Post your e.bike pictures here.
Old 08-07-12, 03:05 PM
  #376
Apache Thunder
Interdimensional Spy
Apache Thunder's Avatar
Finally got my ebike parts moved over to my mountain bike. This was the bike I have been planning on making electric for awhile. Now that the battery box is small enough to mount onto the rear seat rack and the new lithium battery being light enough for it, this bike is now my primary bike. The old bike was just a place holder so that I had something ride able while I saved up to get the new battery and such.
The motor seems able to push this bike along better then the old one. I'm guessing because of the smaller wheels (these are 26 inch wheels instead of 700c) and that it's actually slightly lighter in weight then the old bike. It goes just as fast and now that it's able to handle 2nd gear better, it goes faster then the old bike did.
This bike is much more fun to ride and the suspension makes a world of difference. Especially once it goes up to the 23-25MPH range. Pot holes and dips don't scare me anymore and the battery box is mounted above the suspension thus it isn't exposed to as much bumps and vibration.
Apache Thunder is offline
Old 08-10-12, 04:57 AM
  #377
chi6er
Bikes: Lightning p-38, 4 ebikes, 3 recumbents
my yescomusa powered bike. Batteries are either 18s2p or 12s3p..
File Type: jpg
chi6er is offline
Old 08-24-12, 10:37 PM
  #378
Jim@stuller.org
Super trike
Come see at South Salem Cycle Works tomorrow!
My trike is getting near 100 miles a week on it for pennys. It does 22 or more on just the front hub motor from ampedbikes.com. This design was inspired by atomiczombie.com. The rear end, seat and handle bars are from a Retrike. This creation was built by Tom Sluwka of Eagle Metal Works. All upgraded bearings and tires. Now with twice the range from double the batteries.
The delta design is fast and comfortable.
Picture at.
https://www.pbase.com/llmjls/image/137994976
https://m.youtube.com/watch?v=cQAaaGt1RRY
Jim@stuller.org is offline
Old 09-08-12, 06:35 AM
  #379
rex811
Bikes: BMS SL01
My Electric mountain folding bike
Frame Material: Aluminum Alloy
Motor:Rear Motor240W
Brake system: F/R Disc Brake
Front Fork:Aluminum Alloy (can be locked)
Suspension: F/R Suspension
Tire: 26″*1.95
Rim: Aluminum Alloy
Gear Set: 21 speeds
Power Supply: 36V 8Ah Lithium Battery
Range per Charge: 40km
https://youtu.be/q-GnEQPs6kU
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
rex811 is offline
Old 09-09-12, 03:54 AM
  #380
mrmustard
mmustard
mrmustard's Avatar
Bikes: Tonaro Bighit E/Bike
Hi a vid of my Tonaro Bighit ,crank driven and loads of climbing power.
https://youtu.be/R5z6EYx35Uw
mrmustard is offline
Old 10-19-12, 05:00 PM
  #381
IthaDan
IthaDan's Avatar
Bikes: Click on the #YOLO
Quoted: 26 Post(s)
Liked 12 Times in 12 Posts
Converted an old gary fisher. This things a hoot! I may or may not have shattered half a dozen KOMs on strava today.
Shimano : Click :: Campy : Snap :: SRAM : Bang
IthaDan is offline
Old 10-20-12, 10:37 AM
  #382
squelchy
Hello everyone. This is my trike.
It's a Wes Mason custom racer trike, modified with a city-e-cycles "Conqueror" conversion kit.
It's a 1000watt 48volt motor with a li-ion 17amp battery.
Top speed 25mph
Range 40-45 miles.
It's tempramental and the wiring is cheap, but I like it.
I had to strengthen the forks to cope with the motor and swap handlebars for the throttle.. It weighs 35kg and I weigh 65kg making it 100kg.
I was struck by how similar it is to the very first image in this string from sianelle. . .
Not quite as classy, but we have the same horn and everything!
This trike also has a tow bar. The trailer takes my ruck sack, which means it's the E-bike equivalent of a motor home! If ever you're in the Scottish Highlands, you may see it chained to a gate in the middle of nowhere. I'll be camped nearby.
Hope you like it.
File Type: jpg
File Type: jpg
File Type: jpg
squelchy is offline
Likes For squelchy:
Old 10-24-12, 02:46 PM
  #383
usnavystgc
eBike Fan/Extreme DIYer
Bikes: 2013 Motobecane Gran Turismo w/ 24V/900W motor and LiFePO4 30ah pack
My Unique DIY eBike
Here is my DIY ebike made from stuff I had in the garage. I ride it to work nearly everyday.
Specs.
Frame: 1992 Bianchi Main Street hybrid
Crank: Custom made with 96t #25 gear plus 48/38/28t #35 gears with front freewheel
Rear gears: 14-34t Shimano 7spd freewheel
Motor: 24V/500W Currie scooter motor
Battery: 24V/30ah LiFePO4 (16 Headway 40152S cells)
AER: 20-25 miles
File Type: jpg
File Type: jpg
usnavystgc is offline
Likes For usnavystgc:
Old 10-29-12, 08:12 PM
  #384
Allen
Liked 10 Times in 9 Posts
Specs.
AER: 20-25 miles
That's really nice work.
Allen is offline
Old 11-16-12, 12:07 AM
  #385
IthaDan
IthaDan's Avatar
Quoted: 26 Post(s)
Updated the bike- new cranks, old xt drivetrain, hyperglide cassette. I love this thing.
