What are these THINGS?
Quoted: 383 Post(s)
Liked 690 Times
First, yes, I could bike over to my local shop but with Covid still a presence, the less contact the better at the moment.
Just got a new Specialized e-road bike. While I believe that the yellow piece might be some kind of spacer to protect the disc brake calipers, the silver "fork" like thing was in the same plastic envelope. Actually, I'm not sure how to employ either item.
Then there are two studs on the non-chain side of the chain stay - well, when just now photographing them, I discovered they are rubber and protecting the side-by-side holes. There is a thickened plate on the inside of the chainstay. Purpose? Possibly a kickstand mounting position? Thanks in advance for any info.
Two "studs"
Tools or spacers of some kind?
Two "studs"
SE Wis
Quoted: 2746 Post(s)
Liked 3,390 Times
Looks like a cheap spoke wrench and a disc brake pad spacer for when you removal the wheel. Keeps pads apart if you push the handle with the wheel removed.
I'd guess the holes are for a kickstand.
Likes For dedhed:
Quoted: 383 Post(s)
Liked 690 Times
Thanks for the quick reply. I had not thought of spoke wrench. I will have to check its size. The only time I played with a spoke wrench was when one broke on a ride and I played trying to get the wheel to spin through the brake pads. Finally, undid the brakes - 40 miles of climbing a pass and descending 2,000 feet without that brake - carefully.
Not sure about the frame lugs, but I'd guess its a mount for a side stand. The yellow block goes in your caliper when bleeding the brakes, to prevent the brake pistons from moving. Your bike has a FutureShock, right? The silver fork thing is used when tensioning the headset bearings. The following video shows what its used for from the 6:52 mark.
Quoted: 383 Post(s)
Liked 690 Times
https://www.youtube.com/watch?v=MqG8ffTtenc
But I hope you don't mind my asking another question before I hit up the bike shop - can the handlebar be raised on this type of complex connection? After three days of riding I'm thinking I would not mind the handlebar a somewhat higher. I saw where he had different plastic collars. (I begin searching web)
Quoted: 383 Post(s)
Liked 690 Times
(I am an old guy and just learned about through axles four days ago!) What was nice, my body-float seat post fit this new contraption. And I see that same guy has videos on raising the height.
Thanks very much for the additional information.
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
Wrong and wrong. As the OP now knows that is for the FS headset adjustment. The yellow block is obviously too thick to fit between pads...it's a bleed block. It only fits w/ the pads removed and pistons pushed back all the way.
Likes For cxwrench:
Quoted: 383 Post(s)
Liked 690 Times
I did think the yellow block seemed a bit thick to "replace" the disc when the wheel was removed. So I should find something to maintain the space (I recall blowing it on my mt bike years ago on my first and only flat) for a ride side flat repair. Road bikes are more prone.
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
Your bike shop should have supplied a similar spacer to use when you remove the wheel for transport, etc.
Likes For redcon1:
Bikes: lots
Liked 2,932 Times
I use this when I remove the front wheel and put my bicycle into the back of my SUV, as I will usually bump the front wheel brake lever while trying to finagle the bicycle between the seat backs.
Quoted: 383 Post(s)
Liked 690 Times
I really want to thank everyone who contributed to this thread. I now know more about the intricacies of both the Future Shock and the disc brake. I will use my credit card - either as a spacer or to pay for the spacer and some other things
Quoted: 440 Post(s)
Liked 264 Times
The silver piece of metal is the TOOL for seating and removing the electric wires for the bike. And as others have said the yellow is the spacer for the calipers.
Likes For Bmach:
Bikes: lots
Liked 2,932 Times
