Campagnolo bottom bracket removal C record
Quoted: 211 Post(s)
Liked 199 Times
Hi
Just wondering how and why one might need to remove the self removing screw.
The crank arms came off, as pictured, with an allen wrench .
would there be a reason to remove the threaded piece?
Went to the bike shop to remove and they do not have a spanner with the smallest of holes to put in the 2 holes to remove.
I bought now crank arms with c record self removing cranks.
Also wondering how will I tighten it down?
I am also considering using just the usual bolt screws to put on.
Appreciate any and all thoughts and help.
Thank you
Thank you
Old fart
Quoted: 3587 Post(s)
Liked 3,400 Times
The self-extractor plate (the ring with the two holes) does not need to come out. If you do want/need to remove it, it is a left-hand thread. If you want to replace the self-extractor with standard retaining bolts, you will need a left-hand thread extractor tool to remove the arms. Be prepared to pay dearly for it:
https://www.ebay.com/itm/32473049314...YAAOSwcUBYSI4Z
Quoted: 211 Post(s)
Liked 199 Times
Thanks JDT!
I am a little confused though.
I slide the crank on and just put the bolt on and tighten slightly to test....not riding.
Wouldn't I just take the bolt out and slide the crank off ???
I must be missing something??
AND......I have a NEW set of cranks AND self extracting bolts.
If I decide to use....how would I tighten???
I did not see on the campy tool where it would fit in the 2 holes.
I have not seen s spanner that will fit in the smallest of holes.
About the size of a common pin head......maybe smaller.
Really appreciate the help
Thank you
Thank you
This is the Campy tool for removing the self extractors. (Photo from VeloBase) They were a dime a dozen back in the day. Hard to find today.
Quoted: 211 Post(s)
Liked 199 Times
Thanks gearbasher
I couldn't find one..
But ordered some pliers from Poland of all places that are made for exactly what I need.
I guess when people have one....they hold onto it😁😁😁
Yup. I still have mine. Plus, the left handed crank puller and the hub dust cap puller. Even though I sold off all my C-record stuff years ago. I quote my brother on this "Never get rid of a tool".
