you decide to rebuild the bottom bracket, measure one of the bearing balls before charging ahead and replacing with fresh 1/4" balls - Both of my Nervar cotterless bottom brackets used 7/32" balls.
And don't beat yourself up on the price you paid - there are Super Courses out there for less but this one is particularly pristine and is well worth paying a little more. You didn't get taken.
Likes For daka:
#1965
I wouldn't have said anything except that one of those bottom brackets was original to my Super Course Mk II which looks just like @rossiny 's (except that mine is not in such nice shape). The other Nervar bottom bracket was purchased off of eBay, its origins unknown, and was installed in the Raleigh "Intercourse" project. It too wouldn't go together with 1/4 inch balls. The "tracks" on the spindle and cups were in the wrong places and the adjustable cup had way too many threads showing.
Once quick measurement with calipers should avoid any headaches.
#1966
Quoted: 356 Post(s)
Liked 120 Times
thanks all, will be cleaning and repacking so will check the bearing measurement . There is some movement when I checked it by pushing back and forth on the crank.
#1967
Quoted: 659 Post(s)
Liked 595 Times
Here’s a few pics of the old Super Course I grabbed today. This one isn’t as nice as I usually bring into the shop, but when you get a classic in trade for a set of pedals, you just grab it.
Just a few pics for now. It should look better by spring (my shop is a bit chilly this time of year.
#1968
Bikes: 1968 Raleigh Super Course, 1972 Raleigh Professional, 1975 Raleigh International, 1978 Raleigh Professional, 1985 Raleigh Prestige, 1972 Schwinn Paramount, 1980 Schwinn Voyageur 11.8, 1960 Carlton Franco Suisse Peugeot PX10, 1972 Motobecane Le Champ
Quoted: 321 Post(s)
Liked 688 Times
#1970
Quoted: 659 Post(s)
Liked 595 Times
Quick question on this ‘71 BB. The threads are the same as a more modern BB cup so can I assume that the DS fixed cup is reverse thread (clockwise to loosen)?
#1971
Correct. Clockwise to loosen.
But, being conflict-averse, I don't remove those unless they are worn/damaged badly enough that they have to be replaced. For a clean & regrease, I'd suggest doing that with the cup left installed.
Likes For daka:
Likes For oneclick:
#1973
Quoted: 659 Post(s)
Liked 595 Times
I typically do the same but this cup is the only one on the bike. So it will come off and another BB in it’s place. Thanx for the help, I will hope it isn’t fused in there to tightly.
#1974
Quoted: 659 Post(s)
Liked 595 Times
The paint restoration begins!
#1975
The dropped
Liked 1,014 Times
That bronze green is notoriously difficult to reproduce. Add in 45+ years of oxidation and the cumulative hours of UV exposure, and your matched paint, if accomplished, might not match everywhere. I opted to polish and stabilize what mine had. A phosphatizing treatment for the bare steel will provide a strong curb to rust formation on the exposed steel.
Likes For Unca_Sam:
