Rebuilding a 1990 Bridgestone RB2 as a gravel grinder/commuter.
Bikes: Salsa Podio (SRAM Rival Shifters & Derailers, Red BB and Cranks, Ritchie almost everywhere else); Steve Bauer Boreas (Shimano 105); Bridgestone RB 2 (Mixed group); Bridgestone MB 2 (Mostly XT)
I have stripped the frame bare. Forgetting the wisdom of it, any reason I can't just rebuild with a SRAM Rival build kit, and some new wheels?
The consensus is that 10 speed wheels (130mm) with fit and a 168 English threaded gxp BB should fit.
Quoted: 2026 Post(s)
Liked 1,096 Times
It certainly has a 68 mm English bottom bracket and the rear dropouts are most likely 130 mm so go for it. Even if the rear spacing turns out to be 126 mm, fitting a 130 mm hub should cause no problems.
BTW, there is a BOB (Bridgestone Owners Bunch) web site that will tell you more than you ever wanted to know about vintage Bridgestone bikes.
Expired Member
Quoted: 3669 Post(s)
Liked 5,420 Times
My 1994 RB2 will just take 28mm tires. The fork crown is the tight spot. This might limit the use on gravel but otherwise your plan should work fine.
the races to Roubaix over the cobblestones are on mostly 25mm sew-ups .. & they do a 25mph rate typically ..
I recently tried mounting some 700X32 CX tires on my '93 RB2, no go, neither front nor rear. Ten speed 130 mm hub, no problem.
Also, I thought 1993 was the last year these bikes were produced?
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
Maybe 650B will allow you to run the tires you like.
Bridgestone just dropped the US market for Bikes, they just make them for Japan , they do quite well selling Automobile tires here.
Liked 1,096 Times
I have a 1990 RB2 as well and it will fit 35mm tires. They have more cllearance than the later 92-94 models. Mine has a triple crank and bar end shifters. Concensus on iBob archives is the 90 was predecessor to the RBT. I currently have 28s and fenders for commuting and there is a ton of room, 32s and fenders easy. I had a 94 RB2 that would fit 28,s barely.
Good luck,
Tom Palmr
Twin Lake, MI
Good luck,
Tom Palmr
Twin Lake, MI
All finished
Bike came out great, although I still need to monkey with the chain length. I rode a 70 mile gravel grinder (the Dirty 40 in Vermont) two weeks after I finished it without incident. The bike did very well. I can't say the same about me!
