For the love of English 3 speeds...
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
The local co-op had the bones of a ladies' Raleigh Sports that appeared to have been kept at the bottom of the sea for a while, but it was gone last time I went by. If I didn't already have one I'd have considered trying to bring that one back. My own 3-speeds are worn and chipped with some rust but are not nearly this bad.
what do you think, does it look like a corrosion problem or the result of bad construction/brazing? Well, yeah, there's a lot of rust, but I don't see any brass in the joints that pulled apart. I'm thinking that what this may be an example of is water intrusion into the interface between the frame tubes and the lugs -- a space that should have been penetrated with brazing material and that should have been immune from water penetration.
I've seen some pretty poor brazing jobs on Raleighs from the 70s: poor fitting lugs and massive and obvious voids.
Pretty ugly, in any event.
If you are going to clearcoat over areas with rust, you're going to need to stop the corrosion process first. Some sort of stuff with phosphoric acid in it will do that -- it's what is used in the auto repair industry to remove the unavoidable surface rust that forms almost instantaneously on any bare, untreated iron or carbon steel. The process is to remove the rust mechanically and than treat with some sort of phosphate agent which converts remaining rust to some phosphate compound which will inhibit future rust. Smooth it out and paint either color or clearcoat. Sometimes people refer to the results of phosphoric acid treatment as "etching." Paint sticks well to treated iron/steel and it won't corrode if protected from the elements, i.e. painted.
That broken frame is indeed ugly, but I question how much of the problem was from poor assembly/brazing. Looks like the areas of the top tube and bottom tube that were actually brazed are pretty small.
Attachment 548659
Attachment 548659
edited: Back when the hurricane hit Galveston/Houston (Ike in, as I remember, 2008), Galveston flooded --pretty much of the island under sea water. I've seen some bikes and cars salvaged after the flood and it's a very, very depressing sight.
boattail71
Bikes: Too many to list. Raleigh carbon racer (17 lbs.) and fast to a '37 Columbia (17 lbs. wheels alone) Even an Aerocycle (not ridable yet), love the middleweights too.
Quoted: 28 Post(s)
Thanks!
boattail71
Quoted: 28 Post(s)
It's a strange site with lots of pages that don't look like they've been updated in about 20 years. The whole thing has a sort of "vintage" look to it.
Quoted: 1299 Post(s)
Liked 103 Times
OA is Oxalic Acid, used for rust removal and probably an ingredient in brand name products that do the same thing. Once the surface is rust-free, coat it with something like sprayed-on clear lacquer or enamel to protect the bare metal surface. Your bike really looks okay to me other than the (admittedly prolific) surface rust. Considering how much work you've already done, it would be a shame just to let it go.
Attachment 548659
Attachment 548659
Inflate Hard
Inflate Hard
Liked 2,446 Times
In my years of salvaging old English bikes, I've found that bikes in good condition are far more likely to have worn out bottom brackets from use than rusted hulks like this one. Of course, you won't know until you take it apart, but a bike like this is likely to yield a good 16 GC spindle and bearing cups. Tough to find if you need them. Unfortunately, headsets don't usually survive a bad rusting.
On the other hand, I purely hate to see one in the trash.
Liked 103 Times
I've saved a lot of bikes from the scrap pile over the years. I'll even strip and de-rust frames and forks so I can inspect them thoroughly. Only things that are dangerous to use or pitted badly are sent to the recycle pile at the town dump. I save every usable piece.
Inflate Hard
Inflate Hard
Bike Doctor
Bikes: Norco Cape Cod tandem, KHS Tandemania Cross, 1952 Claud Butler ladyback tandem, 1971 & '73 Raleigh Suberbes, 1985 Gazelle Sport Solide, 1985 Rossi professional
Quoted: 58 Post(s)
Liked 52 Times
Those tubes are torn out of the lug, probably from poor brazing prep, not catostrophic failure from rust. Although there is rust, it doesn't appear to have caused that much character.
Liked 103 Times
I'm going to amend my opinion about the gearing of my roadster. My ride this morning had me in a stiff head wind a good 10 miles headed home and I didn't resent the lower gearing from the 46Tx22T one bit. The rolling resistance from the 1 1/2" tires isn't very noticeable with still air, but every little bit counts in a head wind. On the positive side, the roadster handles sand very well. The roads here are narrow and being forced onto sandy shoulders isn't the white knuckle experience you sometimes get with thin tires.
Inflate Hard
Inflate Hard
Liked 2,446 Times
I was clicking through the photos of one bike on CL this morning and had a "WTF" moment. Just some junky Muffay thang with Shimano hub but...
