Saddle - how long?
Saddle - how long?
Old 09-11-14, 06:04 PM
BikeHawg
Bikes: Trek Emonda SL5, Trek Verve
Saddle - how long?
How many hours do I have to spend with a sore a$$ before I decide I hate the saddle?
- new road bike rider
BikeHawg is offline
Old 09-11-14, 06:14 PM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Quoted: 3203 Post(s)
Liked 592 Times in 326 Posts
Usually one 100 km ride tells me all I need to know.
Machka is offline
Old 09-11-14, 06:23 PM
Lazyass
Quoted: 2431 Post(s)
Liked 634 Times in 391 Posts
A 60 mile ride probably isn't going to tell you if you got a good saddle or not. You have to play around with adjustments. Even nose up/down a millimeter can make a difference. May take a few rides. Of course of you're a new rider any saddle will hurt your butt for a while.
Lazyass is offline
Old 09-11-14, 11:14 PM
Jed19
Jed19's Avatar
Liked 5 Times in 5 Posts
You are a new road rider. I say you should work on the saddle for a full two weeks or so, and follow lazyass' idea re moving things around thru adjustments to see if things get better. As he pointed out, as a new rider, your butt is gonna hurt for a while. You can't escape that. And another thing, don't cheap out on riding shorts. Personally, every ass-hatchet of a saddle is tolerable to some extent with a good pair of shorts.
Jed19 is offline
Old 09-12-14, 12:01 AM
SevenTwentyNine
SevenTwentyNine's Avatar
Bikes: Wheelbarrow
Quoted: 19 Post(s)
First and foremost can we establish you're wearing a chamois... you'd be surprise how many people I see complain about their road bike saddles and then I ask them if they've gotten specific clothing necessary for cycling and they're like durrrrrrrrrrrrrpppppp.
SevenTwentyNine is offline
Old 09-12-14, 01:00 AM
woodcraft
woodcraft's Avatar
Quoted: 1814 Post(s)
Liked 921 Times in 567 Posts
10 hours
woodcraft is offline
Old 09-12-14, 04:31 AM
bruce19
bruce19's Avatar
Quoted: 1717 Post(s)
Liked 1,267 Times in 731 Posts
+1
And, get fitted to your bike. Your saddle to body position will likely change and have an effect (one way or the other) on comfort.
bruce19 is offline
Old 09-12-14, 06:07 AM
Machka
In Real Life
Machka's Avatar
Bikes: Lots
Some tips:
-- make sure the saddle is wide enough for your sitbones. You need to sit on your sitbones, not on any other parts down there. But don't go too wide because that will cause extra friction.
-- don't use soft gel saddles. A harder saddle is better because you can support yourself on your sitbones rather than sinking into the gel and creating all sorts of friction.
-- don't be afraid to adjust your saddle ... tilt, fore/aft, the direction it points, etc.
-- make sure the bicycle fit is correct.
-- develop a strong core so that you can sit properly on a saddle, with good posture. You should not be putting your full weight on the saddle ... your feet can take a little bit of the weight.
-- get a good pair of cycling shorts. And don't ride in your underwear.
-- keep riding. Yes, it is going to hurt at first. You might want to do shortish ride every other day for a while, but go out for a walk, climb some stairs, work on your core, etc. on the day off the bicycle. The better your fitness, the greater the chances you'll find a comfortable saddle.
Machka is offline
Old 09-12-14, 09:53 AM
BikeHawg
Thanks for input... I've got good shorts. I need to improve core strength. I'll "toughen" up for next 2 weeks then re-evaluate.
BikeHawg is offline
Old 09-12-14, 03:46 PM
bbattle
bbattle's Avatar
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Quoted: 62 Post(s)
Liked 24 Times in 11 Posts
Originally Posted by Machka
Some tips:
+1109 Listen to the Machka
bbattle is offline
Old 09-12-14, 05:03 PM
gsa103
Bikes: Bianchi Infinito (Celeste, of course)
Quoted: 754 Post(s)
Liked 104 Times in 77 Posts
First saddle? About two weeks (4-6 rides).
Saddle testing? 2-3 hrs. Adjust the saddle every 20-30 minutes, if you haven't found a reasonably good position after trying 5-6 adjustments its not gonna happen.
gsa103 is offline
jrhoneOC
Fifty Plus (50+)
22
09-26-19 09:34 PM
Weakbikr
Road Cycling
23
07-29-18 05:21 AM
mworden
Road Cycling
26
08-31-13 02:40 PM
FujiKid
Road Cycling
37
10-12-11 11:13 AM
xiao_li
Road Cycling
5
01-14-11 10:57 PM
