Silca frame pump rebuild advice
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
I recently got a hold of an old Silca (Impero?) frame pump that probably needs a rebuild. It seals at the stem, and the plunger seems to seal well, but the check valve isn't working.
I've had absolutely no luck finding any sort of documentation on the things, aside from some Silca Youtube videos that seem to only apply to their modern pumps. While I'm sure that the basic mechanics of the pumps are the same, the differences are enough that I'm not comfortable trying to disassemble the pump, because I'm afraid of boogering up something I couldn't replace like the nylon(?) end caps. I didn't pay a lot for the pump, so the actual risk is minimal, but I'd prefer not to mess it up if possible.
Is there any sort of documentation available on these things? Is it possible it's not an Impero pump, and I'm looking for the wrong documentation?
Quoted: 1829 Post(s)
Liked 3,375 Times
We don't need no stinkin' check valve....
honestly, there isn't a check valve on the Impero. That's part of it's "charm" and folklore.
The assumption is that the valve in the tube will stop air from getting out, which is generally true, until you bump the valve stem and release air into the pump, potentially firing the pump's plunger with great force.
Steve in Peoria (and knows better than to let a friend borrow my Impero pumps)
Quoted: 4511 Post(s)
Liked 6,378 Times
You really can't hurt these any more than it may already be, especially with the amount of trepidation (not a bad thing) already onboard.
As already said, the valve core is the check valve and the pump head needs to be fully engaged and held steadily, squarely inline with the stem while pumping.
I always apply a pinch of spit for lube, sealing and tap the valve core pintle to make sure it moves freely.
Most of them will come around with some lube on the leather plunger after cleaning it by wiping with a rag
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
So, pics or it didn't happen and so we can be sure of what it is.
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
check valve??
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,923 Times
My advice would be put it on the shelf and get a Zefal HPx that fits your frame. Silica pumps are nice classic pumps that come in lots of pretty colors but if you want to ride home get a Zefal
Sugar "Kane" Kowalczyk
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,295 Times
I'm recalling that, though rare, there were Shrader-valve heads available for this style of pump, ...assuming that those included a check valve in them(?).
I'm somehow thinking that Primus made those(?).
Liked 6,378 Times
I've never not gotten home with a Silca, every one I have will get you there.
Liked 6,378 Times
Any Silca that works will get you there once you get the hang of it, simpler more complicated times.
Likes For merziac:
Quoted: 930 Post(s)
Liked 1,291 Times
While I agree that Zefals are slightly better than Silca pumps in that they have a check valve, a Silca with a metal Campy head as 90% as good as a Zefal, and looks a darn sight better on most vintage bikes. On the other hand, Silcas with either Silca or Campy plastic heads are nowhere near as good, though they are lighter.
Likes For davester:
