10-speed shifter with 9-speed rear derailleur, 9-speed cassette
10-speed Deore M6000 shifter is available at a good price.
Will it work with 9-speed MTB rear derailleur & 9-speed cassette (both Shimano)?
Will using SRAM or Microshift help?
Bikes: lots
Quoted: 1958 Post(s)
Liked 2,932 Times
No and no. Shifter has to match the cassette.
Quoted: 102 Post(s)
Liked 55 Times
Yeah. The shift indexes of a 9 speed are different to a 10 speed. I now have a 9 speed rear derailleur running with a 10 speed shifter and besides not being able to reach the extreme rings, it also doesn't shift the middle rings well. But I'm waiting for a replacement so I'd rather ride with 10 out of 20 gears on my foldie.
Likes For jccaclimber:
Bikes: lots
Liked 2,932 Times
OP: What specific components do you have? What are you trying to make work together?
Quoted: 1943 Post(s)
Liked 2,164 Times
The main problem you have is 10 speed mtb shifters pull a lot more cable (3.4mm) to move the RD less distance than traditional 9 speed shifters (2.5mm) pull to move the RD more. Alternate cabling will only give you a maximum of 10 percent change, depending on which way you route it, so even if you routed the cable around the corner and down the block you won't get there.
But if you are intent on mixing components, read this before you throw your money away...
Science Behind the Magic | Drivetrain Compatibility ? Art's SLO Cyclery
John
John
Likes For 70sSanO:
Thanks
Thanks
Thanks
None. Bike is currently 7-speed. Upgrading front to 3x.
Came across a good deal for a Deore 10-speed shifter and wondered if it could be used with 9-speed components. 10-speed derailleur and cassette are relatively expensive and the additional gear is of little use to me.
Thanks. Useful link.
John
John
Thanks
I just looked at my upgrade spreadsheet. The Deore M591 shifters cost $24, the XT M786 derailleur was $60 and the HG-62 cassette was $30. Not exactly break the bank expensive, but I also remember scouring the internet for a month looking for bargains. I don't know if these particular parts are still available but when I bought them they were current, and note they are all from different lines but Shimano was all cross compatible at that point in time. This was 7 years ago and this bike was my every day commuter and it still runs like it is brand new!
Liked 2,164 Times
From my experience, speed upgrade are made to add an additional cog, or two, and be able to keep the same gapping, or to keep the same range, but improve the gapping.
With a 3x setup, you can probably find the range with fewer cogs if you intend to use all 3 chainrings on a typical ride. If your intend is to have a setup where you are basically riding a 2x with the inner ring being an occasional bailout that is not used much, them more cogs can be beneficial.
A 7 speed freehub limits your options. Basically a 7 speed setup or an 8 of 9, or 9 of 10. There is a thread on BF where some members have been able to fit a 10 speed cassette on a 7 speed freehub by hanging the 1st and 10th position off each end and using a longer threaded lockring.
Regardless, you should first determine where your bike fits in long term. If it is going to be replaced in foreseeable future, maybe just stick with what you have and wait it out. If you want to use it long term, the expense factor is not as important, but you’ll first need to assess your freehub before just buying parts.
John
John
9 speed shimano compatible rear shifters are really pretty commonplace, so getting the right part is kind of a non problem.
