Ultegra Di2 FD "tails out" when tightened
Bikes: Yes
Any tricks to getting it not to twist out when tightened? The braze on clamp doesn't look damaged or anything but after line up the derailleur and go to tighten it to 5nm the tail end of the cage twists out to where it's not parallel to the chain ring anymore. Ideas?
Bikes: 199? Landshark Roadshark, 198? Mondonico Diamond, 1987 Panasonic DX-5000, 1987 Bianchi Limited, Univega... Chrome..., 1989 Schwinn Woodlands, Motobecane USA Record, Raleigh Tokul 2
Quoted: 1131 Post(s)
Does it physically twist in the mount or is it just possibly a bent hinge point?
I'd twist it the other way in the rest position and just deal with it.
Also, the derailleur doesn't have to be perfectly parallel with the chain rings. Sometimes it's beneficial to keep it tail out.
That's normal, and in fact, to be expected (I assume you read the dealer manual that came with it?). You are supposed to tighten the braze-on models so they are inboard of the large chainring by 0.5-1mm at the end of the cage, and then align them using the support screw.
Bikes: Yes
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 25 Times
You using the correct hardware to mount.
From left to right, you have fd, fd hanger (assuming it is curved and not flat) concave washer, then the bolt itself
If that is correct maybe the hanger is mashed from previous install.
Post a pic please.
Post a pic please.
Bikes: Yes
Yep. I went back to the stock washer after first trying the K-Edge chain catcher thinking that was the issue. Same story.
I'll try and get some shots tomorrow and post