Nest step is to get the controller on the seattube bottle bosses and the battery on the bosses on the bottom of the DT. Weatherproofing is going to be tough, but the weight distribution and clean look will be worth it.
IthaDan is offline
Old 11-19-12, 11:07 AM
  #386
maluf89
maluf89 is offline
Old 11-20-12, 06:39 AM
  #387
maluf89
very nice , its looks like mine !
maluf89 is offline
Old 11-24-12, 08:35 PM
  #388
Allen
Here's mine.
A Giant Twist with a Panasonic mid-drive and a Xtra-Cycle longtail extension. It makes a great cargo hauler.
The sidecar is made from a Burley Flatbed trailer. It takes just a moment to convert it from a trailer to a sidecar and back.
Allen is offline
Old 11-24-12, 09:12 PM
  #389
EBikeFL
Bikes: 2012 Kona Lanai
Those are great pictures, AllenG. I finally got to see the ladder on an e-bike.
[HR][/HR]
If we don't make changes to our use and abuse of energy, Mother Nature will make it for us.
Be a part of the solution to Climate Change instead of a contributor.
Soylent Green is People!
EBikeFL is offline
Old 11-24-12, 09:22 PM
  #390
Allen
Thanks. I was going through old files and found a few copies. I still can't find the one with the BBQ smoker strapped to the back. Still looking for that.
Allen is offline
Old 11-25-12, 07:15 PM
  #391
Sixty Fiver
Bicycle Repair Man !!!
Sixty Fiver's Avatar
Bikes: See my sig...
Quoted: 67 Post(s)
Liked 129 Times in 96 Posts
Can anyone join this club ?
Built my extrabike 4 years ago and today I turned it into an Extrabike... 36V Crystalyte 400 series gives the bike a little boost and the all wheel drive in the snow is totally awesome.
The lead acid / gel batteries are better suited for warmer weather so will be looking to upcycle some Prius batteries to serve me better in the winter although the performance was still really decent over 10 km at -10C in the snow.
Sixty Fiver is offline
Old 11-26-12, 01:27 AM
  #392
Juggler2
W A N T E D
Juggler2's Avatar
Is this the bike with the Biopace ringset? I've just started looking into Ebikes, and wondering what kind of range to expect. This bike is very high on my "like" list!
Juggler2 is offline
Old 11-26-12, 01:37 AM
  #393
Sixty Fiver
Quoted: 67 Post(s)
Yep... it has Biopace chain rings on a Deore crank which really helps the knees when the load is high and the hills are steeper.
The motor has just the right torque to give me a little boost when I need it and is really low drag when it is not under power... an extra 50 pounds on this bike actually makes it ride better... other folks who are bigger than me might want a 48V system.
Will see what kind of range I can get although our lower winter temps are going to cut into that.
Old 11-26-12, 09:50 AM
  #394
usnavystgc
That is one hell of a work horse AllenG. Awesome build!!!
Old 11-26-12, 06:09 PM
  #395
Allen
Thank you, sir.
Allen is offline
Old 11-26-12, 06:10 PM
  #396
Creakyknees
ride lots be safe
Creakyknees's Avatar
Quoted: 13 Post(s)
Birthday present for my Pops, turning 78 here in a few days. Overall review: Positive. Works great, assembled as you'd expect, everything worked the first time. I did place one call to e-bikekit.com tech support, which was quickly and well answered, turned out to be a cable not quite plugged all the way.
https://www.amazon.com/gp/product/B00...ls_o00_s01_i00
I assembled it at my place then delivered it to Pop tonight. The motor is powerful, it'll spin the front tire on pavement. The trike CG is high, so it can definitely get tippy. He liked it. Commented that it's actually pretty easy to pedal, which it is. Geared pretty low, perfect for bike path cruising and grocery runs.
Very happy with the trike and power system.
Critiques:
- Worksman's manuals are basic but adequate for a home bike mechanic enthusiast. Might befuddle the less mechanical customers. The assembly was painless, which is a positive thing. American made.
- The motor system is labeled by e-bikekit.com, and there were no manuals at all. So I checked their website which was screen-printed on the battery bag. No prob for me, but again, a small nit.
- It's not a racing bike. Stainless steel parts are shiny, durable and reliable but not lightweight.
- The tires are of good quality and arrived with proper inflation already in them, mounted correctly! Major positive to Worksman for that.
- Wheels are tight, straight and true.
- Overall as I said, it seems to be a very well-built and reliable bike, when used within it's limitations.
File Type: jpg
Creakyknees is offline
Old 11-26-12, 06:36 PM
  #397
Creakyknees
ride lots be safe
Quoted: 13 Post(s)
Originally Posted by liberator
OMG just saw this!!!! Sweeeet... is for sale? How much?
Old 12-10-12, 07:14 PM
  #398
ChrisRider
I like that vintage tricycle look, what a classic, does it still perform?
ChrisRider is offline
Old 01-02-13, 03:22 PM
  #399
mechanicalbiker
My Ampedbikes Conversion! Easy install and not to expensive.
File Type: jpg
mechanicalbiker is offline
Old 01-02-13, 06:44 PM
  #400
davidswfla
miami bike 3 wheeler salvaged from dumpster
my 3 wheeler salvaged from a dumpster. $220 for wheel kit, $100 for tires, tubes, wheel liners and paint. $110 for homemade battery pack (12volt 10ah x 3 = 36 volts.)
File Type: jpg
File Type: jpg
File Type: jpg
davidswfla is offline