BICYCLE VINTAGE ANTIQUE ATKINS "SEBRING" 3-SPEED 26"
BICYCLE VINTAGE ANTIQUE ATKINS "SEBRING" 3-SPEED 26" - $35 (HENRICO)
My wife is selling her vintage bike that she bought back in 1972. Still in fair condition. Will need tires of course and oiling of the moving parts. Nothing locked up on the bike. It has been in a shed all these yrs. Thanks, Ronnie
Old Boy
Quoted: 984 Post(s)
Liked 1,715 Times
0.75 (Low) 10.5mph
1.0 (Normal) 13.9mph
1.33 (High) 18.6mph
So if you're in high gear pedaling semi-fast, you are going almost 19 mph and fighting 3x the wind resistance than if you were pedaling at 60 rpm, which is ~14 mph. And with a headwind, that difference increases even more. On my bikes, I consider anything faster than 20mph in top gear at 80rpm a waste. Better to go with shorter gearing for the hills.
But then I guess I forgot: this is your "Path Racer", right? Better put a 16t on there!
USMC 1981-1991 Semper Fi!
Quoted: 887 Post(s)
Liked 335 Times
^^^^ I bet $25 would take that one. S/A shifter/alloy brakes & levers/handle bars that should clean up decently/cool chain guard and other bits.
Liked 103 Times
That's about perfect gearing for a roadster though, don't you think? I mean, how fast do you want to go on such a dignified steed? I did the S.B. gear calculator for your setup (S-A AW, right?) at 80rpm, and came up with this:
0.75 (Low) 10.5mph
1.33 (High) 18.6mph
0.75 (Low) 10.5mph
1.33 (High) 18.6mph
Inflate Hard
Inflate Hard
Liked 2,446 Times
It does not have the Sturmey shifter. It only has a Shimano trigger to shift its Shimano hub. That was the point of my post; that people will put the damnedest stuff in their ads without regard to proofing. The Altenburger calipers are okay but I've never liked exposed-clamp levers, even if they are alloy.
The shots are obviously of two different bikes and the one with the Sturmey shifter (the red women's bike) may actually be the one for sale. If it also has a Sturmey hub it would be worth the money for someone who wants to mess with it, but even then it has marginal appeal for me (space, hassle). The Shimano shifter/hub appears to be on the green men's bike.
On the road
Bikes: Old Schwinns and old Raleighs
Quoted: 373 Post(s)
Liked 847 Times
46-22 is a good, low gearing and does work well on the 28 inch wheel bikes. It can be very easy to "out ride your brakes" on a DL-1 if you are going fast with taller gearing on the stock steel rims. Even with Kool Stop pads, and proper adjustment, the rod brake system with stock rims is mediocre at best. If you're pushing 48-18 or 46-16 gearing hard on a flat or downhill, you're in trouble if you need to emergency stop with the stock braking system. I think 46-22 gives much better low gearing while giving reasonable cruising speeds in high.
Classic American and British Roadsters, Utility Bikes, and Sporting Bikes (1935-1979):
https://bikeshedva.blogspot.com/
Bicycle Repair Man !!!
It has been a while... nice to see that folks are still here.
Pretty soon it will be seven years since post number 1.
Dang.
Dang.
Liked 103 Times
It's been around so long because the people here have made it a great thread. I've learned a lot and found that I'm not alone in the world with my 3 speed hobby. My thanks and appreciation to all of you.
Inflate Hard
Inflate Hard
Bikes: 1971 Hercules, 1978 Raleigh Superbe, 1978 Raleigh Tourist, 1964 Glider 3 Speed, 1967 Raleigh Sprite 5 Speed, 1968 Hercules AMF 3 Speed, 1972 Raleigh Superbe, 1976 Raleigh Superbe, 1957 Flying Pigeon, 1967 Dunelt 3 Speed
Quoted: 1028 Post(s)
Liked 443 Times
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
The legs aren't working as good these days and I haven't been on a bike in months although ... will have to bust out my snappy new winter bike which isn't a three speed but has some nice SA drum brakes on a freewheel hub.
elcraft
Bikes: The keepers: 1958 Raleigh Lenton Grand Prix, 1968 Ranger, 1969 Magneet Sprint, 1971 Gitane Tour de France, 1973 Raleigh Tourist, 3 - 1986 Rossins, and a '77 PX-10 frame in process.
Quoted: 221 Post(s)
Liked 237 Times
After my experience today, I'm going to say that you're right and a 22T cog suites the roadster even a later one with the smaller chainwheel. I don't know why Raleigh fitted them with 16T cogs. Overdrive was crazy tall and useless unless you ha Reg Harris legs and wanted to keep up with friends on road bikes.
Doing this conversion on my '69 Sprite has me rarely using the left side shifter under drive.
Syke
“No one in this world, so far as I know — and I have searched the records for years, and employed agents to help me — has ever lost money by underestimating the intelligence of the great masses of the plain people. Nor has anyone ever lost public office thereby.”
H.L. Mencken, (1926)
Syke
