Alivio SL-M3100-L vs Altus SL-M2010-L
Crankset: Altus FC-M2000, 22 x 30 x 40, bought
Front derailleur: Altus FD-M2000, 3-speed, bought
8-speed chain
7-speed cassette, with future upgrade to 9-speed
Shifters: Alivio SL-M3100-L and Altus SL-M2010-L are at the same price.
Which shifter should I buy? Why?
8-speed chain
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
generally, alivio has always been consider a step up from the altus line. however, these days i can't see much difference other than the name. are you running 8 speed or 9?
Likes For thook:
Liked 2,966 Times
x2^
I've preferred the looks of Alivio, but both would get the job done.
-Oh Hey!
-Oh Hey!
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
First step was to upgrade crankset. Done.
Next step: add FD and shifter
Last step: upgrade to 9-speed rear cassette, RD, shifter and chain.
After Covid tires, wheels, fork, etc
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
thanks for reiterating. okay...but you may still need to get a 9spd chain for things to work perfectly. i've never tried to use an 8spd chain on a 9spd set up/cassette. theoretically it could work, but may be troublesome
Quoted: 581 Post(s)
Liked 921 Times
8 speed chain compatible with 7 speed cassette.
I would get the Alivio shifter if they are the same price. Make sure you are comparing apples to apples, though - perhaps the Alivio is only a rear shifter, or maybe the Altus is a shifter/brake lever combo.
(rhymes with spook)
Quoted: 919 Post(s)
Liked 745 Times
totally aware of that. perhaps my confusion is stemming from his choice of new shifters. both are 9spd. however, they're only front shifters (neither are integrated w/brake). so, maybe he's only looking to replace the front and retain the rear shifters (7spd) for the time being
Likes For anga:
Ordered the Alivio shifter.
Thank you for the responses.
Added: downloaded the exploded view and the two shifters are almost identical. Differ only in the indicator unit. Same with derailleurs. Looks like altus, acero and alivio are converging.
